3 members (moparguy, 3B, Chip O),
139
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,192 Posts1,057,350 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2001 Posts: 268 Shop Shark | | Shop Shark Joined: Apr 2001 Posts: 268 | Hello All, WEll I need a new or rebuilt master cylinder. In my 454-30 Dump Truck. The one is froze solid with the plunger all the way in. Casting number is 11652C, 1 1/4 in bore. I have spent a good part of the day today searching the Internet without much luck. for a new or rebuilt master cylinder. I guess us guys with the big trucks are not thought of very much. All anyone has is parts for low riders and hot rods. Nothing for us guys with some class  Anyway any suggestions or thoughts. I am going to try my local NAPA Auto & Truck parts store tomorrow. In advance, Thanx GMCPic
Dance like no one is watching, Sing like no one is listening, Love like you've never been hurt.
1948 GMC FC101 1/2t Pickup w/270 and SM420 1948 GMC FC253 1t Factory 80"x9' Flatbed Dually 1948 Chevy COE 2 Ton 8'x15' Flatbed 1950 GMC 354-24 2 Ton 8'X12' Flatbed w/Dump Hoist 1953 GMC 454-30 3 Ton 8'x14' Flatbed w/Dump Hoist 1953 GMC 454-30 3 Ton Cab and Chassis 1942 Clarkator 6 MILL-44 Heavy Aircraft Tug 1942 Ford (9N) Moto Tug with 1/2 yard Loader 1947 Oliver OC3 HG-42 Tract-Crawler Bull Dozier w/6' Blade
| | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | Call Geoff at, Alretta Truck Parts. (508)788-9409. He just found another member here (appaloosas, on the 2nd page here) a master cyl. He'll know off the top of his head what you'll need. Knows these old truck brake parts, like the back of his hand. | | | | | Joined: Aug 2008 Posts: 22 New Guy | | New Guy Joined: Aug 2008 Posts: 22 | I too can vouch for Geoff at alretta truck parts. Knows his stuff and very pleasant to deal with. Matt | | | | | Joined: Apr 2001 Posts: 268 Shop Shark | | Shop Shark Joined: Apr 2001 Posts: 268 | Thanz All, Opps on me, I went out today and crawled under the truck and to my surprise the bore on the master cylinder is 1 1/2", not 1 1/4" as I had thought. I will give a call tomorrow to Geoff. Thanz for the info  GMCPic
| | | | | Joined: Nov 2006 Posts: 173 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 173 | The master cylinder on my 450 was the only part of the brake system I didnt replace when rebuilding the brake system. I gave the casting number to Geoff, he had it in stock. He also had all the wheel cylinders and a return spring kit for the front. He was a couple buck cheaper per item than locally. One word of caution, the return springs for the Eaton rear are unavailable. I had my hydrovac rebuilt locally a little cheaper than Geoff wanted for his, though he had one. Scott
1947, 1950, & 1952 Chevrolet 1/2 ton 1952 GMC 450 series Cab Over Engine 1946 Chevrolet 2 Ton
| | | | | Joined: Apr 2001 Posts: 268 Shop Shark | | Shop Shark Joined: Apr 2001 Posts: 268 | Hi All,
I called Geoff today and he has the master cylinder in stock, but for the price it must be GOLD plated.
For the same part, my local NAPA store is $125.00 cheaper and no shipping charges. Both are brand new, not rebuilds.
I had NAPA order the part which will be here Thursday afternoon. I also ordered a rebuild kit for the master cylinder that is coming out.
Then will see what comes next, probably the HydroVac.
I ordered all the return springs, i.e. throttle, clutch and brake, along with flex fuel lines and rubber stops from CLASSIC TRUCK PARTS last night.
Weeeeee such fun...
Thanx ALL
GMCPic
| | | | | Joined: Apr 2005 Posts: 1,107 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,107 | I called Geoff today and he has the master cylinder in stock, but for the price it must be GOLD plated. ive used him when i got the ashton and 720 gmc i had at the time. he is pricey but when you get it from him its the correct part and never had any problems with what he supplied me. since then i found lower cost suppliers. | | | | | Joined: Feb 2006 Posts: 1,867 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 1,867 | One word of caution, the return springs for the Eaton rear are unavailable. Remember this! Fortunately they are plentiful on 1 1/2 tons and larger with single and two speed rear ends throughout the 60's in case one of your is broken. There are two different colors of springs depending on where they go on the rear brakes. Not that 50+ years of grime and brake dust makes them easy to tell apart... Jeff | | | | | Joined: Apr 2001 Posts: 268 Shop Shark | | Shop Shark Joined: Apr 2001 Posts: 268 | Hi All,
Since I started this thing with these old GMC trucks I have found that parts are cheaper here on the west coast, even up into Oregon and Washington.
And if you look hard enough, just as plentiful.
But the guys on the east coast seem to be more knowledgeable.
Thanx for replies. GMCPic
| | | | | Joined: Apr 2001 Posts: 268 Shop Shark | | Shop Shark Joined: Apr 2001 Posts: 268 | Well I got the Master Cylinder off, guess what it was a rebuilt with a new stainless steel sleeve. It was even bright and shiny inside. So, installed new Master cylinder and rebuilt old one as spare.
I was lucky on the registration, the previous owner had done a PNO on the truck, so the registration and title were pretty cheap.
NAPA is going to send out the 13 inch Lipp clutch to have it rebuilt for me, 1/3 cost of a new one.
GMCPic
| | | | | Joined: Apr 2001 Posts: 268 Shop Shark | | Shop Shark Joined: Apr 2001 Posts: 268 | Well here I am again. Brakes work and Hydrovac is working OK. Installed Gen and reg will be driving it home tomorrow Sat. 5/26 Then the real work begins.
Thanx All, GMCPic
