1 members (keithfielder),
156
Mod | | | Forums66 Topics128,183 Posts1,057,263 Members48,467 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2011 Posts: 139 Shop Shark | | Shop Shark Joined: Nov 2011 Posts: 139 | Finally got the rear and front ends out, springs off. Air tools and heat wrench essential equipment!!! Almost ready for the sand blaster. | | | | | Joined: Sep 2010 Posts: 1,721 back yard wrench turner | | back yard wrench turner Joined: Sep 2010 Posts: 1,721 | made my 1st drive around the block today. click The truck has plenty of power, brakes work very good, shifts fine, however the steering is still 1938. click Wayne1938 1-Ton Farm TruckStovebolt Gallery Forums1989 Silverado 1996 Mustang GT convertible When I die, I hope she doesn't sell everything for what I told her I paid for it! | | | | | Joined: Aug 2011 Posts: 687 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 687 | Looking good Wayne. A fun project | | | | | Joined: Mar 2007 Posts: 4,217 Moderator | | Moderator Joined: Mar 2007 Posts: 4,217 | made my 1st drive around the block today. click The truck has plenty of power, brakes work very good, shifts fine, however the steering is still 1938. clickLooks good Wayne, now I wonder why no one is in the passenger seat. | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | [quote=Wayne67vert] made my 1st drive around the block today. click The truck has plenty of power, brakes work very good, shifts fine, however the steering is still 1938. So are those shorts. lol
~Jim
| | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Baba, Looks like you have a 51 door there on your 49.
~Jim
| | | | | Joined: Jun 2011 Posts: 150 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 150 | Baba, Looks like you have a 51 door there on your 49. No it's a 49 with bear claw latches installed  | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Baba, Looks like you have a 51 door there on your 49. No it's a 49 with bear claw latches installed  Well how did it get the vent window? The only Chevy trucks with vent windows and pull down door handles are 51s.
~Jim
| | | | | Joined: Aug 2008 Posts: 290 Shop Shark | | Shop Shark Joined: Aug 2008 Posts: 290 | Well was a good day. I finished welding the new exhaust pipe together & installed it. Also installed new muffler. Finished painting the inside of the cab. So will start installing all the interior in the next few days. | | | | | Joined: Jun 2011 Posts: 150 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 150 | Baba, Looks like you have a 51 door there on your 49. No it's a 49 with bear claw latches installed  Well how did it get the vent window? The only Chevy trucks with vent windows and pull down door handles are 51s. Jim, You must be seeing the shelves in the background. It doesn't have vent windows. Take a look at the pics in my signature. It actually has a set of aftermarket wind wings that my uncle put on when he was driving it to high school. I have never seen these on any other truck and will be reusing them when I get this project back on the road. | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Baba, Looks like you have a 51 door there on your 49. No it's a 49 with bear claw latches installed  Well how did it get the vent window? The only Chevy trucks with vent windows and pull down door handles are 51s. Jim, You must be seeing the shelves in the background. It doesn't have vent windows. Take a look at the pics in my signature. It actually has a set of aftermarket wind wings that my uncle put on when he was driving it to high school. I have never seen these on any other truck and will be reusing them when I get this project back on the road. Dang close looking. I've seen any of those either. Next time you're taking pics take a close up of those.
~Jim
Jim, You must be seeing the shelves in the background. It doesn't have vent windows. Take a look at the pics in my signature. It actually has a set of aftermarket wind wings that my uncle put on when he was driving it to high school. I have never seen these on any other truck and will be reusing them when I get this project back on the road. [/quote]
Dang close looking. I've seen any of those either. Next time you're taking pics take a close up of those. [/quote] Might be awhile until it's assembled. I'll try to get a few closeups of them off the truck in the next day or so. | | | | | Joined: Nov 2011 Posts: 139 Shop Shark | | Shop Shark Joined: Nov 2011 Posts: 139 | Raining today, so started work on the 261. Pulled the water pump off and found that the front of #1 cylinder still has paint on it. Probably a good indication of a rebuild? Very little carbon build up in cylinders. Tomorrow I'll drop the pan and pull the pistons. | | | | | Joined: Aug 2011 Posts: 687 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 687 | Replaced my original valve cover and push rod cover. They were both leaking a bit. I need to straighten the original ones out and repaint them. Until then, a bit a 'summer' bling from my stock pile. I also made a new fuel line. I still need to make up my vacuum line to go along with the fuel line. That's about it for this round. drivers side pass side no name truck.
| | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | It was actually a few days back but I got my windlace rubbers installed on my A.D. I had been avoiding this due to the fact it seems to feature high on the 'PITA' job list. The first one took just over an hour,the second about 45 mins. Not as bad as I'd feared but not something I want to do again any time soon! Here's proof.I also found out about the 'second' screw inside the interior door and window handles. Now they're out the way I can get on with fabricating my door panels. I'm planning on full covers rather than the original basic ones.
