6 members (artinva, Otto Skorzeny, Gdads51, 1955 1 Series, tesa, JW51), 69 guests, and 1 robot.
Topics128,077
Posts1,055,932
Members48,430
#859335 06/15/2012 2:33 PM
After removing the rear hubs, restoring them and then pressing new wheel studs back in my '54 1 ton stake, they now are just off a little bit so I can't get the brake drums back on. I removed the hubs, ran them through the press again but no differance. Any thoughts on how to get these extra long dualie studs squared properly so I can continue to get frustrated by something else?
Bruce
My Trucks
Stuff I Collect
...could you possibly be dealing with Metric replacements???
Just a thought. ( I ran into this some time ago)
Put a nut on the studs and give them a soft side whack with a sledge. It happens from time to time, unfortunately you need to whack, test, whack, test, etc., until they fit right.
Jeff
My 1953 Chevrolet
1947.1 Gallery
is it enough force to put a nut on and tighten it down? face of nut draws it square?
Not metric, I had the tires on to roll it around a few weeks ago. The wheels went on somewhat hard but did go on. I tried the nut on the stud to hopefully draw them in straight but alas, no luck. My shop press read 7 tons when I set them last time. I thought about whacking them but not sure how to keep the hub from rotating while attempting this. I'm sure GM had some fantastic jig to get this done in two seconds.
Bruce
My Trucks
Stuff I Collect
Don't whack 'em- - - - -use a long piece of pipe just big enough to fit over the stud, (probably 1/2") and gently pry the stud whatever direction it needs to go. You'll have better control over the movement than you will if you hammer on the stud.
Go to the flaps or hardware store and get two nuts that are bigger than the thread size of the stud,so they slide over the stud.Take one of the lug nuts and put it on backwards than tightin it down it should pull it in straight.
Pete
Pete
Nope, didn't work. I'll try the pipe idea today, I think that might work.
Bruce
My Trucks
Stuff I Collect
If you flatten the threads a little with the pipe, run a chaser die on the thread to bring it back into shape.
Just throwin' this out: instead of prying on the threads, how about if you put on a few nuts, then size your pipe to fit over the nut flats. Now you'll be prying against the nuts and not the threads. I'd think the nuts would protect the thread form.
You could always get some bolts for mismatched holes. (Scroll to bottom to view.)
Tightening a nut on the stud to straighten it will strip the threads of the nut or stud before it does what you want.
Place the nut on the stud and TAP, repeat TAP, with a 10 pound hammer. Don't wack it. Small taps is all it takes and keep checking for fit. It will move ever so slightly and you won't damage anything.
My Fleet:
1941
1953
1959
1965
1966
1953 Willy's Pickup
Jerry gets the first ride for his suggestion!!! I took a four foot piece of square stock just over 1/2" and tweeked them till they fit. It took a little bit of fussing but they now go on.
Thanks for all the suggestions
Bruce
My Trucks
Stuff I Collect
