1 members (Cosmo), 84 guests, and 3 robots.
Topics128,054
Posts1,055,779
#870521 07/29/2012 11:12 PM
Stalls when warmed up and starts again after 5 minutes. I thought it was gunk in the fuel system so have replaced the tank and filter and cleaned everything up. Still the same problem.
It acts like a fuel problem but, I think I have ruled that out.
We think it is a '55 235 engine with Rochester B carb.
Any help is much appreciated.
1951 Chevy 3100 5-Window
"Howard"
More pix on Photobucket
how about the ignition? Do you have spark when it dies? What about fuel pressure?
1953 1 ton panel
1 Offline
Could it be the fuel pump? my 350 had sort of the same symptoms and i replaced the mechanical fuel pump and it fixed it. Not sure if that makes sense for your issue just a thought and something i ran into.
How long do you leave the choke on? I try to get off mine quickly.
I will get a helper and check the fuel delivery on weekend and also check for spark when it dies.
Thanks. At least I know where to start.
"Howard"
You might also take a look at your gas lines in case you have some old "breathing" rubber... It could affect your fuel pump delivery.
It did it again tonight.
The fuel pump and fuel filter were both full. I could hear it getting getting to die - which it did.
I don't think it can be fuel.
So, on to ignition.
I will try another post under "coils".
Thanks for all your advice. This is really getting frustrating!!
Peter
"Howard"
Have you put a fuel pressure gauge in the line at the carb? Just because you have gas doesn't mean you have flow/pressure. The gauges are pretty cheap...about $10. About 6-7 pounds is normal.
Are you sure the needle seat valve isn't sticking closed? The bowl fills up on start up and the valve sticks, engine runs out of gas and dies...
Before you take anything apart run the truck again and when it stalls grab the coil and see if it's HOT...If it's to hot to hold then it's bad.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
It seems like it was the perfect storm.
After sitting for 2 years it appears I had several problems all at once.
Took the carb apart and found the needle value was stuck, rebuilt it and ran much better - for a about 20 minutes.
Replaced the plugs and cap and rotor and noticed a big difference in performance - until I hit 30 minutes.
Replaced the coil and ta-da!
Thanks for all your suggestions. You all were right!!
"Howard"
