2 members (Gray_Ghost, 1 invisible), 238 guests, and 2 robots.
Topics128,106
Posts1,056,213
Members48,436
#907044 12/29/2012 11:51 AM
I'm about ready to paint my enclosed driveline on my 41, it's all in pieces, has been washed down with solvent and wire brushed by hand. I was thinking of painting it with POR-15. Question is would it help if I coated it with OSPHO before painting? Dave
1941 Chevy
"First rebuild - complete!"
Follow the story in the DITY
1941 GMC resting peacefully
1946/1947 Chevy Street rod on s10 frame complete
1945 GMC panel truck in line for restoration
1941 Plymouth stock complete
1941 GMC COE in restoration process
Read his Project Journal
1941 Chevy Coe uncertain future resting now
homer52 #907053 12/29/2012 12:22 PM
No need, as long as you have loose material removed. In fact, you want surface rust for best adherence results with POR-15.
homer52 #907310 12/30/2012 3:08 AM
1941 Chevy
homer52 #909459 01/07/2013 12:07 PM
The POR-15 company sells something called Metal-Ready which they like you to use before you use the POR-15 itself. I think it's basically a phosphoric acid solution. Mostly make sure the surface is clean.
Ed Miller
'58 Apache short Fleetside half ton Napco
Falls City, OR
homer52 #909560 01/07/2013 6:31 PM
Use their Metal-Ready, if that stuff isn't properly prepared it will peel off in sheets. Also, surface rust helps. I would was my parts with water and let em sit for a day and get a little surface rust then paint on POR. Kinda convenient when you lack all the time in the world!
homer52 #913141 01/20/2013 2:03 PM
I wire brushed, ground and otherwise cleaned off all the grease, grime, paint and rust flakes off, then used oven cleaner to get the grease out of the tight spots. I power washed it all, let it sit for a day or so, then treat with the POR-15.. so far so good... (My 39 was treated 12 years ago with very few problems.)
Another quality post.
Real Trucks Rattle
homer52 #913208 01/20/2013 5:28 PM
...I like the stuff to Rusty Rod.
