Brrrr
place holder
0 members (), 187 guests, and 0 robots.
Topics128,274
Posts1,058,425
Members48,489
On my 46 216 1/2 the clutch always slipped since purchased a couple of years ago. I thought it was just age. I have to change the rear freeze plug so I bought a clutch assembly also. I pulled all the needed stuff and used a tranny lift from Harbor Freight. I got the pressure plate off and the clutch disk came out but someone installed it backwards. The shoulder to the input shaft was pointed to the torque tube and the flush part of the disk to the flywheel. Well this doesn't let the disk seat firmly to the flywheel. The flywheel bolts were slightly ground down and the springs circling the clutch disk were ground also. I could always hear a rattle sound when I depressed the clutch so this must have been the disk scraping against the flywheel bolts. Gee I wonder what it sounded like just after the install.
Rick.....
probably the wrong parts because it was installed correctly. Look closely at the disc, some manufacturers label the discs "flywheel" side,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
In most cases, if the springs hit the bolts, the flywheel has been turned past it's minimum thickness.
My Blog
It was backwards, the hub with the springs in it fits back into the pressure plate.
Evan
HI,
The clutch disc or fiction place hub should face the rear of the truck.
It could be that someone previously installed the wrong clutch disc. In some of the early clutches that I have replaced there are no springs on the clutch disc.
The newer style heavy duty clutch discs have the springs mounted in the center of the clutch disc to reduce torque surge.
You may need to change the clutch disc to the older style without the springs.
The clutch disc hub faces the rear of the truck.
Also, as stated above some one may have taken to much material off the flywheel face when resurfacing it.
Hope this helps...
GMCPic
Dance like no one is watching,
Sing like no one is listening,
Love like you've never been hurt.
1948 GMC FC101 1/2t Pickup w/270 and SM420
1948 GMC FC253 1t Factory 80"x9' Flatbed Dually
1948 Chevy COE 2 Ton 8'x15' Flatbed
1950 GMC 354-24 2 Ton 8'X12' Flatbed w/Dump Hoist
1953 GMC 454-30 3 Ton 8'x14' Flatbed w/Dump Hoist
1953 GMC 454-30 3 Ton Cab and Chassis
1942 Clarkator 6 MILL-44 Heavy Aircraft Tug
1942 Ford (9N) Moto Tug with 1/2 yard Loader
1947 Oliver OC3 HG-42 Tract-Crawler Bull Dozier w/6' Blade
