| | | Forums66 Topics128,164 Posts1,056,977 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2012 Posts: 197 Shop Shark | | Shop Shark Joined: Jun 2012 Posts: 197 | As the title says! My personal results:
1965 C-10, 3.73 open rear, 31x10.50x15 drive tires (14.5" loaded radius), three speed SM318 and 230 with a slightly later Monojet. Engine is stock, complete with ultra high mileage and stuck lifter. (I figure at least 400,000 since the head's been off. Low drag rings courtesy of time?) Carburetor should have stock jets, idle mixture tuned lean. Timing bumped up to 8 degrees initial. Had an electric fan and fuel pump at that time, also. Mileage was about 18-20MPG @ 50-55MPH or so.
1966 C-10, 3.08 gov bomb, same drive tires as the '65, 3.11 first Saginaw 4 speed. 350 with Edelbrock #1406 AVS copy, Chinese dual plane intake, flat top pistons, stock profile CS274 cam. About 90,000 on it since it was rebuilt. Vortec heads. Flex fan, electric fuel pump, point and coil. Got 16-17MPG or so on it's first run with the 3.08 gears going about 60MPH. (Didn't get any numbers with the 3.73s)
This was done using google maps to calculate distance, then parking the truck in the same spot and adding fuel up to a dipstick level by weight. The same route more or less was used both times, mixed rural highway/town with some fairly good hills. About 90 miles total.
I'm going to make a 6 gallon strap-in tank to put in the bed next, so I can just weigh the tank to determine fuel used. Should be real accurate and also allow me to do some shorter test runs.
What's your mileage with your truck?
Some of my crap: 1963 C-30 flatbed dually 292/SM420 1965 C-10 LWB fleet 250/column shift 3 speed 1965 C-30 9' stepside 250/SM420/4.10 gears (my DD) Website I made for my crap: http://www.66submarine.com | | | | | Joined: Jun 2012 Posts: 197 Shop Shark | | Shop Shark Joined: Jun 2012 Posts: 197 | Results are in for today's run in the '66. 54 miles, a lot of that city, three gallons, so 18MPG. Not bad!
Some of my crap: 1963 C-30 flatbed dually 292/SM420 1965 C-10 LWB fleet 250/column shift 3 speed 1965 C-30 9' stepside 250/SM420/4.10 gears (my DD) Website I made for my crap: http://www.66submarine.com | | | | | Joined: Jan 2010 Posts: 378 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 378 | I don't know the MPG but my 49 stock 235 with changed out open drive with 3:90's is BAD. I think if I looked real good I could see the needle move. Maybe the gauge is wrong, I really don't know. | | | | | Joined: Jul 2005 Posts: 946 'Bolter | | 'Bolter Joined: Jul 2005 Posts: 946 | I stopped checking when it was 10 mpg, but it seems to get much better gas mileage now, with 3,000 miles, advanced timing and premium gason the 350.
| | | | | Joined: Feb 2007 Posts: 435 'Bolter | | 'Bolter Joined: Feb 2007 Posts: 435 | 64' C-10, rebuilt 230 w/ slight RV cam, stock 1 bbl. carb, 3 on the tree,3:73 gears and 15" tires, and I'm lucky to see 16-17mpg at Interstate speeds of 60-70 mph. Getting ready to install T-5 and that should help some. Let you know how it works out. Tramp | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | ....gulp, gallon.....gulp, gallon. At 90+ it takes more  | | | | | Joined: Jan 2011 Posts: 188 'Bolter | | 'Bolter Joined: Jan 2011 Posts: 188 | I'm getting a solid 10 MPG on the 85 3/4 ton GMC....
The 52 is getting superb mileage! It runs as long as I keep putting fuel down the carb! | | | | | Joined: Nov 2010 Posts: 1,159 Shop Shark | | Shop Shark Joined: Nov 2010 Posts: 1,159 | My '55 T.F.,is getting about 13-15 M.P.G.,depending on city,or hi-way. Rebuilt head,rebuilt carburetor,Fenton headers,and backed-off front brakes.(Still excellent pedal-new wheel-cylinders). P.O. told me he averaged 6 M.P.G.! Quite an improvement,and not bad fuel-consumption,for a 57-year-old 2-Ton! B.T.W.-261/SM 420/not sure hi-range 2-speed ratio?
| | | | | Joined: Dec 2002 Posts: 3,445 Moderator - The Electrical Bay | | Moderator - The Electrical Bay Joined: Dec 2002 Posts: 3,445 | about 10 mpg over about 10k miles and 12 years
| | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | The star of my fleet is our '50 4dr sedan, all stock 216 3 speed. We usually are in the 17-18 range on the highway. We just cruise along at 50. | | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | 1954/3100/235, dual carbs offy intake, fenton headers s/10 5speed, 2.73 nova rearend and 235/70/15 tires. 16.5 in town and high as 26.6 on highway but down hill in the mountains. 22-23 average too Kansas city. the amazing thing too me is i just bought a new GMC Terrain it weighs 4100 pounds empty and i am averaging 23.6 around town driving. i have not had it out of town on a real long drive.
Ron, The Computer Greek I love therefore I am.1954 3100 Chevy truckIn the Gallery 2017 Buick Encore See more pix1960 MGA Roadster Sold 7/18/2017
