| | | Forums66 Topics128,157 Posts1,056,877 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2008 Posts: 19 New Guy | | New Guy Joined: Feb 2008 Posts: 19 | ANY TRICKS ON INSTALLING THOSE RUBBER CAB WEATHERSTRIPPINGS INTO THEIR CHANNELS IN ONE PIECE. I'VE GOT ALL THE CHANNELS CLEAN AND STRAIGHT. RUBBER WILL NOT SAY IN THE TIGHT CURVE AT THE TOP RIGHT OF PASSENGER DOOR FRAME. HAVEN'T TRIED DRIVERS DOOR FRAME YET. THANKS
Nick Burton
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | without the caps lock... 3M weatherstrip adhesive | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | ...once you get it in the track use some channel locks or something of your choosing and pinch the track together some. Its so hard to get it in that some folks clean and "open" the track some and then it won't hold the stripping so just pinch it back together while holding it in with a screw driver. | | | | | Joined: Nov 2009 Posts: 639 'Bolter | | 'Bolter Joined: Nov 2009 Posts: 639 | As I installed the windlace in my '53 I would periodically tap on a spot with a rubber mallet after the windlace was where I wanted it so it would'nt move or come out as I worked my way around the door opening. You just have to strike it hard enough to pinch the metal track down onto the rubber. | | | | | Joined: Feb 2008 Posts: 19 New Guy | | New Guy Joined: Feb 2008 Posts: 19 |
Nick Burton
| | | | | Joined: Aug 2002 Posts: 154 'Bolter | | 'Bolter Joined: Aug 2002 Posts: 154 | Smack it with a rubber mallet after you get it in the track. That will crimp the track around the rubber. | | |
