1 members (Hotrod Lincoln),
104
Mod | | | Forums66 Topics128,089 Posts1,056,004 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2010 Posts: 171 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2010 Posts: 171 | The assembly manual calls out what. Screw. Nut bolt washer,etc to use in the building of the 54 1st series trucks. Question for the masses- is there a key somewhere for the callouts listed?
....David
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | ...I'm pretty much in the bolt with you! About all I know is that "LW" means "lock washer".
...maybe, IF you look up the part number in the master parts book the part number would probably say what it is??? I don't have a master parts book but if you look around there is some listed on line. ....or you have to do what I do when I don't remember. Use what fits or works better at the time! | | | | | Joined: Oct 2010 Posts: 1,232 'Bolter | | 'Bolter Joined: Oct 2010 Posts: 1,232 | It's really frustrating to have the diagram and the part number, but no way to know what size the nut or bolt is. Probably the best reference is the knowledge and experience of other Stovebolt.com forum members. Post a question about the specific bolt. I haven't found a reference that defines the bolt numbers in the Assembly Manual. A few of the nuts, bolts, and washers can be referenced in the "Standard Parts 8.900" group of the Master Parts Catelog with illustrations, but most of the hardware items in the MPC do not have the same number as in the Assembly Manual. The hardware item and dimentions are sometimes shown in the MPC section for the item that it attaches to, such as this listing for Group #0.002.If you do find the nut or bolt in the MPC, this list of abbreviations may help. The drawing in the Assembly Manual will sometimes show you if the bolt is a hex, square, clutch head, etc. You can sometimes find info on the item by doing a Google search of the part number and a brief description such as "bolt 3701135" for the outer bolts in the front engine mount of my '54 3100. Or, "washer 352282" for the middle washer on my '54 front engine mount. Here is one of the "washer 352282" hits that gave me thickness info available nowhere else ... http://www.wbparts.com/rfq/5310-00-447-2493.htmland info on "washer 365685", the end washer on the front motor mount at the same site ... http://www.wbparts.com/nsndetail.cfm?NIIN=004496420&pn=365685Try the site to search for other part numbers. I've found that some of the "bolt kits" or specific bolts sold by vendors are not correct, so don't assume that they know any more than you do. Bottom line - I don't have a good answer.
- Lonnie My '54 3104Photos that I have shared on Stovebolt via PhotoBucket are no longer available. Please contact me if you want a photo from an old post. lonniecook [at] aol [dot] com. I sold my '54 3104 12/12/2017, but I still visit Stovebolt. OLD STUFF ... houses, furniture, cars, wine ... I love it all | | | | | Joined: Aug 2011 Posts: 835 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 835 | Why don't we start a master list of fasteners? Look in the assembly manual, look at what is on your truck in that position, confirm the fastener type, length, thread ect.
Just doesn't seem like it would take that long to come up with a list cross-referenced to the assembly manual numbers.
Kurt | | | | | Joined: Jun 2007 Posts: 134 Shop Shark | | Shop Shark Joined: Jun 2007 Posts: 134 | | | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | I reccomend Larry's parts list all the time. Actually, i think it should be permanently added to the "Tech Tips" page.
Drew
| | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | I have see that in some cases different assembly plants might use different parts for some reason. Therefore the term "original" might be different for different vehicles built in different plants. For that reason I agree with Alvin, "use what fits"
~Jim
| | | | | Joined: Oct 2010 Posts: 1,232 'Bolter | | 'Bolter Joined: Oct 2010 Posts: 1,232 | Larry's list is a good start. His list includes this disclaimer regarding the correctness of the parts: "* These are not the "concours correct" fasteners. They are just what is currently mounted on BillyBob."
It took me only a few minutes to copy his info onto an Excel worksheet that can be easily sorted by part number, location, etc. I'll contact him to ask for his permission to distribute it. With a few tweaks, it could be updated as more info comes in from the forum.
- Lonnie My '54 3104Photos that I have shared on Stovebolt via PhotoBucket are no longer available. Please contact me if you want a photo from an old post. lonniecook [at] aol [dot] com. I sold my '54 3104 12/12/2017, but I still visit Stovebolt. OLD STUFF ... houses, furniture, cars, wine ... I love it all | | | | | Joined: Oct 2010 Posts: 1,232 'Bolter | | 'Bolter Joined: Oct 2010 Posts: 1,232 | I sent an email to Larry Kephart asking permission to use his data in an Excel workbook for us to use and update. He immediately responded with a thumbs up.
I have a draft of the Excel workbook. Send me a PM with your email address if you would like to see and critique it. Looking for ideas to make it simple, yet usable.
- Lonnie My '54 3104Photos that I have shared on Stovebolt via PhotoBucket are no longer available. Please contact me if you want a photo from an old post. lonniecook [at] aol [dot] com. I sold my '54 3104 12/12/2017, but I still visit Stovebolt. OLD STUFF ... houses, furniture, cars, wine ... I love it all | | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | Do I have to have an Excel program installed on my pc to look at it?
Drew
| | | | | Joined: Oct 2010 Posts: 1,232 'Bolter | | 'Bolter Joined: Oct 2010 Posts: 1,232 | Some of the IT gurus on the forum can answer better than I can.
Probably need Excel or a clone Excel program. I could save as a .pdf, but it would not be as flexible for finding parts.
- Lonnie My '54 3104Photos that I have shared on Stovebolt via PhotoBucket are no longer available. Please contact me if you want a photo from an old post. lonniecook [at] aol [dot] com. I sold my '54 3104 12/12/2017, but I still visit Stovebolt. OLD STUFF ... houses, furniture, cars, wine ... I love it all | | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | Why not build or export it in Google Docs and open it up to everyone? You could maintain control of input but open it to the public.
