4 members (cmayna, 52Carl, CATMAN, J Lucas), 126 guests, and 2 robots.
Topics128,195
Posts1,057,380
Members48,471
Page 64 of 177 1 2 … 62 63 64 65 66 … 176 177
Finally got the rear and front ends out, springs off. Air tools and heat wrench essential equipment!!! Almost ready for the sand blaster.
back yard wrench turner
W Online: Content
made my 1st drive around the block today. click
The truck has plenty of power, brakes work very good, shifts fine, however the steering is still 1938.
click
Wayne
1938 1-Ton Farm Truck
Stovebolt Gallery Forums
1989 Silverado
1996 Mustang GT convertible
Looking good Wayne. A fun project
David Gilmore
Stovebolt Pictures
Paint progress
____________________________
1950 Chevy 3600
Leo Offline
Moderator
Moderator
click
Looks good Wayne, now I wonder why no one is in the passenger seat.
Originally Posted by 1953 panel
[quote=Wayne67vert] made my 1st drive around the block today. click
So are those shorts. lol
~Jim
Got the seats in.
http://img.photobucket.com/albums/v518/Blacktailer/IMG_5081.jpg
Now I can get the steering column, pedals, etc. set up!
Baba,
Looks like you have a 51 door there on your 49.
~Jim
Baba,
No it's a 49 with bear claw latches installed wink
Originally Posted by Baba
Baba,
Well how did it get the vent window? The only Chevy trucks with vent windows and pull down door handles are 51s.
~Jim
Well was a good day. I finished welding the new exhaust pipe together & installed it. Also installed new muffler. Finished painting the inside of the cab. So will start installing all the interior in the next few days.
"IT IS WHAT IT IS"
1953 Chevrolet 1/2-ton 3100 4x4
In the DITY Gallery
More images in Flickr
1948 GMC 1-Ton (now sold to someone in Hawaii!)
More photo in Flickr
1953 Chevy 1-Ton
Baba,
Jim,
You must be seeing the shelves in the background. It doesn't have vent windows. Take a look at the pics in my signature.
It actually has a set of aftermarket wind wings that my uncle put on when he was driving it to high school. I have never seen these on any other truck and will be reusing them when I get this project back on the road.
Baba,
Jim,
Dang close looking. I've seen any of those either. Next time you're taking pics take a close up of those.
~Jim
Jim,
It actually has a set of aftermarket wind wings that my uncle put on when he was driving it to high school. I have never seen these on any other truck and will be reusing them when I get this project back on the road. [/quote]
Dang close looking. I've seen any of those either. Next time you're taking pics take a close up of those. [/quote]
Might be awhile until it's assembled. I'll try to get a few closeups of them off the truck in the next day or so.
I should of been working this morning but I decided to pull off the carburetor like you guys on the StoveBolt suggested. I made a blog post if you want to see photos. http://kens46truck.wordpress.com/2012/04/26/pulling-off-the-carburetor/
My blog and photos of the old 46 --> http://kens46truck.wordpress.com/
Raining today, so started work on the 261. Pulled the water pump off and found that the front of #1 cylinder still has paint on it. Probably a good indication of a rebuild? Very little carbon build up in cylinders. Tomorrow I'll drop the pan and pull the pistons.
Replaced my original valve cover and push rod cover. They were both leaking a bit. I need to straighten the original ones out and repaint them. Until then, a bit a 'summer' bling from my stock pile.
I also made a new fuel line. I still need to make up my vacuum line to go along with the fuel line.
That's about it for this round.
drivers side
pass side
no name truck.
David Gilmore
Stovebolt Pictures
Paint progress
1950 Chevy 3600
It was actually a few days back but I got my windlace rubbers installed on my A.D.
I had been avoiding this due to the fact it seems to feature high on the 'PITA' job list.
The first one took just over an hour,the second about 45 mins.
Not as bad as I'd feared but not something I want to do again any time soon!
Here's proof.
I also found out about the 'second' screw inside the interior door and window handles.
Now they're out the way I can get on with fabricating my door panels.
I'm planning on full covers rather than the original basic ones.
More pix on Flickr.
Still raining today, so inside working on the 261. Got the head off and dropped the pan. So far everything looks really good. Also got the shop cleaned up and a bit more organized.
Ever since I replaced my Rochester with the Carter YF the throttle linkage has been rubbing on the firewall and even sticking a bit. Its not a big job, but a few trips between the vice and the truck for test fits sure made a big difference. Cleaned up the linkage, filed a few rough spots, resulting in much better throttle response.
Now I need to tackle the front brakes, king pins, and get some new shocks.
1953 Chevrolet 3100
Did a quick border run to pick up my new Coker whitewalls. Now all I have to do is get the body bolted back together!!
1951 Chevy 3100 5-Window
"Howard"
More pix on Photobucket
...got the new (4) 6.50x 20's on the '38 dump truck! (2 were in fair shape, now outer duals.)
Tired of the ticking and worrying, had a valve adjustment done, the 235 is smooth as silk. Also rewired the alternator which did the trick for a charging issue. The reunion with the southern bolters really recharged me to get going on "Norma Dame". I love my 52 more each day.
