1 members (Pre '68 Dave), 60 guests, and 3 robots.
Topics128,187
Posts1,057,312
Members48,468
#841588 04/06/2012 2:58 AM
The assembly manual calls out what. Screw. Nut bolt washer,etc to use in the building of the 54 1st series trucks. Question for the masses- is there a key somewhere for the callouts listed?
....David
...I'm pretty much in the bolt with you! About all I know is that "LW" means "lock washer".
...maybe, IF you look up the part number in the master parts book the part number would probably say what it is??? I don't have a master parts book but if you look around there is some listed on line.
....or you have to do what I do when I don't remember. Use what fits or works better at the time!
It's really frustrating to have the diagram and the part number, but no way to know what size the nut or bolt is.
Probably the best reference is the knowledge and experience of other Stovebolt.com forum members. Post a question about the specific bolt.
I haven't found a reference that defines the bolt numbers in the Assembly Manual. A few of the nuts, bolts, and washers can be referenced in the "Standard Parts 8.900" group of the Master Parts Catelog with illustrations, but most of the hardware items in the MPC do not have the same number as in the Assembly Manual. The hardware item and dimentions are sometimes shown in the MPC section for the item that it attaches to, such as this listing for Group #0.002.
If you do find the nut or bolt in the MPC, this list of abbreviations may help.
The drawing in the Assembly Manual will sometimes show you if the bolt is a hex, square, clutch head, etc.
You can sometimes find info on the item by doing a Google search of the part number and a brief description such as "bolt 3701135" for the outer bolts in the front engine mount of my '54 3100. Or, "washer 352282" for the middle washer on my '54 front engine mount.
Here is one of the "washer 352282" hits that gave me thickness info available nowhere else ...
http://www.wbparts.com/rfq/5310-00-447-2493.html
and info on "washer 365685", the end washer on the front motor mount at the same site ...
http://www.wbparts.com/nsndetail.cfm?NIIN=004496420&pn=365685
Try the site to search for other part numbers.
I've found that some of the "bolt kits" or specific bolts sold by vendors are not correct, so don't assume that they know any more than you do.
Bottom line - I don't have a good answer.
- Lonnie
My '54 3104
Why don't we start a master list of fasteners? Look in the assembly manual, look at what is on your truck in that position, confirm the fastener type, length, thread ect.
Just doesn't seem like it would take that long to come up with a list cross-referenced to the assembly manual numbers.
Kurt
This would be a good starting point
http://www.laroke.com/larryk4674/2005/bbpartshp2.htm
I reccomend Larry's parts list all the time. Actually, i think it should be permanently
added to the "Tech Tips" page.
Drew
I have see that in some cases different assembly plants might use different parts for some reason. Therefore the term "original" might be different for different vehicles built in different plants.
For that reason I agree with Alvin, "use what fits"
~Jim
Larry's list is a good start. His list includes this disclaimer regarding the correctness of the parts:
"* These are not the "concours correct" fasteners. They are just what is currently mounted on BillyBob."
It took me only a few minutes to copy his info onto an Excel worksheet that can be easily sorted by part number, location, etc. I'll contact him to ask for his permission to distribute it. With a few tweaks, it could be updated as more info comes in from the forum.
- Lonnie
My '54 3104
I sent an email to Larry Kephart asking permission to use his data in an Excel workbook for us to use and update. He immediately responded with a thumbs up.
I have a draft of the Excel workbook. Send me a PM with your email address if you would like to see and critique it. Looking for ideas to make it simple, yet usable.
- Lonnie
My '54 3104
Do I have to have an Excel program installed on my pc to look at it?
Drew
Some of the IT gurus on the forum can answer better than I can.
Probably need Excel or a clone Excel program. I could save as a .pdf, but it would not be as flexible for finding parts.
- Lonnie
My '54 3104
Why not build or export it in Google Docs and open it up to everyone? You could maintain control of input but open it to the public.
Give me ambiguity
or give me something else
Lonnie,
Google Docs Spreadsheet might work if the Excel spreadsheet has no macros and does to do sophisticated list/table manipulations.
http://www.google.com/google-d-s/spreadsheets/
Thanks, CASO and Tim -
That looks like the solution. I exported the workbook to Google Docs. Now I gotta play with it to make it easy to use inside Google Docs. Probably won't get to post the first version until Sunday.
- Lonnie
My '54 3104
Drew,
To view the Excel files, download and install the free Open Office or Libre Office suite. Drop in replacement for Microsoft Office, and will load and read Excel files.
Link to Libre Office
This very high quality software, We use it on all the workstations in my business.
Kurt
That's what I was thinking. Thanks for the direction
....David
Hey,
Your welcome. Looks like things are (were) already under way!
I'm going to keep track from now on. I may even take pictures of the fasteners as I remove them and make links!
Kurt
I finished the trial run of the spreadsheet with part numbers used in the Factory Assembly Manual based on the data that Larry Kephart and BillyBob started. I'm wide open for suggestions to make it easy to use.
< CLICK > this link to the Google Docs spreadsheet.
Looking for input on the "correct" way to list the dimentions of the nuts, bolts, washers, etc.
