| | | Forums66 Topics128,201 Posts1,057,281 Members48,467 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2010 Posts: 301 'Bolter | | 'Bolter Joined: Jun 2010 Posts: 301 | I picked up a Dana 60 from a 69' F250 with 3.73's. I have it bolted up using it's spring perches but the diff has a slight up angle to it on the driveshaft end. Will this be a problem? Or do I need to modify the spring perches and get the diff driveline to set level. It's on a 49' 3600.
1949 Chevy 3600 1975 W-25 Hurst Olds 1970 GMC 1/2 ton Fleetside 2010 Chevy Silverado
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | I copied this from another web site, but driveline angle is what is important here. Ideally, the operating angles on each end of the driveshaft should be equal to or within 1 degree of each other, have a 3 degree maximum operating angle and have at least 1/2 of a degree continuous operating angle.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Feb 2003 Posts: 452 Shop Shark | | Shop Shark Joined: Feb 2003 Posts: 452 | It sounds like the truck it came from had the engine/transmission mounted tail-low. Some hi-perf guys will mount their rears a little 'down' from parallel with the trans so that they will get closer to parallel when high torque is applied to the rear and the axle twists slightly upwards. probably best in the long run to re-do the perches so the rear matches the rest of the driveline. Your u-joints will thank you and last much longer.
Current fleet (subject to change w/o notice) \'49 GMC 3/4-Ton , 60 Austin Healey Frog-eye Sprite (some assembly required), 2011 Dodge Avenger, 2015 Jeep Cherokee. No, they don't all run. My other ride is a (B737)no, (B767)no, A320.... Update... was Embraer E190, now Boeing B787. Knowledge is a wonderful thing, but ignorance means you don't know you can't do something.
| | | | | Joined: Mar 2008 Posts: 1,775 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 1,775 | If I'm not mistaken, I once read that Ford used to offset their diff's more to the side and had a pretty much straight on pinion angle. | | | | | Joined: Jun 2010 Posts: 301 'Bolter | | 'Bolter Joined: Jun 2010 Posts: 301 | All brake hardware installed. I have to work up connecting the parking brake cables but it doesn't look like it will be a problem. The drums are out getting turned and the driveshaft is at the shop getting shortened as well as the rear yoke being swapped to match the Dana 60 pinion yoke and new u joints front and rear. Patience.....patience......eager to put her all back together....
| | | | | Joined: Jul 2008 Posts: 149 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2008 Posts: 149 | I put a dana 60 in my 53 3600/3/4 ton, and have got vibration in it. cant seem to get it out. one guy looked at it and thinks its pointing up to much, any ideas. other than that had no problem any idea's | | | | | Joined: Jun 2010 Posts: 301 'Bolter | | 'Bolter Joined: Jun 2010 Posts: 301 | I haven't finished it up yet but are you sure your drive shaft is balanced ok?
| | | | | Joined: Jul 2008 Posts: 149 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2008 Posts: 149 | driveshaft balanced. i did notice that the dana 60 is not centered to the line up hole on the chassis, the rear end is over to the right. will the ujoints compensate ? | | | | | Joined: Jun 2010 Posts: 301 'Bolter | | 'Bolter Joined: Jun 2010 Posts: 301 | Mine is just offset to the right a little too. I'm banking the u joints will compensate. I did modify the spring perches so the diff. driveline has a slight down angle to compensate for wrap up. Just got it bolted on yesterday but I can only drive it around the farm for now as it will be a while before it can hit the roads. I still need to finish up the brake lines and parking break cables.
| | | | | Joined: Oct 2007 Posts: 725 Shop Shark | | Shop Shark Joined: Oct 2007 Posts: 725 | Great thread! Please keep this one updated! | | | | | Joined: Jun 2010 Posts: 301 'Bolter | | 'Bolter Joined: Jun 2010 Posts: 301 | Well, I have the brakes done and took her up to 40 mile an hour before I ran out of driveway on the farm. No vibrations and runs up nicely. I can definately tell a difference. All in all it looks like this whole thing will be pulled off for under $400. It will be next year most likely before I can take her on the open road unless I make huge strides on the restoration process this summer.
