1 members (Hotrod Lincoln),
73
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,055 Posts1,055,782 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2009 Posts: 33 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2009 Posts: 33 | im having trouble with my doors closing an latching they seem to sag an have a hard time closing them with out slaming them an that still dont work some times also have to lift up on the door to get it to close any advice how to fix this prob ?
1957 Chevy Service Station Wrecker
| | | | | Joined: May 2012 Posts: 574 'Bolter | | 'Bolter Joined: May 2012 Posts: 574 | my truck has the same problem.... one of the hinges are broken more than likely
1949 Dodge Coronet 1955 2nd Chevy 4400 1.5 ton 1955 2nd Chevy 3100 1/2 ton 1955 2nd Chevy 3100 1/2 ton 1957 Chevy 5400 LCF 2 ton 1966 Dodge D100 Sweptline 1968 Chevy P20 stepvan 1969 GMC LWB pickup 1972 GMC Sprint 1974 CP30 shorty bus There are three things that I've learned never discuss with people: religion, politics, and the Great Pumpkin.----Linus Van Pelt Trying to understand the behavior of some people is like trying to smell the color 9 | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | With the door in the open position lift up and down on the back edge of the door. If there is any up and down movement look and see where it is. It could be a rust problem on the door or cab. It could also be a loose/bad hinge. If there is no movement then a simple hinge adjustment will fix the problem.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Jul 2009 Posts: 33 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2009 Posts: 33 | the hinges have a sloppy give to them any way to fix with out having to replace hinges ?
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | if you're sure it's the hinges themselves that are sloppy and not the attaching points inside the door, you could try replacing the hinge pins - with oversize ones if it's the holes that are wallowed out and not just the pins corroded/worn away .... replacement pins should be available from a NAPA if you have one nearby
Bill | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Take off striker plate on door jamb and see if door fits OK. If not, adjust pillar and door hinges accordingly (if pins/hinges are good). Then adjust striker so that door is slightly lifted by striker when closed and rubber is squeezed enough to seal and door is flush..... These doors will need to be "slammed" as compared to todays doors. If rubber is new it will take awhile to be a gentle SLAM!
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Nov 2010 Posts: 1,159 Shop Shark | | Shop Shark Joined: Nov 2010 Posts: 1,159 | My passenger side door has a BIG problem,too. It sags when I open it,and on further inspection,the lower hinge is "flopping in the breeze",(technical term.) To make matters worse,the bolts are carriage style,with only one having a slot for an impact screwdriver. the other is just a round head carriage bolt. I'm thinking about welding a nut on the carriage bolt,and trying to remove it,before drilling out the bolt,and damaging the retainer nut. Has anyone done this on a T.F.?? | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | Willy, sounds like a farmer fix on those hinge bolts, should be cage nuts the hinges are attached to with hex head or clutch head bolts, there'd be no way to tighten a carriage bolt from the outside, but you may be able to get a wrench on the nuts by looking in the slot behind the kick panel - the holes in the hinges are [were] squarish slots for adjustment and that may catch the shoulder on a carriage bolt so you couldn't turn it anyway
Bill | | | | | Joined: Nov 2010 Posts: 1,159 Shop Shark | | Shop Shark Joined: Nov 2010 Posts: 1,159 | Thanks,Bill! i thought I posted this question,but couldn't find it. I'll remove the kick panel again,and see if I can gain access. I did notice the 3rd mounting bolt,accessible behind the tire. THANKS!! | | | | | Joined: May 2012 Posts: 574 'Bolter | | 'Bolter Joined: May 2012 Posts: 574 | just saw this post, and I too have the big carriage bolts, one on the bottom having a cut in it for a very large screwdriver or impact wrench, i have seen it on multiple 55-7 trucks of various sizes but my Apache doesn't have the carriage bolts, just normal hex head bolts, also I read somewhere that this was something that they did for a short time on the early TF trucks but discontinued due to trouble removing the hinges later on, something I can attest to, LOL  Indy
1949 Dodge Coronet 1955 2nd Chevy 4400 1.5 ton 1955 2nd Chevy 3100 1/2 ton 1955 2nd Chevy 3100 1/2 ton 1957 Chevy 5400 LCF 2 ton 1966 Dodge D100 Sweptline 1968 Chevy P20 stepvan 1969 GMC LWB pickup 1972 GMC Sprint 1974 CP30 shorty bus There are three things that I've learned never discuss with people: religion, politics, and the Great Pumpkin.----Linus Van Pelt Trying to understand the behavior of some people is like trying to smell the color 9 | | | | | Joined: Dec 2011 Posts: 402 Shop Shark | | Shop Shark Joined: Dec 2011 Posts: 402 | X2 on the carriage-bolt-through-the-door fix. Looks like this was a common thing. Must have worked...the doors were still attached. The heads were buried under about 1/2 inch of body filler.
-Jim | | | | | Joined: Apr 2005 Posts: 1,971 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,971 | I just rebuilt on of my doors. I had another old Chevy and I took off the doors. The lower hinges were really shot. I took a top hinge off and put in in the bottom of my good door. Closes pretty good now. | | |
