1 members (Rusty Rod), 80 guests, and 2 robots.
Topics128,127
Posts1,056,680
Members48,452
Opinions on the subject are as varied as anything; nevertheless, I am considering blocking off my butterfly heat riser valve as it is very worn and flops around. The exhaust is leaking out and blackening everthing around it. Obviously, there ar those who will say that the mechanism was put there by GM for a reason. Others will say it isn't necessary - especially for warmer climates. I can cut a beer can block gasket in about 3 minutes and seal this thing tight. Any input is appreciated.
J.D. Jordan
You might be alright with it removed and you might not. Generally you don't need a cold climate to have carb icing problems, just the right combination of humidity etc. There may be a way of getting a bushing installed on your manifold.
1951 1 Ton Completed
Or you can do what i did on mine,,remove the shaft and butterfly completely,,and put 5/16 bolts in the holes.
Marty
I ran mine with it stuck in the shut position for some time. When I added the fenton headers, I installed a water heat set-up. No more cold blooded hesitations when I try to accelerate. Better gas mileage also, and then even better when I added the O.D., radials and HEI. Every professional engine builder I've talked too sez the intake heat is essential. Even in the warm climates.
1962 Fleetside 4spd 235 w/O.D. posi 3:90
1990 Subaru Legacy Wagon AWD 2.2 5sp
2013 Ram Tradesman C/V
My Webshot Photos]
My welder guy who's been spliting 235 manifolds for years says to weld the riser in the closed position.
99 percent of the time it's closed as you are running and warmed up, closed position just protects the underside of the intake.
1946 1/2-Ton Chevy
Riding in the Passing Lane
You can probable get along without it but blocking it off is not a good way. You still get some heat to the intake with the passage open. Remove the shaft & fill the holes is better.
1972 Chevy c10 Cheyenne Super
I remove it and welded up the holes and ran even better the when it was in there.More flow for the ehxaust.
1955 GMC Big Window
1957 Chevy 1.5-Ton
1959 Chevy Short Fleetside
Plus lots more ...I LOVE THESE TRUCKS!!!
