| | | Forums66 Topics128,094 Posts1,056,483 Members48,444 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#84478 10/18/2007 1:23 PM | Joined: Sep 2007 Posts: 8 New Guy | | New Guy Joined: Sep 2007 Posts: 8 | I purchased a 1965 C-10 with a 283ci and a three speed manual tranny.
I since have replaced the above with a 327ci and a turbo 350 tranny. The porblem I have now is that the driveshaft is to long. If at all possible I would like to get rid of the two piece driveshaft for a one piece. Is this possible? Will a one piece from a later model truck with a 127" wheelbase work?
Looking for help! | | |
#84479 10/18/2007 3:31 PM | Joined: Nov 2002 Posts: 1,002 Shop Shark | | Shop Shark Joined: Nov 2002 Posts: 1,002 | I had a 63 C20 lwb with a Olds 350 and a TH400. The Olds was a direct bolt in. The drive shaft was a single piece, I don't know where the previous owner got it. I still have the drive shaft. I know the drive shaft won't fit my current 63 C20 with aA833 too short. Hope that doesn't muck thins up
Larry
I don't own a vehicle that isn't old enough to drink. | | |
#84480 10/18/2007 4:49 PM | Joined: Oct 2006 Posts: 128 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2006 Posts: 128 | I'm running into the same situation with my "upgrade"... I am dropping in a 331 Hemi with a Chrysler A727 transmission. I also questioned going with the one piece driveshaft but was advised to stick with the two piece unless I wanted to get in to pinion angle issues. From what I've been told, the front section will need to be shortened and the back section will stay at it's original length and sit at the same angle from the center carrier bearing as stock so pinion angle will not change.
Whether this is true or not is beyond me... that's why I am paying a guy who knows what he's talking about to take care of this part of the rebuild.
Lee | | |
#84482 10/19/2007 2:25 AM | Joined: Nov 2002 Posts: 1,002 Shop Shark | | Shop Shark Joined: Nov 2002 Posts: 1,002 | As a follow up on drive shaft shorting. When the single piece drive shaft was too short, I had the two piece drive shaft shortened. I called a local shop that shortened drive shafts. The shop told me to measure both trannies and find the difference. I measured both trans found the difference. Took the shaft to them gave them the difference. Picked the shaft and it installed with out a problem. I've banged the trans pretty hard more than once and no problems.
Larry
#84483 10/19/2007 4:17 AM | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | I don't think you can go single shaft on a C10. The driveshaft has to go through that big crossmember that the trailing arms attach to. I don't think you would have much range of motion with a single shaft. Scott | | |
