1 members (stoveboltgator),
218
0
Mod | | | Forums66 Topics128,048 Posts1,055,540 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2012 Posts: 163 Shop Shark | | Shop Shark Joined: Jul 2012 Posts: 163 | New to this.
removed and cleaned all fuel lines and tank. I do not know if the motor is the 235 or 262.. Do I need to treat the fuel with lead additives or anything else. I figured i would use some stabil since it might be a while before I use the entire tank.
1950 Chevy 3600
| | | | | Joined: Jul 2004 Posts: 2,987 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 2,987 | Stabil is always good. You shouldn't need the lead additive. | | | | | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | For what its worth I fill my tank in the autumn and put the truck away for about 6 months. I run it up to operating temperature about once a month during that time. I have not used Sta-Bil. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Gasoline comes in different formulations in different geographic locations and at different times of the year.
Some of the formulations are less stable than others. It is prudent to use something like Sta-Bil if the gas is not going to be used in two or more months.
Run the engine for at least 10-15 minutes after you have added the Sta-Bil.
| | | | | Joined: Aug 2004 Posts: 1,417 ODSS Lawman | | ODSS Lawman Joined: Aug 2004 Posts: 1,417 | I have read that for folks that do not use their trucks much starting and running it for short period of time is actually worse that letting it sit. The reason being that starting and running it creates condensation internally and without longer running times at increased RPM's it will not allow the draft tube/PCV systems to properly expel the water.
This will allow the condensation to build up in the engine/ exhaust and cause issues over time.
I would recommend Tim's advice and use Stabil then allow a run time of 10-15 minutes to make sure it is in the fuel bowls of your carb(s).
SWEET Sergeant At Arms: Old Dominion Stovebolt Society BUNS?!?!?!Where we're going, we don't need no buns.....1950 GMC 450 1951 Chevy 1/2-TonThe GreenMachineIn the Stovebolt Gallery | | | | | Joined: Jul 2012 Posts: 163 Shop Shark | | Shop Shark Joined: Jul 2012 Posts: 163 | So these engines can use regular pump gas?
1950 Chevy 3600
| | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | So these engines can use regular pump gas? Yes | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | So these engines can use regular pump gas? Yes Agreed. I've read that if all you have available is E10 or E15 you can add gas line anti freeze periodically to prevent phase separation.
| | | | | Joined: Apr 2005 Posts: 1,971 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,971 | So these engines can use regular pump gas? Yes Agreed. I've read that if all you have available is E10 or E15 you can add gas line anti freeze periodically to prevent phase separation. Not sure I'm biting on the seperation part. Someone will have to explain further on that for me. | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | Adding more alcohol(gas line antifreeze) won't help w/ alcohol fuel. Aviation fuel (100LL)has no alcohol in it, keeps forever, costs a little more, but safe.
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Adding more alcohol(gas line antifreeze) won't help w/ alcohol fuel. Aviation fuel (100LL)has no alcohol in it, keeps forever, costs a little more, but safe. I don't know what gas line anti freeze is but it's job is to absorb water in the fuel to prevent freezing in the gas lines. As I stated I've read that it's been successfully used to prevent phase separation. If the poster of that information was wrong I apologize for muddying the water but I've also not seen anything that says it doesn't work either.
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | I believe gas line antifreeze is mostly methanol [with anti-corrosive additives], different critter than ethanol .... to the question, there's no problems using E10 or 15 in stovebolts, not sure you'd want to be using AVgas, even 100LL still has lead additive, which doesn't sound "safe" to me, and any dyed fuel is illegal on the road here [av, marine, or farm gas] Bill | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | This discussion has prompted me to do a bit more research on fuel line anti freeze products. It seems most are isopropal alcohol and work by absorbing a small amount of water, putting it into solution. I expect you're adding more alcohol to allow the fuel solution to absorb a bit more water before it does separate. Looks like more of a bandaid that a long term 'fix' for phase separation. My apologies to anyone I may have mislead.
| | | | | Joined: Oct 2010 Posts: 1,232 'Bolter | | 'Bolter Joined: Oct 2010 Posts: 1,232 | I started using non-ethanol gas about a year ago. What brand of stuff do you recommend to absorb any water remaining in my tank and burn off with the gas? I figure I'll use it every tank full for a while.
