0 members (),
182
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,108 Posts1,056,228 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | I have decided to use Jim Carters upholstery kits and cover my own seat frames.I'm using Spanish brown grain. Here are some photos of the lower jump seat cushion. burlap hog ringed coir hog ringed jute jump lower cushion upholstered jump lower cushion upholstered #2 If you guys want me to post all the cushions as I do them,just say so and I will add it to this thread. Tim 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | ....by all means Tim. Curious minds want to see. You may convince me that even I can do it? | | | | | Joined: Jul 2012 Posts: 83 Shop Shark | | Shop Shark Joined: Jul 2012 Posts: 83 |
1953 1 ton panel
| | | | | Joined: Oct 2011 Posts: 206 Shop Shark | | Shop Shark Joined: Oct 2011 Posts: 206 | so hog ring will work? Im planning on sewing new covers with my mothers new industrial machine, but worried i needed the round lil clips. looks good! | | | | | Joined: Oct 2004 Posts: 1,780 Master Gabster | | Master Gabster Joined: Oct 2004 Posts: 1,780 | That jump seat look great!  | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | drew, Wait to hear from Tim in response to the hog ring question. What I think I see/read (from Tim's two posts on this project) is that hog rings were used for layers under the upholstery and the original-style c-clips were used for the upholstery. | | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | I used original style c-clips that Tim Lederman linked to above on the upholstery material.I used the hog rings on the layers under the cotton and upholstery.
To use hog rings,I believe there is wire that is fed into the bead material.I watched a lot of you tube videos on upholstery and decided I would try it myself.
The other post I have concerns the reproduction seat cushion I built and the seat frame Elhippie64 built.The rest of the seats and cushions will be posted in this thread.
Thanks for the kind words and I will be posting more soon.
Thanks,Tim
| | | | | Joined: Nov 2004 Posts: 1,552 Shop Shark | | Shop Shark Joined: Nov 2004 Posts: 1,552 | | | | | | Joined: Oct 2011 Posts: 206 Shop Shark | | Shop Shark Joined: Oct 2011 Posts: 206 | ahh so i do need those then, i was studying it the other day when i pulled my jump seat and it looked like a hog ring wasent going to work.
| | | | | Joined: Feb 2005 Posts: 531 Shop Shark | | Shop Shark Joined: Feb 2005 Posts: 531 | | | | | | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | bowtietim, I need that blue 51,let me know when I can come down and pick it up.......I will leave you my 52 sedan in exchange...lol Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | | | | Joined: May 2007 Posts: 222 Shop Shark | | Shop Shark Joined: May 2007 Posts: 222 | Tim
Are the seats in you suburban comprised of a 3/4 bench seat and a jump seat? If so does Jim Carter have the kit to re-upholster them? Thanks for the help
God bless,
Dave
Joh 3:16 For God so loved the world, that he gave his only begotten Son, that whosoever believeth in him should not perish, but have everlasting life.
| | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | Yes it's just as you describe and yes I purchased from Jim Carter.I have a problem with the fitment of the jump seat back rest upholstery and both middle seat cushions.
I talked to Jim Saturday and I will be dropping the seat cushions off to the guy that makes the upholstery.You might want to wait on ordering them until I report back on the fix.
Tim
| | | | | Joined: Feb 2005 Posts: 531 Shop Shark | | Shop Shark Joined: Feb 2005 Posts: 531 | Say Tim, I looked on the Jim Carter website and even called them and they said they don't carry Panel seat kits..... do you have more info on them?
Thanks! | | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | I'm sorry I don't know anything about panel seats.My thread is all about suburban seats.Do you know if the panels used the same type of material and color ?
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Same type of material - gray color.
| | | | | Joined: Feb 2005 Posts: 531 Shop Shark | | Shop Shark Joined: Feb 2005 Posts: 531 | Mmmm.... Sorry when I looked at the photos I saw a bucket. Presumed it was a panel. So is a Suburban Jump Seat the same as a panel passenger seat??? | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | Larry, the burb jump seat has a "pipe' frame that folds/tips forward to allow entry to the rear area - also the burb jump seat is narrower than the panel driver seat and didn't have the solid back that curved around at the hinge point like what you have
Bill | | | | | Joined: Feb 2005 Posts: 531 Shop Shark | | Shop Shark Joined: Feb 2005 Posts: 531 | Thx Bill.. For my Panel... I have two driver's seats and one passenger seat (all needing work)... I was thinking of installing the two driver's seats up front (they have the slide adjustments) and then adding the passenger seat as a third jump seat in back.... but it sounds like a burb jump seat would be better as it has the fold/tip feature vs. just the tip forward of a passenger seat. But as I'm writing this, I'm wondering if the burb pipe frame could be adapted to a panel passenger seat...
BTW, I really appreciate everyone's help and suggestions... going from a 56 pickup to a panel gives me some basic TF knowledge but I'm still learning about Panel stuff....
BTW II... I just realized that I hijacked this thread... My apologies.
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | yes it would work Larry - you could try making your own frame, but finding one might be tough Bill | | | | | Joined: Nov 2011 Posts: 112 Shop Shark | | Shop Shark Joined: Nov 2011 Posts: 112 | Keep up the GREAT work Tim! We(all the burb owners out there) appreciate what you do to help make it easier for us to work on our projects. By all means, keep us posted as you progess on the rest of your seats. Dave | | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | The upholstery shop did confirm the back cushion of the jump seat and both middle cushions upholstery were wrong.I let them make new patterns off of my original cushions.
Jim Carter told the upholstery shop to go ahead and install the upholstery for all my trouble.He's taking care of the bill on it as well,you can't beat that.
I will post photos of the seat cushions soon.
Thanks,Tim 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
| | | | | Joined: Feb 2005 Posts: 531 Shop Shark | | Shop Shark Joined: Feb 2005 Posts: 531 | How're your seats coming along T#im? | | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | I'm hula dancing right now !!!!
Pictures soon !!!!!!!!!!!!!!!!!!!!
| | | | | | OLTrucks Unregistered | | OLTrucks Unregistered | I'm hula dancing right now !!!!
Thanks,Tim Tim Your a nice guy n all and I like ya yeah I do but please no photos of you hula dancin. | | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | Here are couple of pictures of the drivers seat cushions I covered.Probably not perfect like a upholstery shop would do. drivers back cushon drivers lower seat cushion I'll post some more pictures soon. Thanks,Tim 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
| | | | | Joined: Oct 2005 Posts: 4,252 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,252 | | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Nice Tim. Looking forward to seeing it in Kansas...soon. | | | | | Joined: Mar 2007 Posts: 4,215 Moderator | | Moderator Joined: Mar 2007 Posts: 4,215 | Nice Tim. Looking forward to seeing it in Kansas...soon. x 2 | | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
| | | | | Joined: Feb 2008 Posts: 320 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2008 Posts: 320 | | | |
