3 members (homer52, Bill Hanlon, 1 invisible), 140 guests, and 3 robots.
Topics128,026
Posts1,055,408
Members48,422
Is there a conversion kit for my 57 GMC 6cyl point ignition to electronic ignition? Just brought it home on Sat and trying to figure out what we need to get it mobile so I can start driving it. Thanks!
Hello Kitty bandaides do make the hurt go away!!
1970 Chevy C-10 Longbed
1959 Chevy Suburban
1957 GMC Pickup Truck
Pertronix makes an electronic replacement unit that just bolts into your distributor and does away with the points and condenser. Never have to set the points again and much hotter spark. Give em' a call and they will tell you exactly which part number unit you need and usually under $100.
DJ
dj durant
More pix on Flickr
thank you kindly. that is exactly what we are looking( well what the hubby is looking for). He doesn't want me calling him to come rescue me when the points faul out. we want to keep it as stock as possible.
1959 Chevy Suburban
However do keep a set of points in your glove box in case the Pertronix unit fails. It has been known to happen.
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
Close to 1,000 miles on my Pertronix set and not a problem!
58' 3200 235 3-speed/OD
