6 members (Jon G, 68ironhead, 3B, DHedrick, Oswald, 1 invisible), 99 guests, and 3 robots.
Topics128,151
Posts1,057,009
Members48,460
ANY TRICKS ON INSTALLING THOSE RUBBER CAB WEATHERSTRIPPINGS INTO THEIR CHANNELS IN ONE PIECE. I'VE GOT ALL THE CHANNELS CLEAN AND STRAIGHT.
RUBBER WILL NOT SAY IN THE TIGHT CURVE AT THE TOP RIGHT OF PASSENGER DOOR FRAME. HAVEN'T TRIED DRIVERS DOOR FRAME YET. THANKS
Nick Burton
without the caps lock...
3M weatherstrip adhesive
...once you get it in the track use some channel locks or something of your choosing and pinch the track together some. Its so hard to get it in that some folks clean and "open" the track some and then it won't hold the stripping so just pinch it back together while holding it in with a screw driver.
As I installed the windlace in my '53 I would periodically tap on a spot with a rubber mallet after the windlace was where I wanted it so it would'nt move or come out as I worked my way around the door opening. You just have to strike it hard enough to pinch the metal track down onto the rubber.
Thanks for you help!!
Nick Burton
Smack it with a rubber mallet after you get it in the track. That will crimp the track around the rubber.
Moderated by  ndkid275, Phak1
