4 members (Hanks custodian, GMCJammer51, 3B, 1 invisible), 127 guests, and 1 robot.
Topics128,196
Posts1,057,386
Members48,469
Hello All,
WEll I need a new or rebuilt master cylinder. In my 454-30 Dump Truck. The one is froze solid with the plunger all the way in. Casting number is 11652C, 1 1/4 in bore.
I have spent a good part of the day today searching the Internet without much luck. for a new or rebuilt master cylinder. I guess us guys with the big trucks are not thought of very much.
All anyone has is parts for low riders and hot rods. Nothing for us guys with some class wink
Anyway any suggestions or thoughts.
I am going to try my local NAPA Auto & Truck parts store tomorrow.
In advance, Thanx
GMCPic
Dance like no one is watching,
Sing like no one is listening,
Love like you've never been hurt.
1948 GMC FC101 1/2t Pickup w/270 and SM420
1948 GMC FC253 1t Factory 80"x9' Flatbed Dually
1948 Chevy COE 2 Ton 8'x15' Flatbed
1950 GMC 354-24 2 Ton 8'X12' Flatbed w/Dump Hoist
1953 GMC 454-30 3 Ton 8'x14' Flatbed w/Dump Hoist
1953 GMC 454-30 3 Ton Cab and Chassis
1942 Clarkator 6 MILL-44 Heavy Aircraft Tug
1942 Ford (9N) Moto Tug with 1/2 yard Loader
1947 Oliver OC3 HG-42 Tract-Crawler Bull Dozier w/6' Blade
Call Geoff at, Alretta Truck Parts. (508)788-9409. He just found another member here (appaloosas, on the 2nd page here) a master cyl. He'll know off the top of his head what you'll need. Knows these old truck brake parts, like the back of his hand.
Spanky Hardy
More pictures on Photobucket
1950 GMC 250 1-Ton
I too can vouch for Geoff at alretta truck parts. Knows his stuff and very pleasant to deal with.
Matt
Thanz All,
Opps on me, I went out today and crawled under the truck and to my surprise the bore on the master cylinder is 1 1/2", not 1 1/4" as I had thought.
I will give a call tomorrow to Geoff.
Thanz for the info wink
GMCPic
The master cylinder on my 450 was the only part of the brake system I didnt replace when rebuilding the brake system. I gave the casting number to Geoff, he had it in stock. He also had all the wheel cylinders and a return spring kit for the front. He was a couple buck cheaper per item than locally. One word of caution, the return springs for the Eaton rear are unavailable. I had my hydrovac rebuilt locally a little cheaper than Geoff wanted for his, though he had one.
Scott
1947, 1950, & 1952 Chevrolet 1/2 ton
1952 GMC 450 series Cab Over Engine
1946 Chevrolet 2 Ton
Hi All,
I called Geoff today and he has the master cylinder in stock, but for the price it must be GOLD plated.
For the same part, my local NAPA store is $125.00 cheaper and no shipping charges. Both are brand new, not rebuilds.
I had NAPA order the part which will be here Thursday afternoon. I also ordered a rebuild kit for the master cylinder that is coming out.
Then will see what comes next, probably the HydroVac.
I ordered all the return springs, i.e. throttle, clutch and brake, along with flex fuel lines and rubber stops from CLASSIC TRUCK PARTS last night.
Weeeeee such fun...
Thanx ALL
GMCPic
ive used him when i got the ashton and 720 gmc i had at the time. he is pricey but when you get it from him its the correct part and never had any problems with what he supplied me. since then i found lower cost suppliers.
Remember this!
Fortunately they are plentiful on 1 1/2 tons and larger with single and two speed rear ends throughout the 60's in case one of your is broken. There are two different colors of springs depending on where they go on the rear brakes. Not that 50+ years of grime and brake dust makes them easy to tell apart...
Jeff
My 1953 Chevrolet
1947.1 Gallery
Hi All,
Since I started this thing with these old GMC trucks I have found that parts are cheaper here on the west coast, even up into Oregon and Washington.
And if you look hard enough, just as plentiful.
But the guys on the east coast seem to be more knowledgeable.
Thanx for replies.
GMCPic
Well I got the Master Cylinder off, guess what it was a rebuilt with a new stainless steel sleeve. It was even bright and shiny inside. So, installed new Master cylinder and rebuilt old one as spare.
I was lucky on the registration, the previous owner had done a PNO on the truck, so the registration and title were pretty cheap.
NAPA is going to send out the 13 inch Lipp clutch to have it rebuilt for me, 1/3 cost of a new one.
GMCPic
Well here I am again. Brakes work and Hydrovac is working OK. Installed Gen and reg will be driving it home tomorrow Sat. 5/26
Then the real work begins.
Thanx All,
GMCPic
