2 members (78buckshot, NJC),
99
Mod | | | Forums66 Topics128,149 Posts1,056,819 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2012 Posts: 3 New Guy | | New Guy Joined: Oct 2012 Posts: 3 | Anyone know where to get the odd shaped tool to remove the rear fenders from a 1958 Apache? I have looked and looked with no luck. | | | | | Joined: Jun 2006 Posts: 693 'Bolter | | 'Bolter Joined: Jun 2006 Posts: 693 | do you mean for the clutch-head bolts that hold the fenders to the bedsides? the bits are available on eBay and tool suppliers. search on "clutch head bit" | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Don't know about "today" but I have seen those clutch head sets in Lowes, Home Depot and even Ace Hardware on occassions. They are also available from most all vendors, with shippin of coarse. You can also get them in sockets...... | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | as Tom sez, you want the biggest clutch head screwdriver, and the rest of the set of 3 or 4 as well if you're working on the whole truck
Bill | | | | | Joined: Oct 2012 Posts: 3 New Guy | | New Guy Joined: Oct 2012 Posts: 3 | Much appreciated guys. I knew it was a certain "NAME" that would make the difference in my search. | | | | | Joined: Jan 2015 Posts: 2 Moderated | | Moderated Joined: Jan 2015 Posts: 2 | I know this is an older post... but wanted to add to my experience. After identifying the same with this tread, Thank You!, I found a clutch head driver set at the Tri-State Car Parts Swap meet in Denver. $12.00 It worked in removing only 5 of the bolts on the bed. The bolts stripped out even with a solid fit. I had to drill the rest out. It worked and did not take to long. I will replace them with a hex head or equivalent. Not a fan the clutch head.
1959 3100 Apache (Farm Find) Always another day to get that fixed...
| | | | | Joined: Apr 2005 Posts: 1,971 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,971 | I found clutch head sockets on a Snap-On truck. They grip the screws better than the screw driver style I ordered from LMC or where ever I got them from. | | |