1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
| | | | | Joined: Nov 2011 Posts: 139 Shop Shark | | Shop Shark Joined: Nov 2011 Posts: 139 | Still raining today, so inside working on the 261. Got the head off and dropped the pan. So far everything looks really good. Also got the shop cleaned up and a bit more organized. | | | | | Joined: Mar 2005 Posts: 94 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 94 | Ever since I replaced my Rochester with the Carter YF the throttle linkage has been rubbing on the firewall and even sticking a bit. Its not a big job, but a few trips between the vice and the truck for test fits sure made a big difference. Cleaned up the linkage, filed a few rough spots, resulting in much better throttle response.
Now I need to tackle the front brakes, king pins, and get some new shocks.
1953 Chevrolet 3100
| | | | | Joined: Sep 2010 Posts: 252 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 252 | Did a quick border run to pick up my new Coker whitewalls. Now all I have to do is get the body bolted back together!! | | | | | Joined: Feb 2012 Posts: 61 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2012 Posts: 61 | ...got the new (4) 6.50x 20's on the '38 dump truck! (2 were in fair shape, now outer duals.)
| | | | | Joined: Jan 2012 Posts: 17 New Guy | | New Guy Joined: Jan 2012 Posts: 17 | Tired of the ticking and worrying, had a valve adjustment done, the 235 is smooth as silk. Also rewired the alternator which did the trick for a charging issue. The reunion with the southern bolters really recharged me to get going on "Norma Dame". I love my 52 more each day. | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | I cut a couple small sheet metal panels today to cover a few small holes.
shakey, I'm glad you came. Its guys like you that also inspire me. Now, just drive down anytime. We'll go cruising together. | | | | | Joined: Sep 2010 Posts: 1,721 back yard wrench turner | | back yard wrench turner Joined: Sep 2010 Posts: 1,721 | Repaired some rust spots and welded up the gas filler hole. before cut out after gas fill hole Wayne1938 1-Ton Farm TruckStovebolt Gallery Forums1989 Silverado 1996 Mustang GT convertible When I die, I hope she doesn't sell everything for what I told her I paid for it! | | | | | Joined: Nov 2011 Posts: 139 Shop Shark | | Shop Shark Joined: Nov 2011 Posts: 139 | Received lowering springs, disc brake kit and sway bars along with some other parts from PerformanceOnline. Once I start puttin it all back together I'll post some pics. | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | I trashed the speakers I had mounted on the back of the firewall and mounted new 3 way speakers on the stainless shelf behind the seat. Speakers I wasn't happy with the tin can echo from the old ones caused by both the quality of the speakers and the location (without any inclosure). I had 2nd skin insulation under the shelf and the sound is 100 times better now. I drove it out to the trim shop to have carpet and headliner installed. Now 44 miles on odometer. I don't remember my 51 back in 69 riding so rough but I guess when you're only 26 your rear is numb.
~Jim
| | | | | Joined: Mar 2003 Posts: 1,132 Shop Shark | | Shop Shark Joined: Mar 2003 Posts: 1,132 | Finally installed the seals around the hinges on the rear doors on my Sub. They have been laying in my parts bin for 2 years. Touched up some scratches on the right rear quarter and fender where some paint from the garage door found its way onto the Sub. Wonder how that happened. Checked and adjusted the toe in then went for a drive and filled it up at $3.72 a gallon. A good day except for the price of the gas.
