Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
5 members (Samantha, baldeagle, SandraD, farmallb, Peggy M), 55 guests, and 1 robot.
Topics128,005
Posts1,055,261
Members48,418
#871338 08/01/2012 7:32 PM
My donor gauges didn't come with the line that runs from the engine to the temp gauge. Is there a way to join my existing temp line to the new donor gauge? Thanks
What year? What year and kind of engine?
Mechanical (copper tube) or electrical sender/gauge?
Electrical can be joined; mechanical cannot, unless you are real talented.
52' Original 216 with mechanical gauge.
Order one of these (all the vendors carry them) the sealed sender/tube is all attached.
http://www.classicparts.com/1949-53-Temp-Gauge-w_-White-Needle-6-cyl/productinfo/24-703C/
I'm gonna re-use my temp gauge setup with the donor gauge face. I'll just have to paint the needle. I have some tiny screws to attach the donor face to my temp gauge.
Well, after removing the temp gauge from the truck(what a pain in the....), I started drilling out the tiny rivets holding the gauge face on. Apparently, while drilling the second rivet, I applied to much pressure on the unit and the needle went to 180 instead of 100. Is it possible to bend the coil back so the needle rest near 100? Is there a way to test it out of the truck or should I just order a new one?
....my thoughts. Bend it back and then put the sender in a pot of hot water. Drop one of those temp "probes" down in the water and check the guage to the probe temp.
Yup, I bent the coil back to where the gauge was reading 100 and then borrowed a temp reading gun from a friend and heated up the end of the temp sending unit and it was off. So I've ordered a new gauge and hopefully it'll be here by the weekend. I figure something that delicate and that old could be replaced giving me peace of mind.
I sure am learning a lot about these old trucks the more I dig into it. Just makes me want to learn more!
Moderated by  ndkid275, Phak1
