| | | Forums66 Topics128,271 Posts1,058,415 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2008 Posts: 217 Shop Shark | | Shop Shark Joined: Feb 2008 Posts: 217 | On my 46 216 1/2 the clutch always slipped since purchased a couple of years ago. I thought it was just age. I have to change the rear freeze plug so I bought a clutch assembly also. I pulled all the needed stuff and used a tranny lift from Harbor Freight. I got the pressure plate off and the clutch disk came out but someone installed it backwards. The shoulder to the input shaft was pointed to the torque tube and the flush part of the disk to the flywheel. Well this doesn't let the disk seat firmly to the flywheel. The flywheel bolts were slightly ground down and the springs circling the clutch disk were ground also. I could always hear a rattle sound when I depressed the clutch so this must have been the disk scraping against the flywheel bolts. Gee I wonder what it sounded like just after the install.
Rick..... | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | probably the wrong parts because it was installed correctly. Look closely at the disc, some manufacturers label the discs "flywheel" side, Scott | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | In most cases, if the springs hit the bolts, the flywheel has been turned past it's minimum thickness.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | It was backwards, the hub with the springs in it fits back into the pressure plate.
Evan
| | | | | Joined: Apr 2001 Posts: 268 Shop Shark | | Shop Shark Joined: Apr 2001 Posts: 268 | HI,
The clutch disc or fiction place hub should face the rear of the truck.
It could be that someone previously installed the wrong clutch disc. In some of the early clutches that I have replaced there are no springs on the clutch disc.
The newer style heavy duty clutch discs have the springs mounted in the center of the clutch disc to reduce torque surge.
You may need to change the clutch disc to the older style without the springs.
The clutch disc hub faces the rear of the truck.
Also, as stated above some one may have taken to much material off the flywheel face when resurfacing it.
Hope this helps...
GMCPic
Dance like no one is watching, Sing like no one is listening, Love like you've never been hurt.
1948 GMC FC101 1/2t Pickup w/270 and SM420 1948 GMC FC253 1t Factory 80"x9' Flatbed Dually 1948 Chevy COE 2 Ton 8'x15' Flatbed 1950 GMC 354-24 2 Ton 8'X12' Flatbed w/Dump Hoist 1953 GMC 454-30 3 Ton 8'x14' Flatbed w/Dump Hoist 1953 GMC 454-30 3 Ton Cab and Chassis 1942 Clarkator 6 MILL-44 Heavy Aircraft Tug 1942 Ford (9N) Moto Tug with 1/2 yard Loader 1947 Oliver OC3 HG-42 Tract-Crawler Bull Dozier w/6' Blade
