4 members (50Chevy3100, Otto Skorzeny, carbking, 1 invisible), 74 guests, and 2 robots.
Topics128,023
Posts1,055,370
Members48,420
#905799 12/24/2012 8:16 AM
Now that I'm ready to reassemble I'm wondering in what order do I put the truck together?
I have the factory assembly manual.
Just wondering so that I don't put on take off a bunch of times.
thanks
rolf
1963 c10
rgie #905813 12/24/2012 8:53 AM
To put it simply, the same way you took it apart. I dont really think you will get two people to answer this question the same way. Do what makes sense to you.
For me, I would set the engine (on completed chassis), set the cab and then the steering gear/mast. Then, it is in whatever order makes you smile at the end of the day.
Edit: Oops, I assumed an AD truck, might not be the case.
DavidF #905882 12/24/2012 12:23 PM
it's the 53.
i was thinking along those same lines
thanks
rolf
1963 c10
rgie #906041 12/25/2012 12:06 AM
Not a complete description but you might check out the 47-54 forum on Classic Parts of Americas site. It has a sticky near the top that covers a lot of the reassembly process. Not very good with linking stuff but heres the web address:
http://talk.classicparts.com/showthread.php?t=9530
happens to be of a '53 as well, maybe itll help
Chooglin
1954 3600
[/url] www.tors54.tumblr.com
rgie #906079 12/25/2012 8:45 AM
great link choog!
thanks
rolf
1963 c10
rgie #906081 12/25/2012 8:58 AM
Is the cab off the frame?
DADS50 #906100 12/25/2012 10:54 AM
Or the cab off the frame? dance
rgie #906124 12/25/2012 1:32 PM
the cab is off the frame.
axles and drums are on the frame.
brake lines and master cylinder on the frame.
engine and tranny are on the frame.
having done all that i will now move the frame in that configuration from my old shop to my new shop.
everything is in new paint.
new glass.
new rubber.
the vent windows need to be redone. i have the tech tip for that.
i will be doing 99% of the work by myself.
rolf
1963 c10
rgie #906132 12/25/2012 1:49 PM
Sir Searchalot
Sir Searchalot
fuel lines, ebrake, brake lines,then engine and tranny, then cab....then rest a while and think and write down a sequence that makes sence.
rgie #906169 12/25/2012 6:01 PM
i was thinking of trying to make a list but figured as i got into the process it would become clear what the order should be.
i'm wondering mainly when the windows should go in.obviously after the cab is mounted.
thanks everyone
merry christmas
rolf
1963 c10
rgie #906194 12/25/2012 9:07 PM
Sir Searchalot
Sir Searchalot
As I have said in another post , leave the doors off till last. Everything! is easier!!!! Dash parts install, seats, column, wiring, everything is easier without those darn doors in the way. Do the door glass and rubber items and any other door work on
a carpeted table. Leave the steering wheel off also. Jack up frame real high to get under easily and to have it at chair height for lights, bumper, etc install. you can do the exhaust system while body is off also if you want, as mentioned.
When mounting your cab make sure you reinstall any shims that may have been under the shackles and cab bottom.
This is spelled out in the shop manual
Here is the page in the manal I was refering to
Step 9 here
...click...
rgie #906216 12/25/2012 10:46 PM
...ditto about the doors. It is much easier to put the weather stripping on with the doors off.
rgie #906275 12/26/2012 9:48 AM
thanks guys
all good advice
rolf
1963 c10