The documents in the link implied that "phased" gas (water) could not be reabsorbed.
- Lonnie My '54 3104Photos that I have shared on Stovebolt via PhotoBucket are no longer available. Please contact me if you want a photo from an old post. lonniecook [at] aol [dot] com. I sold my '54 3104 12/12/2017, but I still visit Stovebolt. OLD STUFF ... houses, furniture, cars, wine ... I love it all | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | I believe gas line antifreeze is mostly methanol [with anti-corrosive additives], different critter than ethanol .... to the question, there's no problems using E10 or 15 in stovebolts, not sure you'd want to be using AVgas, even 100LL still has lead additive, which doesn't sound "safe" to me, and any dyed fuel is illegal on the road here [av, marine, or farm gas] Bill 100% agreed. E10 has been around for a long time, some places even had it back when these truck were new.
Bill Burmeister | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | Lonnie - you won't eliminate water from your tank - aside from the condensation you may be picking up from the service station tanks, your vented tank always has ambient humidity [in FLA?] and if the tank is not absolutely full, there will always be condensation happening in there, most of the reason many old tanks are so corroded inside .... best way to maintain gas quality is to use the gas, don't store it - drive the truck  Bill | | | | | Joined: Oct 2010 Posts: 1,232 'Bolter | | 'Bolter Joined: Oct 2010 Posts: 1,232 | That's what my Dad always told me (50 yrs ago) but I sometimes let it sit for a while with a low tank. Let's see - 97% humidity in Central Florida; half tank of gas. 500-1,000 miles a year. I guess I'm breaking all the rules.
Didn't know if some of the snakeoil products would blend the water sitting in the bottom of the tank with gas so that it will burn off.
- Lonnie My '54 3104Photos that I have shared on Stovebolt via PhotoBucket are no longer available. Please contact me if you want a photo from an old post. lonniecook [at] aol [dot] com. I sold my '54 3104 12/12/2017, but I still visit Stovebolt. OLD STUFF ... houses, furniture, cars, wine ... I love it all | | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | In our part of the country we use Iso-heat. It is isopropal alcohol. Anyone who lives in this part of the country knows all about gas line freeze ups. I should take care of you issues also Lonnie. Don | | | | | Joined: Feb 2011 Posts: 583 'Bolter | | 'Bolter Joined: Feb 2011 Posts: 583 | Back in the day when I drove a stovebolt as my daily driver I would sometimes experience carburetor iceup in the venturi. Usually when it was 40-50 degrees outside. If I used the isopropal alcohol it would take care of the problem. The symptoms were pushing the gas pedal further down, and going slower, and slower until the engine quit. The engine heat would melt the ice in about 10-15 minutes. As a rule, I have hardened seats installed on heads of engines that I rebuild because of todays unleaded gasoline.
1939 Chevrolet Stake Truck
| | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | As a rule, I have hardened seats installed on heads of engines that I rebuild because of todays unleaded gasoline. Not necessary unless you work the engine really hard for extended periods. I'd heard of several problems caused by hardened seats coming loose and I've not heard of read of a single problem from not installing them. Personal choice I guess but I've put tens of thousands of miles on pre-unleaded engines, using unleaded fuel with no issues at all.
| | | | | Joined: Apr 2005 Posts: 1,971 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,971 | .....but I've put tens of thousands of miles on pre-unleaded engines, using unleaded fuel with no issues at all. I agree with that Tiny. I believe back that (back when) i ran into that question, it was determined that with normal driving, one would loose 10% of the valve/seat life. Not a big enough reason to just do it because the leaded gas wasn't available in my book. I figured to go through the expense as needed. | | |