Weeds | | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | Today I started fabricating my inner door panels with 3/16" marine grade plywood. I've decided to make full height ones rather than the basic originals. Plans are to cover them in an Oxblood colour leather,and unlike my bench seat I'll maybe have a go at these myself.
| | | | | Joined: Nov 1995 Posts: 5,744 24601 | | 24601 Joined: Nov 1995 Posts: 5,744 | The Stovebolt Flagship ('49 3800) has started locking up the right rear brake coming out of the winter storage. Today, I pulled the wheel and drum -- Everything looked okay, so I just doused it with brake cleaner and sprayed a little WD-40 on the linkages (letting everything drip for about 30 minutes before I put the drum back on), put it all back together and took a test drive to the transfer station (where we take our trash) and everything worked as it ought to. Yay for me -- I actually fixed something  John
~ John A kid raised on Hotwheels, Matchbox and Tonka cannot be reasonably expected to own only one vehicle as an adult. 1949 Chevrolet 3804In the Legacy Gallery | In the Gallery Forum1973 IH 1310 Dump1963 Kaiser M38A12001 International/AmTran RE3000 "Skoolie"2014 Ford E-350 4x4 (Quigley) | | | | | Joined: Jul 2008 Posts: 1,262 Shop Shark | | Shop Shark Joined: Jul 2008 Posts: 1,262 |  Good Job John!  Brake Cleaner and WD-40.... add some Duct Tape and Baling Wire and there's nothing you can't fix. | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 |  Good Job John!  Brake Cleaner and WD-40.... add some Duct Tape and Baling Wire and there's nothing you can't fix. Don't forget a big hammer, a screwdriver, a pair of pliers and a bigger hammer. | | | | | Joined: Nov 1995 Posts: 5,744 24601 | | 24601 Joined: Nov 1995 Posts: 5,744 | Yeah Buddy! The aircraft maintenance guys at work have taught me this over the years: If it moves -- grease it. If it doesn't move -- paint it. If it's supposed to move and doesn't -- WD-40. If it still doesn't -- BFH. If it's NOT supposed to move and it does -- Duct tape it. If it still moves -- epoxy it. If it still moves, and it's metal -- weld it and then paint it. And if it's not on your inventory form at all -- Deep six it!
~ John A kid raised on Hotwheels, Matchbox and Tonka cannot be reasonably expected to own only one vehicle as an adult. 1949 Chevrolet 3804In the Legacy Gallery | In the Gallery Forum1973 IH 1310 Dump1963 Kaiser M38A12001 International/AmTran RE3000 "Skoolie"2014 Ford E-350 4x4 (Quigley) | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Yeah Buddy! The aircraft maintenance guys at work have taught me this over the years: If it moves -- grease it. If it doesn't move -- paint it. If it's supposed to move and doesn't -- WD-40. If it still doesn't -- BFH. n the Navy it was, "if it moves salute it, if it doesn't move paint it. If it's NOT supposed to move and it does -- Duct tape it. If it still moves -- epoxy it. If it still moves, and it's metal -- weld it and then paint it. And if it's not on your inventory form at all -- Deep six it!  In the Navy it was, "if it moves salute it, if it doesn't move paint it."
~Jim
| | | | | Joined: May 2011 Posts: 266 Shop Shark | | Shop Shark Joined: May 2011 Posts: 266 | Got the LS-1 mounted the tranny and cross member. | | | | | Joined: Aug 2008 Posts: 290 Shop Shark | | Shop Shark Joined: Aug 2008 Posts: 290 | I got the flatbed mounted on truck. Hooked up all the wiring for the lights. The last week I finished putting all of the interior back inside the cab. Also reinstalled the new wiring harness & got everthing connected & working. I also installed all the glass except for the windshield(this week task). Almost ready for the road, waiting on the seat to get back from the upholster shop. | | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | Got some more garage time today,it's a bank holiday. I fabricated my left and right kick panels from 3/16" plywood. 1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
| | | | | Joined: Feb 2012 Posts: 23 New Guy | | New Guy Joined: Feb 2012 Posts: 23 | Got the front end off my 55 Chevy Series 2!
Chris "I'm sure those leftover parts aren't needed" 55 Chevy Series 2 pickup, "Buddy"
| | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Got some more garage time today,it's a bank holiday. I fabricated my left and right kick panels from 3/16" plywood. Looking good John. Is that a flat paint or primer?
~Jim
| | | | | Joined: Jul 2008 Posts: 1,262 Shop Shark | | Shop Shark Joined: Jul 2008 Posts: 1,262 | BLUEMEANIE, that looks awesome.  | | |
