1 members (Ole49GMC), 109 guests, and 0 robots.
Topics128,115
Posts1,056,292
Members48,439
#866691 07/13/2012 4:39 PM
I am converting everything to 12 volt and was wondering what area inside the cab have you guys found to be a good area for mounting?
I mounted mine high on the firewall above and between the clutch pedal and E-brake pedal. Easy to get to from standing outside the truck.
1953 Chevrolet 3600
Fried Green T'mater (Vern)
Caution: Political Statement
...used a mini fuse panel and put it "sort of high" on the inside left firewall. I blew a fuse the other day and it was a LITTLE hard to get to but now bad. This way its out of the way of my big foot!!! Besides, I hope I don't need to change a fuse that often.
I installed mine high on the left kick panel,so if you're setting on the edge of the door it's easy to work on.
Pete
