| | | Forums66 Topics128,191 Posts1,057,362 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2006 Posts: 335 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 335 | What a ride! No plates, no inspection. Adjusted clutch, started truck (forgot to adjust clutch rod under dash. Good thing it stalled before putting a new door in rear of garage! So happy my rebuilt power steering works excellent. Out on the road wind in my hair, hhmmm something smells like it's burning, must be residue on pipes etc. Pull into friends house and combination smoke and steam fills cab. Jump out and open hood and pull off battery cable. Forgot to tighten valve cover, well oiled hood hinges! Radiator screaming, must have had an air gap when filling coolant. Fill coolant try to start truck, out of gas (gauge a little off). Get ride to station for gas, pour it in and crank it up. More wind in hair. Shift from second to third and shifter comes out of tranny and falls on floor! Jamb it back in and make it back to house and a few stiff drinks. This restoration stuff is such fun!! | | | | | Joined: Mar 2007 Posts: 4,217 Moderator | | Moderator Joined: Mar 2007 Posts: 4,217 | The first ride is always good, even when it's bad. It gats you motivated as well, glad you are at that point. Good luck with the small stuff.
Leo | | | | | Joined: Mar 2003 Posts: 1,132 Shop Shark | | Shop Shark Joined: Mar 2003 Posts: 1,132 | DThela, Hang in there it gets better.
Weeds | | | | | Joined: Aug 2011 Posts: 687 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 687 | | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | HEHEHE, but just think of the MEMORIES and the stories you will be telling for years to come  | | | | | Joined: Jun 2008 Posts: 1,388 Shop Shark | | Shop Shark Joined: Jun 2008 Posts: 1,388 | That's great! That first ride is a blast for sure. | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | It's not a ride, it's an adventure. | | | | | Joined: May 2007 Posts: 321 Shop Shark | | Shop Shark Joined: May 2007 Posts: 321 | Awesome. I now have 500 miles on my 49 and am still working out the bugs. I just blew a lower rad hose pin hole leak. One of Jim Carter's. Anyway called Lisa and she sent me a new one for shipping cost. Still many small things to work through, just enjoy it and be thankful its not your only mode of transportation. :-) | | | | | Joined: Jan 2007 Posts: 219 'Bolter | | 'Bolter Joined: Jan 2007 Posts: 219 | Congratulations Mr. DThela sounds like you are having a great time. Any day now i will be taking my 54 panel out for the first time in 35 years. I will be sure now to take a second look at things. Good luck with it Len
layback
| | | | | Joined: Feb 2008 Posts: 320 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2008 Posts: 320 | I think we all have similar stories to tell about the first day out in our trucks. For myself, my first trip out the new coil was defective and left me in the middle of a busy intersection. Fixed that, then like pplummer, my new radiator hose from JC also had a pin hole, then etc.. but now I'm working on a shortlist of bugs I've found as I drive it. Now have 1300 miles, moxt of which have been uneventful. | | | | | Joined: Feb 2011 Posts: 14 New Guy | | New Guy Joined: Feb 2011 Posts: 14 | That story just made my day. Adds fire under my own butt to get mine up and going (neighbors are well aware and already warned I may end up in their backyard on first driving attempt)
If the shortcut actully worked it would be called "the way"
| | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | wheres the pictures of it out of the garage ?  1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
