1 members (Hotrod Lincoln),
95
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,049 Posts1,055,677 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2011 Posts: 71 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2011 Posts: 71 | Hi guys,
I am just finishing rebuilding a 56 235 for my 59 3100, and I need an exhaust recommendation. It will have a stock intake and exhaust, with a Patrick's 264 cam. Can anyone suggest a pipe diameter and muffler? I would like to get the most out of the cam, with maybe a little louder exhaust, but still be able to hold a conversation in the cab.
I don't want dual mainly due to the cost of the manifolds/piping. Double the pipes=double the cost.
Thanks, Vince | | | | | Joined: Feb 2000 Posts: 5,200 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,200 | 2" will be plenty of pipe for your engine. Stay away from the hollow mufflers like Flowmaster. I like the DynoMax brand, they flow good and have a deep rumble to them. A straight through muffler will be pretty load and rap a lot. Use 2" tail pipe and you will be happy. If you like the sound of noisy 6 cylinder, go with 1 3/4" pipe with the muffler right up under the cab and the longest tail pipe you can get, your neighbors will love you!
Joe | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | I agree with Joe's assement totally. On my panel,because of the gas tank and spare tire location I put a single exhaust on it. I am running a 305 engine but still used a 2" single exhaust and it breathes good. I did not use a Flowmaster but did put a "soundmaster" on it which is the about the same thing but a lot less expensive. It has a deep throaty sound but still not to loud even with the V8. I think your making a wise choice for your vehicle. | | |
