| | | Forums66 Topics128,023 Posts1,055,365 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | How is the AD dash attached to the cab? Bolted or welded? Would like to get behind it to rewire the gauges but with it in position its kind of tough. | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | It is spot welded all around the windshield area and inside where it curves by the doors. All of us who have spent any time on these trucks have gone through this. I can make a couple suggestions to make it easier. Work from left to right as you put the parts in so gauges, then speedo, then radio grill, then glovebox. It also can help to remove the shifter and the seat so you can move around better. | | | | | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | Thanks Brad. Everything is in but it needs new wiring in that area. I'll rewire it myself as its pretty simple but being six feet five inches tall makes it difficult. I'll take out the seat and perhaps put a sheet of plywood on the seat riser. How difficult is it to remove the shifter (3 speed - column)? | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | No need on the column shift I meant if it has a floor shift. It will help with the seat out and the plywood because you can lay flat and reach-up. Another tip is get one of those headlamps for your head so you see right where you are looking and free up your hands. Also you can remove the pedals/shafts they are only held on with a bolt each. | | | | | Joined: Oct 2007 Posts: 63 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2007 Posts: 63 | dissamble all the electrical parts from the dash , place them on the bench and wire it. then transfer loom back into the cab . wiring going to engine and rear lights can be terminated in a plug then continue with the rest of the truck. makes life easier cost 2 or 3 plugs and no sore back. chers andrew | | |
