| | | Forums66 Topics128,022 Posts1,055,381 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#84454 10/17/2007 4:15 AM | Joined: Jun 2006 Posts: 17 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2006 Posts: 17 | Is there a conversion kit for my 57 GMC 6cyl point ignition to electronic ignition? Just brought it home on Sat and trying to figure out what we need to get it mobile so I can start driving it. Thanks! | | |
#84455 10/17/2007 4:35 AM | Joined: Feb 2007 Posts: 435 'Bolter | | 'Bolter Joined: Feb 2007 Posts: 435 | Pertronix makes an electronic replacement unit that just bolts into your distributor and does away with the points and condenser. Never have to set the points again and much hotter spark. Give em' a call and they will tell you exactly which part number unit you need and usually under $100. DJ | | |
#84456 10/17/2007 4:37 AM | Joined: Jun 2006 Posts: 17 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2006 Posts: 17 | thank you kindly. that is exactly what we are looking( well what the hubby is looking for). He doesn't want me calling him to come rescue me when the points faul out. we want to keep it as stock as possible. | | |
#84457 10/22/2007 5:36 AM | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | However do keep a set of points in your glove box in case the Pertronix unit fails. It has been known to happen. Bill | | |
#84458 10/22/2007 5:59 AM | Joined: Dec 2005 Posts: 547 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 547 | Close to 1,000 miles on my Pertronix set and not a problem!
58' 3200 235 3-speed/OD