I feel that the information must include the dimentions/descriptions of the original part, plus info on substitute parts that will work. I have space for both on the worksheet.
I used to think that I was the cat's meow when it came to creating Excel spreadsheets. But I'm having a little trouble with the Google version. And when it comes to publishing for all to see and update - I'm befuddled.
So, I guess this project moved me from wizzkid to dufus in one weekend! But it's a start.
>> CASO and Tim -
Have you worked with Google Docs to allow users to publish or submit info? I'll take any info, experiences, or suggestions that you can give me.
- Lonnie
My '54 3104
Authorized Pest
Authorized Pest
Does the Google program allow you to add an image to anything?
I know this Tech Tip took a while to build and get pictures, but for some folks, it is very helpful.
I'm sure brainer people than I will jump in here.
This would be a great Tech Tip. Thanks to all of you for taking the time to put the pieces together. Reminds me of the days we worked on those pages to identify your truck! dang Glad (hopefully) things are getting better / easier.
Peggy M
~ Peggy M
1949 Chevrolet 3804
"Success comes in 'cans' ..."
Looks good, Lonnie.
I do not have much experience with Google Spreadsheet.
You (the owner) can add collaborators (by email address) but then that collaborator can change anything (until you take away a person's collaboration ability).
Sharing collaboration on a Google Spreadsheet (all viewers and Editor). Only the owner can add/remove an editor.
Here is how you can add an image to a Google Spreadsheet.
Thanks go to you and to Larry (and to Billy Bob).
Peggyand Lonnie, I've messed with it a little and found its not that different than MS Works or whateva'... It's pretty friendly really. If you want to do a workgroup or something I'm up for a 'little' data arrangement. Drop me a PM and I'll send you my digits and we can talk.
But if you can get Tim to do it so much the better!
Give me ambiguity
Cool thread!!
Outstanding!
thank you
Is rust considered a body style?
LonnieC
This look great and it crosses to MS Excel with ease when you down load. Lot of work went into this and I hope everyone will appreciate the amount of effort that was required.
A friend and I have been working on getting the similar doc for the 41 to 46 trucks.
Thank for the inspiration it helps to keep us going.
"If it ain't Steel it ain't Real"
"Earth the insane aslyum for the rest of the Universe"
41 1/2-ton, a work in progress
68 Shortbed stepside 327/325hp/700R4
Hey guys -
I have pretty much dropped the ball on creating and updating a database for fasteners. Anybody want to take over? Send me a PM, I'll give you the plan that I had in mind when I started it.
In the mean time, here are links to sources of info that I use when I am researching a part number to learn the description (Length, Diam, Thread pitch, Head, etc):
You can sometimes find info on the item by doing a Google search of the part number and a brief description such as "bolt 3701135" for the outer bolts in the front engine mount of my '54 3100. Seems like many of the fastener part numbers were industry standard numbers.
WBParts - Parts Procurement Service
Enter part number in box - upper right corner
May give discription of the part
BillyBob Parts Shop
by Larry R. Kephart
Stock Corvair Group
http://stock.corvair.org/wpmu/blog/2011/11/gm-fasteners-table/
Plymouth: The First Decade
http://www.ply33.com/parts/group18
GMPartsWiki is also a good source. It has been posted by Stovebolters before.
http://www.gmpartswiki.com/query
The MPC has standard hardware items, but only a few of the numbers match the numbers in the Assembly Manual.
> Standard Parts Listing 1929 - 1954
8.899
p.473 - p.482
http://chevy.oldcarmanualproject.com/1929_54chevyparts/08/473.HTM
> Standard Parts Listing 1929 - 1957
8.899
p.641 - p.652
http://chevy.oldcarmanualproject.com/1929_57chevyparts/57cmpc0641.htm
Also, illustration indexes in the Master parts Catalogs ...
> Illustration Index 1929 - 1954 MPC
http://chevy.oldcarmanualproject.com/1929_54chevyparts/info/039.HTM
> Illustration Index 1929 - 1957 MPC
Primarily '49 - '57
http://chevy.oldcarmanualproject.com/1929_57chevyparts/57cmpc0055.htm
http://chevy.oldcarmanualproject.com/1929_54chevyparts/00/093.HTM
> Here are abbreviations used in the MPC that may help define the type of fastner
http://chevy.oldcarmanualproject.com/1929_54chevyparts/info/005.HTM
My post discussing this information in a recent thread
https://www.stovebolt.com/ubbthreads/ubbthreads.php?ubb=showflat&Number=897093#Post897093
- Lonnie
- Lonnie
My '54 3104
Great post, Lonnie.
I started reading this topic several hours ago and ended up spending the better part of my day reading the links! Thanks for all the great information Lonnie. By the way, if you ever run into a link like this:
BillyBob Parts Shop
by Larry R. Kephart
prepare yourself for a great reading experience. I could read Laroke posts for hours and hours. grin
She's one 55 year old with a spare tire that looks good!
It's not rocket surgery. . . .
http://www.picturetrail.com/fredoly
http://www.cardomain.com/ride/2412127
Thanks, fredoly -
The fastener section of the BillyBob blog was the second link in my list. You're right - it is a good read.
- Lonnie
- Lonnie
My '54 3104
