7 members (eclector, 32Fordpuchoptop, Hotrod Lincoln, dt235sd, MickeyP, 2 invisible), 154 guests, and 1 robot.
Topics128,033
Posts1,055,531
Members48,425
#842060 04/08/2012 12:55 AM
Shot some paint on the completed cab and set it on the chassis.....now to get it fired up....lots of wiring to figure out
http://inlinethumb13.webshots.com/17932/2021215130102329435S500x500Q85.jpg
Shane
1959 Apache 3100 Fleetside
1959 Apache 3200 NAPCO
1957 Chevy 5700 Low Cab Forward
1959 GMC F370 LCF
Another 1959 Apache 3100 Fleetside
1959 Chevy 5700 LCF
1946 Chevy 1/2 ton
1958 GMC 600
1974 Elcamino SS
Wow! I love those suicide doors. Can't wait to see the finished product.
Camp Commandant
Camp Commandant
Wow, it looks awesome, I just checked out all your pictures. The one above is just a tease, we need more!
Great job really. I can tell there is tons of work there.
~ Billy
1959 GMC 860 | Pictures
I
I Offline
Holy Crab, That's one neat truck. More pictures, more pictures.....Great job
Click on the webshots link in my signature and there are 9 pages of the build
Shane
1959 GMC F370 LCF
1959 Chevy 5700 LCF
1946 Chevy 1/2 ton
1958 GMC 600
1974 Elcamino SS
DUDE! --- that is one seriously badass build! Can't wait to see the finished product. Beautiful work. What engine is that?
1946 1.5-Ton Chevy Shorty Bus
All my best --- Tango
I've said it before, I'll say it again, man you've got talent. Looks great.
1947, 1950, & 1952 Chevrolet 1/2 ton
1952 GMC 450 series Cab Over Engine
1946 Chevrolet 2 Ton
Tango,
It has a 350 with a 4L80E tranny with a 5.38 gear in the rear end. should have enough power and cruise down the road at 65 all day. the chassis and running gear is from an 2003 GMC W4500HD. That was the last year gm put a 350 in anything.
Shane
Shane
1959 GMC F370 LCF
1959 Chevy 5700 LCF
1946 Chevy 1/2 ton
1958 GMC 600
1974 Elcamino SS
Mighty Sweet ride you are assembling there...please do keep the pix & updates coming. Just curious...are any higher R & P sets available for that rear end?
there are higher and lower R&P sets out there for it. look for any salvage yard that deals in isuzu npr/gmc w4 trucks and you can find a bunch of different ratios depending on what the truck was set up for.
Shane
1959 GMC F370 LCF
1959 Chevy 5700 LCF
1946 Chevy 1/2 ton
1958 GMC 600
1974 Elcamino SS
Sure looks good!!!
Red meat is not bad for you.........Fuzzy green meat is bad for you!
"What happens in the garage stays in the garage!"
1958 Chevy Spartan 100 firetruck in the Gallery
I've toyed with the idea of using that frame in a swap. What size rims and tires are you using? Those don't look like the cookie cutter 16" that most NPR's seem to wear. I think a big truck needs big wheels and tires to fill out the wheel wells.
Scott
Scott
The tires are 9r-22.5 The bolt pattern on these trucks is the same as the 56-59 chevy 2 ton trucks. 6 on 8.75 I changed the studs to american thread so I could get correct lug nuts. I also found a set of alcoa aluminum wheels. I should have all the alcoa wheels on soon. I was mocking up the bed tonight....more fabrication
Shane
1959 GMC F370 LCF
1959 Chevy 5700 LCF
1946 Chevy 1/2 ton
1958 GMC 600
1974 Elcamino SS
You will never see another like it - that is beautiful!!
1st Gen. Dodge Cummins 4x4 OVRTRQD Buick GNX #276
"If it died... we can fix it" | "If your not outraged, you're not paying attention." | "Do you know a large group of baboons is called a Congress? That explains a lot." ~author unwn
I just spent a hour looking through your pictures. I can't imagine how much time you've spent doing the work, and I've worked in the body buisness for 30+ years. Very impressive, and all done in a two car garage!
Thanks bobd, I have a few hours in it. Most are from 8pm til about 1am then off to work at 6 am. It was 5 am when we got done spaying it last Thursady. My brother has an autobody shop and just outer body paint and setting it on the chassis was done there. I wish I had a bigger garage though. The wife wont let me buy a building because she won't be able to monitor my truck hording disorder. I have been messing around with body work since I was 12.
Shane
1959 GMC F370 LCF
1959 Chevy 5700 LCF
1946 Chevy 1/2 ton
1958 GMC 600
1974 Elcamino SS
I have that same disorder, like alot of us. What I really wish I had was your ambition. I seem to concentrate more on the hording, than on a single project. Again, very impressive.
Bob
From what I've seen...you "mess around" better than most professionals execute their trade!
I've been told that I do pretty good for being an accountant.....Tuesday at work they were having trouble with a machine and they came and got me to trouble shoot it. 10 seconds after walking up to the machine, I knew what was wrong with it and how to fix it. The maintenance manager calls me his 8th and 9th maintenance man.
Shane
1959 GMC F370 LCF
1959 Chevy 5700 LCF
1946 Chevy 1/2 ton
1958 GMC 600
1974 Elcamino SS
Looks great in paint.
I've seen other people "build" stuff like that too, but it never looks like the factory made it. Yours does...
I've been starting to look into a newer rear diff for my '52 to get rid of the low geared 2 speed. I was thinking a later model IH with hydraulic brakes but I haven't gotten to measuring the spring width yet. I'd really like to get 22.5 aluminum wheels on it.
1952 Chevrolet 6400 flat bed
Fantastic truck, my gosh your skilled. Going to be an awesome truck !
