| | | Forums66 Topics128,035 Posts1,055,443 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2000 Posts: 591 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 591 | I'm finally getting close to completing my 1957 Chevy NAPCO long bed. I'm considering chrome bed steps. However, I haven't seen many trucks with them. I was wondering: 1. Opinions: do they look good or do they come across as over the top? 2. Are they of decent quality from the various vendors?
Thanks, don. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | my opinion: look goofy ... quality of most repro chrome: poor ... both contributing to why you don't see many  Bill | | | | | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | I would not use chrome. Aluminum step plates are available.
| | | | | Joined: Jan 2000 Posts: 591 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 591 | Tim,I like the idea of aluminum. I haven't seen them before, do you know of a source? Thanks, don | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | Tim is talking about step plates to prevent scratching paint, not full steps Bill | | | | | Joined: Mar 2011 Posts: 457 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 457 | Yep, less is more. Took the off the aluminum plates that were on my truck when I bought it.
1940 Chevy 1/2 ton pickup "KC" A day without sunshine is like, well, ..... dark! | | | | | Joined: Jan 2000 Posts: 591 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 591 | Thanks Bill, I read that too fast. I'm leaning toward keeping the original bed steps (they have been painted body color). I may paint the tread portion with another more durable finish, or go to the aluminum step plate. However, I see that 40casey still finds that a bit much. I have never seen them installed, so I am considering 40casey's comment carefully. | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | ...here on the bolt not to long ago a bolter posted a pic of his "step plates" which were aluminum "boiler plate" type. He had rounded the corners and put them on his running boards. I thought they looked pretty nice and could be glued to the ridges on the running boards with out putting holes in everything. I'd like to see the pics again but can't find them and didn't save them. I liked them vs the ones that have the back edge sticking up......and the aluminum can be gotten without the "diamond" shapes on it. Just thinking........ which gets me in trouble. | | |
