7 members (Philipj, CharlieF, CATMAN, klhansen, fonz8261, Shade Baby, Phak1),
84
Mod | | | Forums66 Topics128,153 Posts1,056,842 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2011 Posts: 205 Shop Shark | | Shop Shark Joined: Sep 2011 Posts: 205 | We have come down to one of the last items to be found or made for my 36 Suburban. Tailight mounts...they are gooseneck in shape..anyone know if these are made anymore or do I have to fashion them somehow..they are larger where they fit the body and smaller at end with licence plate holder ajnd light housing. Thanks for any info as always..Bruce (mtvoices) | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Bruce, You have the oldest Suburban among our members. We should all hold you in high regard, if not in awe. You might want to check with the one other person who owns (or owned, actually) a Suburban listed in the Gallery. Most likely you have already tried this? Another possibility is the VCCA discussion boards. You have to join that discussion group, but you do not have to join the VCCA. If you join the VCCA, you are then able to get advice from experts. I do not know if they have an expert with info on a second year Suburban. Good luck. I hope someone responds with helpful information. Please let us know (and see) your progress. | | | | | Joined: Oct 2005 Posts: 4,258 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,258 | Older than the '35 in the gallery??
| | | | | Joined: Oct 2004 Posts: 1,780 Master Gabster | | Master Gabster Joined: Oct 2004 Posts: 1,780 | | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Thanks, MNSmith,
That 1935 Suburban is the true winner of the oldest possible example of a Chevrolet Suburban.
| | | | | Joined: Oct 2005 Posts: 4,258 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,258 | mtvoices still needs to be held in high regard!! His will end up being a restored example!! | | | | | Joined: Oct 2004 Posts: 1,780 Master Gabster | | Master Gabster Joined: Oct 2004 Posts: 1,780 | Thanks, MNSmith,
That 1935 Suburban is the true winner of the oldest possible example of a Chevrolet Suburban. The First Suburban | | | | | Joined: May 2009 Posts: 135 'Bolter | | 'Bolter Joined: May 2009 Posts: 135 | GMONIZ, The '36 Burb in the photo has panel truck doors installed instead of the original clamshell doors. Chevrolet did not offer a choice of rear doors on the Suburban until 1938. If the license/tail lamp bracket was the item your were pointing out, It may not be the same as was used on the lower clamshell gate.
Mike | | | | | Joined: Apr 2005 Posts: 177 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 177 | the tail lamp and tag bracket is different on the clam shell than the door model the clam shell sets off to the left on the lower rear 1/4 to clear the tail gate when it is lowered. i do not have enough parts to go back original as far as interior and running gear . so i am going to remove all the wood and change it to metal and up date the interior and dash and running gear hope to start on mine this mo. | | | | | Joined: Sep 2011 Posts: 205 Shop Shark | | Shop Shark Joined: Sep 2011 Posts: 205 | Mike and Leonard are correct..my lower tailgate has a slight "goose necked" shaped arm that does attached to very lower round corner on left..so it does not hit gate when lowered. The 35 Red Prototype that Ed B owns and is selling, has the same arm..I probably will have to make these arms or stands..as we will have two tailights. Thanks tho to all who responded. Pics soon after the finished painting. mtvoices.
| | | | | Joined: Apr 2005 Posts: 177 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 177 | if you need the tail light let me know. i am not going to use it
if you need pic of the light and tag bracket let me know
| | | | | Joined: Sep 2011 Posts: 205 Shop Shark | | Shop Shark Joined: Sep 2011 Posts: 205 | will have to make these also..they are at an angle from the lower rear corner of the burb....we will have two tailights...Bruce | | | | | Joined: Sep 2011 Posts: 205 Shop Shark | | Shop Shark Joined: Sep 2011 Posts: 205 | Still looking for this early 36 clamshell door rear tailight stand..have the correct light, lost one on Ebay today...thanks guys..Bruce mtvoices
| | | | | Joined: Sep 2011 Posts: 205 Shop Shark | | Shop Shark Joined: Sep 2011 Posts: 205 | Leonard..just wrote you aobut that piece under the my tailgate..will send pics when you eamail me...YES if you have a tailight stand like the one that fits to the bottom corner of the 35-36 body I sure could use that..I'll pay you something for it.. I have the light and housing already tho..just need that gooseneck..thanks a lot...Bruce D | | | | | Joined: Apr 2005 Posts: 177 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 177 | thanks i found some pic of the tail pan that will work i no longer have the light i sold it to someone in california | | | | | Joined: Sep 2011 Posts: 205 Shop Shark | | Shop Shark Joined: Sep 2011 Posts: 205 | Mike...we're all finished with thapainting.and the woodbed is next..then the seats..but still looking for the hard to find tailight goosenecked arm. Do you have any leads on who might have one of these rare pieces?? thanks..Bruce D. | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Bruce, remind me/us again of what years will work. Is the piece you need a '36 itme only or will a couple later years work?? I will ask around a couple guys I know "up north" but I need to know what works.......Alvin | | | | | Joined: May 2009 Posts: 135 'Bolter | | 'Bolter Joined: May 2009 Posts: 135 | Group # 2.662, Part # 474814 Tail Lamp and License Bracket Assembly '35-'39 Used with Suburban Bodies (from 1941 Master Parts Catalog) Price $1.00 Do you want me to order one for you? I have a '37 Burb with the bracket. It might be available for copying.
Mike | | | | | Joined: Oct 2004 Posts: 1,780 Master Gabster | | Master Gabster Joined: Oct 2004 Posts: 1,780 | Is this what you are looking for? This one sold on ebay. But if you can get a loaner, you can take it to one of the many 3-D copying places that can make one in plastic that you can use for a mold. Try your local college and see what they can do to help you. They may be able to make one for you for a donation to the college. | | | | | Joined: Sep 2011 Posts: 205 Shop Shark | | Shop Shark Joined: Sep 2011 Posts: 205 | It's only for the late 35's or an early 36 which my Suburban is...(made in Nov 35) so the later tailight arms are not right..this one is a goose necked S curved arm, and the licence plate holder and light fit to it., Kinda hard to make..but I know of a guy ho can make one.. it;s bigger on the end that fits to the body low corner on the right...then it reduces to the end where the light and plate holder fits. Thanks a lot for any info on this rare item...Bruce | | | | | Joined: Sep 2011 Posts: 205 Shop Shark | | Shop Shark Joined: Sep 2011 Posts: 205 | Thats the one I missed by two minutes..was bidding but somebody snipped at the last second..darn..needed that....NO...want to see if I can have it made here in Sandpoint..or maybe luck out and find another orig..thanks tho...Bruce | | | | | Joined: Oct 2004 Posts: 1,780 Master Gabster | | Master Gabster Joined: Oct 2004 Posts: 1,780 | Contact the seller and see if you can get the buyers information and contact him for a copy. I have done that and have been successful, | | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
| | | | | Joined: Sep 2011 Posts: 205 Shop Shark | | Shop Shark Joined: Sep 2011 Posts: 205 | TIM not sure if that guy got he message from me...hope he has the 35 tailightarm...Bruce | | | | | Joined: Sep 2011 Posts: 205 Shop Shark | | Shop Shark Joined: Sep 2011 Posts: 205 | does anybody know of one of these rare tailight arms and licenece plate holder combo? Still looking...mtvoices | | |
