| | | Forums66 Topics128,026 Posts1,055,399 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2005 Posts: 313 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 313 | I've been having some some problems lately with my 283. It has been misfiring at times, and left me on the side of the road the other day. I have recently installed new points, condenser rotor, distributor cap, coil, spark plugs and spark plug wires, but it is still acting up. I just noticed that the dwell angle is not constant. It ranges from 27 to 30 degrees at idle.
I guess I need to replace the distributor. | | | | | Joined: Feb 2001 Posts: 1,094 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,094 | Doug, The distributor is like anything else mechanical, they do wear out. Try moving the shaft( front/rear, side/side) and see if there is a lot of movement. If so probably need to replace it. There are bronze bushings in the housing that wear over time.
Tommy 59 apache 1/2t 261 short stepside | | | | | Joined: Apr 2005 Posts: 1,971 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,971 | I agree with tommy. Also check the advance weight springs. | | | | | Joined: Apr 2005 Posts: 313 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 313 | I replaced the distributor, and it is running great now. | | |
