9 members (ranchojuan, jkreiner, fonz8261, TexasJim50, rfs56trk, Forty9, Bill Hanlon, treegrower, Wally / Montana),
55
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,074 Posts1,055,914 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2010 Posts: 378 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 378 | OK folks I'm going to try to put this as best as I can. I have removed the forward part of my 1949 enclosed drive (truck) rear end. The Torque Tube and the gears inside are completely gone. I also removed the rear end cover plate. Now I have in the truck an original housing with nothing in it. Had to pull the axles to remove the Torque Tube assembly. I read where a 1955-1962 (car or truck, I don't know which) third member or as some say a pumpkin would fit the original housing. This way you do not have to turn the springs around,weld tabs on or anything else. Just bolt the later model third member in, replace the original axles, put the cover on and add the oil and go. My question is #1-Is this possible? #2-Which rear-end do you use, a car or a truck. #3-What angle do you set on the pinion, providing this is possible? I know #3 is an estimate but close will be a starting place. I was asked to post this because it has not been addressed properly, so I'm told. If you have done this swap please post a reply on this so we Stovebolters can get it down for all the future Bolters. Thank you so much from me and future Bolters. If this is possible it would make an easy and fast way to go to open drive system. Thank you for all replys. Steven (Red 49 Truck) | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Its been discussed but I have not did a search to see if I can find that thread. Yes, you can make the change. I used a 55/56 pumpkin (truck) to replace the torque tube in my 52 panel. Like you said. Pull the axles, take the torque tube out an install the pumpkin, put the axles back in. The original is probably a 4:11 ratio. The pumpkin I got is a 3:90 ratio, not the best but better. I have heard that SOME 60's had a little higher gear but don't really know what they came in.
You will have to weld the "swivels" so that they do not flex up and down like the original.....or do some other way. I personally cut the old stuff off and slid perch blockd under the original rear end housing and made me a bottom U-bolt plate and used U-bolts. I set my pinion angle at 2deg. negative with the vehicle sitting on the floor with the weight on it. Once its set then weld the perch blocks to the housing. If you do a search I'm sure you'll find plenty to read about setting pinion angle but don't let it scare you. Its no big deal. Note, if you made your "U-bolt plate" its agood time to weld the shock bracket to the inside of the backing plate. The original shock mount was between the spring and inside the tire. I didn't like that and welded a stud to the u-bolt plate. Don't have to worry about it ever rubbing the tire. You may also have to weld a piece to the chassis to fasten the top end of the shock. IF you just weld up the swivels you wont' have to worry about this. Also be sure you get the rearend centered side do side which I'm sure you know to do.
Since you have an open drive shaft do know you'll have to change the tranny so you can hook up the driveshaft?...or are you using a V8?
...also, if your changing wheel size from a 16" to say a modern 15" rim you may want to move the rear end forward or backward to get it sitting in the fender well like you want it. Much has been said about flipping the springs around to move the rear end back about an inch or inch and half since the center spring eye bolt is not exactly in the center.....or makes sure you use the perch blocks from the dodge dealer which has three holes in the bottom of it....a center hole and one more on each side about 1 1/2" toward front or back! While the pumpkin change is quite simply there are some little things to think about but don't let them overwhelm you. You do what works for YOU. Good luck.
Hope this helps and I'm sure others will chip in along the way. Just remember, measure twice-cut once!!
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | The 3rd member you would need would the '55-'62 Truck, the Passenger 3rd member is much smaller and has a different shape. The standard (and most common) gear ratio is 3.90, with options for a 4.10 (usually with overdrive) and 3.38 (Hydramatic).
