1 members (Hanks custodian),
103
10
Mod | | | Forums66 Topics128,014 Posts1,055,324 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2010 Posts: 135 'Bolter | | 'Bolter Joined: Jun 2010 Posts: 135 | Looking for a floor jack to use on my 1964 K10. Since the truck is a 4x4 it is higher than most trucks. I want to be sure I get a jack that will give me enough lift. The truck is 3/4 ton. Any recommendations? Thanks John
1964 K10 Fleetside Pickup Truck | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | I'm sure your looking for a jack with the most lift so I'd check around. Maybe catch a good one on sale....but be prepared to pay a few extra bucks for a GOOD ONE. Also, save your receipt till the warrante runs out on any jack.
Also, since you will probably be jacking up other vehicles you may want to watch the "profile" meaning how "low" it is in case you want to use it under a low vehicle.
Good luck. Let us know what you pick..and I'd go at least for a 2 1/2 ton if not a three! | | | | | Joined: Jun 2008 Posts: 1,644 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 1,644 | Costco sells a low-profile 4 ton jack for $95. Bought it last year and it's a high quality jack with dual cylinders, powdercoat paint, and nice casters. It's heavy!! You won't find a nicer one for the money.
Chuck 1950 Chevy 1/2 ton (all original) 1951 Chevy 1/2 ton (future streetrod) 1941 Chevy coupe 1938 Chevy coupe streetrod | | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | You didn't say if it was to carry in the truck or to be used in your shop and on what surface.
Chipmunk has a good point about using it on other vehicles.
I have a 3 ton steel floorjack and it's very heavy. I'd get an aluminum jack for general purpose in the shop next time. I like scissor jacks for light duty use to carry with me but bottle jacks are good if you don't mind crawling under the truck. So how you use it is key to figuring out what is best. | | | | | Joined: Oct 2006 Posts: 289 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 289 | see this thread. BTW, my Jet jack is still working fine and sees a fair amount of use from time to time. Threard on car jacks | | |
