8 members (msmall, 68ironhead, Shardean, DannyW, Eisenholtz, 3800GUY, Shade Baby, cmayna),
41
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,023 Posts1,055,367 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2011 Posts: 306 'Bolter | | 'Bolter Joined: Jan 2011 Posts: 306 | Now that I'm ready to reassemble I'm wondering in what order do I put the truck together? I have the factory assembly manual. Just wondering so that I don't put on take off a bunch of times. thanks rolf
1963 c10 | | | | | Joined: Jun 2010 Posts: 1,001 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 1,001 | To put it simply, the same way you took it apart. I dont really think you will get two people to answer this question the same way. Do what makes sense to you.
For me, I would set the engine (on completed chassis), set the cab and then the steering gear/mast. Then, it is in whatever order makes you smile at the end of the day.
Edit: Oops, I assumed an AD truck, might not be the case.
| | | | | Joined: Jan 2011 Posts: 306 'Bolter | | 'Bolter Joined: Jan 2011 Posts: 306 | it's the 53. i was thinking along those same lines thanks rolf
1963 c10 | | | | | Joined: Apr 2011 Posts: 89 'Bolter | | 'Bolter Joined: Apr 2011 Posts: 89 | Not a complete description but you might check out the 47-54 forum on Classic Parts of Americas site. It has a sticky near the top that covers a lot of the reassembly process. Not very good with linking stuff but heres the web address: http://talk.classicparts.com/showthread.php?t=9530happens to be of a '53 as well, maybe itll help Chooglin | | | | | Joined: Jan 2011 Posts: 306 'Bolter | | 'Bolter Joined: Jan 2011 Posts: 306 | great link choog! thanks rolf
1963 c10 | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | Is the cab off the frame?
| | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | Is the cab off the frame? Or the cab off the frame?  | | | | | Joined: Jan 2011 Posts: 306 'Bolter | | 'Bolter Joined: Jan 2011 Posts: 306 | the cab is off the frame. axles and drums are on the frame. brake lines and master cylinder on the frame. engine and tranny are on the frame. having done all that i will now move the frame in that configuration from my old shop to my new shop. everything is in new paint. new glass. new rubber. the vent windows need to be redone. i have the tech tip for that. i will be doing 99% of the work by myself.
rolf
1963 c10 | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | fuel lines, ebrake, brake lines,then engine and tranny, then cab....then rest a while and think and write down a sequence that makes sence.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Jan 2011 Posts: 306 'Bolter | | 'Bolter Joined: Jan 2011 Posts: 306 | i was thinking of trying to make a list but figured as i got into the process it would become clear what the order should be. i'm wondering mainly when the windows should go in.obviously after the cab is mounted.
thanks everyone merry christmas
rolf
1963 c10 | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | As I have said in another post , leave the doors off till last. Everything! is easier!!!! Dash parts install, seats, column, wiring, everything is easier without those darn doors in the way. Do the door glass and rubber items and any other door work on a carpeted table. Leave the steering wheel off also. Jack up frame real high to get under easily and to have it at chair height for lights, bumper, etc install. you can do the exhaust system while body is off also if you want, as mentioned.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | When mounting your cab make sure you reinstall any shims that may have been under the shackles and cab bottom.
This is spelled out in the shop manual Here is the page in the manal I was refering to | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | ...ditto about the doors. It is much easier to put the weather stripping on with the doors off. | | | | | Joined: Jan 2011 Posts: 306 'Bolter | | 'Bolter Joined: Jan 2011 Posts: 306 | thanks guys all good advice rolf
1963 c10 | | |