Bill Burmeister | | | | | Joined: Jan 2010 Posts: 378 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 378 | Thanks for the replys. Anyone else just put your opinion in and we should get something good going on here. Achipmuck, I rebuilt a 4-speed SM-420 a while back and it was ready to go far as the open drive is concerned. When, I say when, I find a third member I will probably just see how the Lever shocks work. If they don't please me I've got a 1951 and a 1954 parts truck. I think I will be able to use one or both of those to rob the shock plates from I hope. I think I'll measure, plumb bob, level and what ever else about three or 4 times before I weld anything in place. Longbox55, I hope I can do a little better than 3.90 but time will tell. 3.50's would be nice. I'm going to have to get another digital camera so I can post some pictures. You know what they say, "A picture is worth a thousand words." Thanks to you both. Steven
Oh,I just changed out a 1956 Hyd. lifter 235 for a 1955 solid lifter engine so for now I'll stay with this "Blue Flame 235" As far as the camera goes, when I get the money I'll get another one. Disablity pay ain't much. I know a bunch of you know what I mean! | | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | Are the 3.38 rear gears from the 55-62 trucks with the hydromatics hard to find?
Dennis -there is nothing stronger than the heart of a volunteer-
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | hydramatic trucks are hard to find, but the 3.38 gearsets to fit in the 55-62 rear are available from Patricks
Bill | | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | Probably best use of time and money to with Patrick's. But It is good to check out all possibilities.
| | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | The 1955-1962 truck 3:38 gear set can be bought from any reputable gear vendor. Randys Ring & PinionTim 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Nice link Tim. Thanks. I may want to put a 3:38 in the old panel one day since I have a 56 pumpkin in it. Just never know! | | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | Right now I have the 53 pumpkin with torque tube. Your site is no good for me. Thanks though
| | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | You asked this question, "Are the 3.38 rear gears from the 55-62 trucks with the hydromatics hard to find?". The link is good for the question you asked.
| | | | | Joined: Sep 2009 Posts: 27 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2009 Posts: 27 | I have a '50 3600. If I ordered a ring and pinion set from Randy's, is it a 30 or 35 spline? | | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | The link I provided is for a ring and pinion to fit a 1955-1962 1/2 ton pumpkin.It will not interchange with your original 3rd member.If you have the 55-62 pumpkin you can do the conversion.
Patricks has a 3:55 ring and pinion that might work for you.You need to call them at 520-836-1117 .
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | I have a '50 3600. If I ordered a ring and pinion set from Randy's, is it a 30 or 35 spline? That one will not work, nor will the 3.55 gearset, as they re both for 1/2 ton.
Bill Burmeister | | | | | Joined: Jan 2010 Posts: 378 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 378 | Hello Longbox. I was wondering if you might know where I can locate some pictures of rearend carriers so I might can date my carrier. It is a 3:90 ratio and I'm going to put it in my truck using the 49' housing. Thanks a bunch. I've ask a couple of other people so maybe if you don't know someone else might chime in. Thanks , Steven Red 49 Truck | | | | | Joined: Oct 2009 Posts: 127 'Bolter | | 'Bolter Joined: Oct 2009 Posts: 127 | Hi all - does anyone have some info on how to definitely ID a 3:90 rear end? I have this torque tube from a 1954 that I think should be a 3:90 that I want to swap, but need to confirm. Does this number "309" and the clock-like marking mean anything? [image] http://i1310.photobucket.com/albums...0f9c816858c_zps9b1e5e6b.jpg?t=1388517486[/image] Hello Longbox. I was wondering if you might know where I can locate some pictures of rearend carriers so I might can date my carrier. It is a 3:90 ratio and I'm going to put it in my truck using the 49' housing. Thanks a bunch. I've ask a couple of other people so maybe if you don't know someone else might chime in. Thanks , Steven Red 49 Truck
52 3100 project 54 3100 / 3112 ice cream truck, next project
| | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | Right now and for about 15 years I've been running a 1965 Chev pickup 3:08 ratio(6 lug) rear end under my 46, was a gift from a very good friend. The BIG plus for going this route is that there are many other ratios to choose from for these and not all that hard to find. Best of luck Jim | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 |
| | | | | Joined: Oct 2009 Posts: 127 'Bolter | | 'Bolter Joined: Oct 2009 Posts: 127 | Thanks - but is there a way to tell a 4:11 from a 3:90 half-ton rear end? Does this casting number "309" and the clock-like marking mean anything? [image] http://i1310.photobucket.com/albums...0f9c816858c_zps9b1e5e6b.jpg?t=1388517486[/image] if not, are there markings on the gears?
