Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
5 members (55shaker, Otto Skorzeny, Greg_H, baldeagle, TUTS 59), 32 guests, and 0 robots.
Topics128,004
Posts1,055,246
Members48,418
#858304 06/12/2012 1:06 AM
Fellow Brothers;
Just a safety note here. The lawn tractor was running rough and the problem was traced down to dry rotted fuel hose (10 years old). I replaced it with GATES barrier fuel hose (more expensive than regular fuel hose). So you might want to crawl round the truck the next time you are doing an oil change and check your fuel lines, as I did 2 weeks ago when I was getting the '55 Pontiac ready for a show, and low and behold, the line that I had replaced 10 years ago from the fuel tank to the hard line was cracked. A fire waiting to happen.
John G
1942 G5106 1.5-ton Chevy cargo dump Gallery page
Old Dominion Stovebolt Society
T/Sgt. Gott (28 years of service with the USPP)
1940 Chevy G506 4112 cargo dump
1942 Diamond T G509 969A 4 ton wrecker
1942 Ward LaFrance G116 series 2 10 ton wrecker
1944 Ward LaFrance G116 series 5 10 ton wrecker
1931 Ford AA with a WEAVER crane
1944 Sterling HC 165 tractor
1944 Autocar U7144T w/ 10 ton trailer
J Gott #858366 06/12/2012 4:21 AM
John,
I just had the same expereince with my fire engine. I found by accident a flex gas line I replaced about 8 years ago all dried out and cracking.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Mike B #858373 06/12/2012 4:48 AM
And how do you know this is ethanol related?
1948 Chevy 1/2-Ton
"Tuesdays with Morris"
In the Legacy Gallery
Find it - Fix it - Drive it
Tom R #858374 06/12/2012 5:01 AM
in australia they wont let you put ethanol based fuels in boats cause it plays up with fuel lines cars any different i wonder ?
TPR57C #858377 06/12/2012 5:24 AM
ethanol doesn't cause 'dry rot' or cracking, those are age and temperature related problems [maybe limited to the "Old Dominion"? grin ] - if anything it will soften some older formulations of rubber, causing the inside of tubing to gum up and feed junk into the system until things plug up, but I've been using E10 for the 15+ years my 58 has been a daily driver and it hasn't affected the rubber fuel lines on it, which were old when I got it
Flxible #858403 06/12/2012 11:53 AM
Back in 2002, John Sawruk (Pontiac drivetrain engineer) gave a tech talk at a Pontiac national show about the effects of ethonal on rubber fuel lines and to change out your rubber fuel lines to ethonal compatible (barrier hose) as the alcohol will "attack" the rubber. I got home from the show, I checked the car, which had the lines on for 5 years, they were cracked so I changed them out. On my 55 Pontiac, it is stored in a climate controlled garage and is driven about 150 miles a year and the fuel is treated with stabilazer.
As a test, pure some E10 into a mason jar,put the top back on and after about 2-3 weeks you will see the alcohol seperate from the fuel, over a longer time you will see 3 distinct layers, fuel, alcohol and water.
John G
J Gott #858469 06/12/2012 5:13 PM
I'm with Bill on this, all I can get is ethanol here, and it's no trouble. It's nice not to worry about tank condensation, and gas lines freezing. In fact, I don't think I've ever had a tank of plain gas in any of my old cars.
Perhaps we've had ethanol for so long up here (and before that, added it to prevent freeze up) that our rubber is different than in the states?
Christopher
1950 1-Ton
"Rochester"
In the DITY Gallery
1949 GMC Panel Truck
1926 Model TT Truck
J Gott #858476 06/12/2012 5:47 PM
The effect of ethanol on fuel lines and the need for ethanol compatible lines is when you're talking about E-85, where it's a higher concentration. When it's E-10, don't worry about it.
My 46 GMC on Photobucket
46gmcpu #858478 06/12/2012 6:14 PM
Don't hold your breath that the barrier hose is much better. I used the barrier hose on my pickup about two months ago. Had to pull one off to do a repair and the inside is black and gooey.
Don't fool yourself about E10 being okay for these old trucks. You've just been very fortunate if you have not had a problem.
Mike B #859213 06/15/2012 2:43 AM
at least if you had a fire you were in a fire truck
brokenhead #859243 06/15/2012 3:38 AM
my two cent/experience. I've ran the same rubber lines on my 37 since about 98/99. No problem. I do make sure to check and NOT put any E-85 in the tank but other than that I have no problems and I have let the truck set for extended periods over the years.
I might add, or ask, if the fuel lines you buy are "marked" that is suppose to be "ok with E-85"??? I suspect some consumers may be buying hose, or some old stock hose, thinking they're getting the "improved stuff".... .and the parts guy don't know the difference.
Just saying........
