7 members (GMCJammer51, Phak1, Leo, Tom McGrath, dt235sd, DaveV, Paul_WNC),
106
Mod | | | Forums66 Topics128,050 Posts1,055,646 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2001 Posts: 1,096 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,096 | I am doing a diff for my truck .
I have a spare diff head that I think is from a '55. The one in my truck is from a '54. These should be the same item.
I am looking for the carrier bearings . KC11445Y. I have looked at several sites , but they are offering a taper roller replacement. I cannot see how an item engineered for barrel roller will accept a taper roller and not subject the taper bearing to undue point loading.
Can someone please help me locate the correct barrel roller bearing . | | | | | Joined: Aug 2004 Posts: 1,418 ODSS Lawman | | ODSS Lawman Joined: Aug 2004 Posts: 1,418 | The carrier bearings are roller type. They fit inside the bearing caps and are preloaded. These bearings were roller type as far back as 1940. Perhaps earlier.
The roller part is pressed onto the two end of the carrier and the races are placed on them when it is installed into the housing then are preloaded with the adjusting screws.
SWEET Sergeant At Arms: Old Dominion Stovebolt Society BUNS?!?!?!Where we're going, we don't need no buns.....1950 GMC 450 1951 Chevy 1/2-TonThe GreenMachineIn the Stovebolt Gallery | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: Feb 2001 Posts: 1,096 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,096 | Thanks for your thoughts SWEET, I know what type of bearing I am looking for (I have it in my hand) I just cannot find an appropriate supplier. | | | | | Joined: Feb 2001 Posts: 1,096 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,096 | Tim, thanks for the link. That is the bearing I am having the problem with.
The one shown in that link has not got the barrel shaped rollers of the original fitment style. | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | When replaced as a set,(cup and cone/bearing and race), the tapered roller bearing will work fine as a replacement for the old style barrel shaped bearing.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Aug 2004 Posts: 1,418 ODSS Lawman | | ODSS Lawman Joined: Aug 2004 Posts: 1,418 | Do you have a photo of this bearing?
SWEET Sergeant At Arms: Old Dominion Stovebolt Society BUNS?!?!?!Where we're going, we don't need no buns.....1950 GMC 450 1951 Chevy 1/2-TonThe GreenMachineIn the Stovebolt Gallery | | | | | Joined: Feb 2001 Posts: 1,096 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,096 | You have a pic on your gear swap . pic #21 shows the original barrel roller and later pic #60 shows you have replaced them with a standard taper roller set.
| | | | | Joined: Feb 2006 Posts: 1,867 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 1,867 | Dusty, Ive never seen barrel rollers used in a rearend before. I do believe those are tapered roller bearings originally and both pictures referenced above look like tapered rollers to me.  Jeff | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | Dusty is right, Chev used barrel rollers on the diff side bearings. They also used them on the worm thrust bearings in steering boxes, and most likely in other places I would need to stop and think about.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Aug 2004 Posts: 1,418 ODSS Lawman | | ODSS Lawman Joined: Aug 2004 Posts: 1,418 | Dusty
The bearings that I have in my rear end have been there untouched for 6+ years with over 10,000+ miles on them. I have not had any issues.
I am sure that if you install these in your truck and follow all of the installation directions for pre-loading, you too will have many many miles of trouble-free driving.
If anything, the roller type bearings should perform better since any point load applied to the races are distributed over a greater area thus reducing wear at the point of contact. Just like installing roller bearings in the front wheels versus the original style.
In the end, the bearing folks have thousands of hours in research and testing. If the original barrel type bearings performed better, you'd be able to find them.....