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Sorry, I posted the wrong link. Check the link above, again. There should be a code on the rear end that you can use.
| | | | | Joined: Oct 2009 Posts: 127 'Bolter | | 'Bolter Joined: Oct 2009 Posts: 127 | Thanks, according to the diagram, it looks like the 309 is a month and date. I checked for a number on the other side, and found this:
3698954 D2
This doesnt match the "MU" code for a 54 3100 on the chart- anybody have an idea what D2 means?
| | | | | Joined: Feb 2001 Posts: 1,094 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,094 | Take the back cover off of the rearend housing and look at the back of the pinion gear.A number will be stamped on the gear, that will tell you what ratio it is.
Tommy 59 apache 1/2t 261 short stepside | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Tommy,
What would be the code on torque-tube 3.90 pinion gear and the code on torque-tube 4.11 pinion gear?
| | | | | Joined: Oct 2009 Posts: 127 'Bolter | | 'Bolter Joined: Oct 2009 Posts: 127 | Ok, I opened it up and the back of the pinion says 39 - 10. Also, counted 39 teeth on the ring gear and 10 on the pinion.
| | | | | Joined: Feb 2001 Posts: 1,094 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,094 | simple math 3.90 gear.
Tim, I don't know about any codes on the torque tube rears. Just all the years I've been fooling with cars/trucks, was always told you could divide one number into the oether and come up with the ratio. Kind of like jacking up one side of the car and turning the wheel to see how many times the driveshaft turns.
Tommy 59 apache 1/2t 261 short stepside | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Yes, I know that, Tommy I am pretty good at math.
I was wondering about the number stamped on the 4.11 and 3.90 pinion gears: "Take the back cover off of the rearend housing and look at the back of the pinion gear.A number will be stamped on the gear, that will tell you what ratio it is."
| | | | | Joined: Feb 2001 Posts: 1,094 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,094 | Tim,
I guess the code you are looking for would be the numbers Wurlitzer46 found 39-10 for the 3.90 and 40-11 ? for the 4.11.
I Haven't taken a rearend apart in years, I always remember the numbers being stamped on the rear face of the pinion gear as being the ratio.
If Chevy had a different number stamped for a stock code I'm not familiar with that. All of the aftermarket gear companies had them stamped on the rear face of the pinion gear.
I wasn't trying to be a smart--- with the "simple math"thing. maybe it came across wrong, sorry if it offended you, didn't mean it that way.
Tommy 59 apache 1/2t 261 short stepside | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | I think I have both a 4.11 and a 3.90 pinion gear, but I will not be back in my cold and snowy home until 3 January. I'll try to remember to look at the pinions when I get home.
Does anyone know what, if anything, is on the 3.55 conversion pinion gear?
Happy New Year
| | | | | Joined: Oct 2009 Posts: 127 'Bolter | | 'Bolter Joined: Oct 2009 Posts: 127 | Hi All For the record the pinion gear from the 1954 1/2 ton says this: 54 3697703 10 39 GM
10 teeth on the pinion, 39 teeth on the ring, 3:90
| | | | | Joined: Jun 2010 Posts: 298 'Bolter | | 'Bolter Joined: Jun 2010 Posts: 298 | I have a set of 3:55 gears for sale New never used with carrier Give me a call 313-995-2768 | | | | | Joined: Aug 2004 Posts: 1,418 ODSS Lawman | | ODSS Lawman Joined: Aug 2004 Posts: 1,418 | Please post items of sale in the swap meet.
SWEET Sergeant At Arms: Old Dominion Stovebolt Society BUNS?!?!?!Where we're going, we don't need no buns.....1950 GMC 450 1951 Chevy 1/2-TonThe GreenMachineIn the Stovebolt Gallery | | |