I cut a couple small sheet metal panels today to cover a few small holes.
shakey, I'm glad you came. Its guys like you that also inspire me. Now, just drive down anytime. We'll go cruising together.
W Online: Content
Repaired some rust spots and welded up the gas filler hole.
before
cut out
after
gas fill hole
Wayne
1989 Silverado
Received lowering springs, disc brake kit and sway bars along with some other parts from PerformanceOnline. Once I start puttin it all back together I'll post some pics.
I trashed the speakers I had mounted on the back of the firewall and mounted new 3 way speakers on the stainless shelf behind the seat. Speakers
I wasn't happy with the tin can echo from the old ones caused by both the quality of the speakers and the location (without any inclosure). I had 2nd skin insulation under the shelf and the sound is 100 times better now. I drove it out to the trim shop to have carpet and headliner installed. Now 44 miles on odometer. I don't remember my 51 back in 69 riding so rough but I guess when you're only 26 your rear is numb.
~Jim
Finally installed the seals around the hinges on the rear doors on my Sub. They have been laying in my parts bin for 2 years. Touched up some scratches on the right rear quarter and fender where some paint from the garage door found its way onto the Sub. Wonder how that happened. Checked and adjusted the toe in then went for a drive and filled it up at $3.72 a gallon. A good day except for the price of the gas.
Weeds
Today I started fabricating my inner door panels with 3/16" marine grade plywood.
I've decided to make full height ones rather than the basic originals.
Plans are to cover them in an Oxblood colour leather,and unlike my bench seat I'll maybe have a go at these myself.
More pix on Flickr.
24601
24601
The Stovebolt Flagship ('49 3800) has started locking up the right rear brake coming out of the winter storage. Today, I pulled the wheel and drum -- Everything looked okay, so I just doused it with brake cleaner and sprayed a little WD-40 on the linkages (letting everything drip for about 30 minutes before I put the drum back on), put it all back together and took a test drive to the transfer station (where we take our trash) and everything worked as it ought to.
Yay for me -- I actually fixed something smile
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
2014 Ford E-350 4x4 (Quigley)
thumbs_up Good Job John! thumbs_up
Brake Cleaner and WD-40.... add some Duct Tape and Baling Wire and there's nothing you can't fix.
Don't forget a big hammer, a screwdriver, a pair of pliers and a bigger hammer.
24601
24601
Yeah Buddy! The aircraft maintenance guys at work have taught me this over the years:
If it moves -- grease it.
If it doesn't move -- paint it.
If it's supposed to move and doesn't -- WD-40.
If it still doesn't -- BFH.
If it's NOT supposed to move and it does -- Duct tape it.
If it still moves -- epoxy it.
If it still moves, and it's metal -- weld it and then paint it.
And if it's not on your inventory form at all -- Deep six it!
smile
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
n the Navy it was, "if it moves salute it, if it doesn't move paint it.
smile
In the Navy it was, "if it moves salute it, if it doesn't move paint it."
~Jim
Got the LS-1 mounted the tranny and cross member.
I got the flatbed mounted on truck. Hooked up all the wiring for the lights. The last week I finished putting all of the interior back inside the cab. Also reinstalled the new wiring harness & got everthing connected & working. I also installed all the glass except for the windshield(this week task). Almost ready for the road, waiting on the seat to get back from the upholster shop.
"IT IS WHAT IT IS"
In the DITY Gallery
1953 Chevy 1-Ton
Got some more garage time today,it's a bank holiday.
I fabricated my left and right kick panels from 3/16" plywood.
More pix on Flickr.
Got the front end off my 55 Chevy Series 2!
Chris
"I'm sure those leftover parts aren't needed"
55 Chevy Series 2 pickup, "Buddy"
Looking good John. Is that a flat paint or primer?
~Jim
Got some work done on the exterior. I spent the better half of a hot and humid day basically wet sanding the exterior with CLR and Scotch-brite and then re-buffing it with chrome polish. Still needs a bit of work and I plan on repeating the entire process several more times but its getting there. Looks nice with the shine and a some reflections happening in the paint. ...the dark green is the original Juniper Green.
(will update w/pics of the tailgate asap)
BEFORE:
http://farm6.staticflickr.com/5070/5575911856_54251c0c1b_b.jpg
AFTER:
http://farm8.staticflickr.com/7055/7006358266_f0d3de799c_b.jpg
BEFORE:
http://farm6.staticflickr.com/5023/5575325737_2c3f258535_b.jpg
AFTER:
http://farm8.staticflickr.com/7040/7152451251_8c375e0f6c_b.jpg
BEFORE:
http://farm6.staticflickr.com/5185/5695931707_78aab69b57_b.jpg
AFTER:
http://farm8.staticflickr.com/7252/7006362522_7cde648759_b.jpg
BEFORE:
http://farm6.staticflickr.com/5058/5531804795_9c8396def3_o.jpg
AFTER:
http://farm6.staticflickr.com/5447/7152448581_b91be470f1_b.jpg
BLUEMEANIE, that looks awesome. thumbs_up
