3 members (delky, Hanks custodian, Rich'sToys), 127 guests, and 3 robots.
Topics128,149
Posts1,056,817
Members48,454
We have come down to one of the last items to be found or made for my 36 Suburban. Tailight mounts...they are gooseneck in shape..anyone know if these are made anymore or do I have to fashion them somehow..they are larger where they fit the body and smaller at end with licence plate holder ajnd light housing. Thanks for any info as always..Bruce (mtvoices)
1936 Chevy Suburban Carryall
1941 Chevy Woodie with Cantrell body
1936 Low Cab Chevy Pickup
1941 Spec Deluxe Chevy Coupe.
1953 Pontiac Catalina hardtop
More pix on Flickr
Bruce,
You have the oldest Suburban among our members. We should all hold you in high regard, if not in awe.
You might want to check with the one other person who owns (or owned, actually) a Suburban listed in the Gallery. Most likely you have already tried this?
Another possibility is the VCCA discussion boards. You have to join that discussion group, but you do not have to join the VCCA. If you join the VCCA, you are then able to get advice from experts. I do not know if they have an expert with info on a second year Suburban.
Good luck. I hope someone responds with helpful information. Please let us know (and see) your progress.
Older than the '35 in the gallery??
Thanks, MNSmith,
That 1935 Suburban is the true winner of the oldest possible example of a Chevrolet Suburban.
mtvoices still needs to be held in high regard!! His will end up being a restored example!!
Thanks, MNSmith,
The First Suburban
GMONIZ,
The '36 Burb in the photo has panel truck doors installed instead of the original clamshell doors. Chevrolet did not offer a choice of rear doors on the Suburban until 1938.
If the license/tail lamp bracket was the item your were pointing out, It may not be the same as was used on the lower clamshell gate.
Mike
1936 1-1/2 Ton (RD) Stake Body Original
the tail lamp and tag bracket is different on the clam shell than the door model the clam shell sets off to the left on the lower rear 1/4 to clear the tail gate when it is lowered. i do not have enough parts to go back original as far as interior and running gear . so i am going to remove all the wood and change it to metal and up date the interior and dash and running gear hope to start on mine this mo.
Mike and Leonard are correct..my lower tailgate has a slight "goose necked" shaped arm that does attached to very lower round corner on left..so it does not hit gate when lowered. The 35 Red Prototype that Ed B owns and is selling, has the same arm..I probably will have to make these arms or stands..as we will have two tailights. Thanks tho to all who responded. Pics soon after the finished painting. mtvoices.
More pix on Flickr
if you need the tail light let me know. i am not going to use it
if you need pic of the light and tag bracket let me know
will have to make these also..they are at an angle from the lower rear corner of the burb....we will have two tailights...Bruce
More pix on Flickr
Still looking for this early 36 clamshell door rear tailight stand..have the correct light, lost one on Ebay today...thanks guys..Bruce mtvoices
More pix on Flickr
Leonard..just wrote you aobut that piece under the my tailgate..will send pics when you eamail me...YES if you have a tailight stand like the one that fits to the bottom corner of the 35-36 body I sure could use that..I'll pay you something for it.. I have the light and housing already tho..just need that gooseneck..thanks a lot...Bruce D
More pix on Flickr
thanks i found some pic of the tail pan that will work i no longer have the light i sold it to someone in california
Mike...we're all finished with thapainting.and the woodbed is next..then the seats..but still looking for the hard to find tailight goosenecked arm. Do you have any leads on who might have one of these rare pieces?? thanks..Bruce D.
More pix on Flickr
Bruce, remind me/us again of what years will work. Is the piece you need a '36 itme only or will a couple later years work?? I will ask around a couple guys I know "up north" but I need to know what works.......Alvin
Group # 2.662, Part # 474814 Tail Lamp and License Bracket Assembly '35-'39 Used with Suburban Bodies (from 1941 Master Parts Catalog) Price $1.00
Do you want me to order one for you?
I have a '37 Burb with the bracket. It might be available for copying.
Mike
Is this what you are looking for? This one sold on ebay. But if you can get a loaner, you can take it to one of the many 3-D copying places that can make one in plastic that you can use for a mold. Try your local college and see what they can do to help you. They may be able to make one for you for a donation to the college.
It's only for the late 35's or an early 36 which my Suburban is...(made in Nov 35) so the later tailight arms are not right..this one is a goose necked S curved arm, and the licence plate holder and light fit to it., Kinda hard to make..but I know of a guy ho can make one.. it;s bigger on the end that fits to the body low corner on the right...then it reduces to the end where the light and plate holder fits. Thanks a lot for any info on this rare item...Bruce
More pix on Flickr
Thats the one I missed by two minutes..was bidding but somebody snipped at the last second..darn..needed that....NO...want to see if I can have it made here in Sandpoint..or maybe luck out and find another orig..thanks tho...Bruce
More pix on Flickr
Contact the seller and see if you can get the buyers information and contact him for a copy. I have done that and have been successful,
pm sent to you
1951 3100 Chevrolet
TIM not sure if that guy got he message from me...hope he has the 35 tailightarm...Bruce
More pix on Flickr
does anybody know of one of these rare tailight arms and licenece plate holder combo? Still looking...mtvoices
More pix on Flickr