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Lonnie, Google Docs Spreadsheet might work if the Excel spreadsheet has no macros and does to do sophisticated list/table manipulations. http://www.google.com/google-d-s/spreadsheets/ | | | | | Joined: Oct 2010 Posts: 1,232 'Bolter | | 'Bolter Joined: Oct 2010 Posts: 1,232 | Thanks, CASO and Tim -
That looks like the solution. I exported the workbook to Google Docs. Now I gotta play with it to make it easy to use inside Google Docs. Probably won't get to post the first version until Sunday.
- Lonnie My '54 3104Photos that I have shared on Stovebolt via PhotoBucket are no longer available. Please contact me if you want a photo from an old post. lonniecook [at] aol [dot] com. I sold my '54 3104 12/12/2017, but I still visit Stovebolt. OLD STUFF ... houses, furniture, cars, wine ... I love it all | | | | | Joined: Aug 2011 Posts: 835 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 835 | Drew, To view the Excel files, download and install the free Open Office or Libre Office suite. Drop in replacement for Microsoft Office, and will load and read Excel files. Link to Libre Office This very high quality software, We use it on all the workstations in my business. Kurt | | | | | Joined: Oct 2010 Posts: 171 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2010 Posts: 171 | Why don't we start a master list of fasteners? Look in the assembly manual, look at what is on your truck in that position, confirm the fastener type, length, thread ect.
Just doesn't seem like it would take that long to come up with a list cross-referenced to the assembly manual numbers. That's what I was thinking. Thanks for the direction
....David
| | | | | Joined: Aug 2011 Posts: 835 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 835 | Hey,
Your welcome. Looks like things are (were) already under way!
I'm going to keep track from now on. I may even take pictures of the fasteners as I remove them and make links!
Kurt | | | | | Joined: Oct 2010 Posts: 1,232 'Bolter | | 'Bolter Joined: Oct 2010 Posts: 1,232 | I finished the trial run of the spreadsheet with part numbers used in the Factory Assembly Manual based on the data that Larry Kephart and BillyBob started. I'm wide open for suggestions to make it easy to use. < CLICK > this link to the Google Docs spreadsheet. Looking for input on the "correct" way to list the dimentions of the nuts, bolts, washers, etc. I feel that the information must include the dimentions/descriptions of the original part, plus info on substitute parts that will work. I have space for both on the worksheet. I used to think that I was the cat's meow when it came to creating Excel spreadsheets. But I'm having a little trouble with the Google version. And when it comes to publishing for all to see and update - I'm befuddled. So, I guess this project moved me from wizzkid to dufus in one weekend! But it's a start. >> CASO and Tim - Have you worked with Google Docs to allow users to publish or submit info? I'll take any info, experiences, or suggestions that you can give me.
- Lonnie My '54 3104Photos that I have shared on Stovebolt via PhotoBucket are no longer available. Please contact me if you want a photo from an old post. lonniecook [at] aol [dot] com. I sold my '54 3104 12/12/2017, but I still visit Stovebolt. OLD STUFF ... houses, furniture, cars, wine ... I love it all | | | | | Joined: Apr 2004 Posts: 5,074 Authorized Pest | | Authorized Pest Joined: Apr 2004 Posts: 5,074 | Does the Google program allow you to add an image to anything? I know this Tech Tip took a while to build and get pictures, but for some folks, it is very helpful. I'm sure brainer people than I will jump in here. This would be a great Tech Tip. Thanks to all of you for taking the time to put the pieces together. Reminds me of the days we worked on those pages to identify your truck!  Glad (hopefully) things are getting better / easier. Peggy M
~ Peggy M 1949 Chevrolet 3804"Charlie" - The Stovebolt FlagshipIn the Gallery"We make a living by what we get; we make a life by what we give." -- Winston Churchill | | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | Peggyand Lonnie, I've messed with it a little and found its not that different than MS Works or whateva'... It's pretty friendly really. If you want to do a workgroup or something I'm up for a 'little' data arrangement. Drop me a PM and I'll send you my digits and we can talk. But if you can get Tim to do it so much the better!
| | | | | Joined: Jun 2013 Posts: 51 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2013 Posts: 51 | | | | | | Joined: Aug 2012 Posts: 45 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2012 Posts: 45 |
Is rust considered a body style?
| | | | | Joined: Apr 2005 Posts: 507 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 507 | LonnieC This look great and it crosses to MS Excel with ease when you down load. Lot of work went into this and I hope everyone will appreciate the amount of effort that was required.
A friend and I have been working on getting the similar doc for the 41 to 46 trucks.
Thank for the inspiration it helps to keep us going.
"If it ain't Steel it ain't Real" "Earth the insane aslyum for the rest of the Universe" 41 1/2-ton, a work in progress 68 Shortbed stepside 327/325hp/700R4
| | | | | Joined: Oct 2010 Posts: 1,232 'Bolter | | 'Bolter Joined: Oct 2010 Posts: 1,232 | Hey guys - I have pretty much dropped the ball on creating and updating a database for fasteners. Anybody want to take over? Send me a PM, I'll give you the plan that I had in mind when I started it. In the mean time, here are links to sources of info that I use when I am researching a part number to learn the description (Length, Diam, Thread pitch, Head, etc): ======== You can sometimes find info on the item by doing a Google search of the part number and a brief description such as "bolt 3701135" for the outer bolts in the front engine mount of my '54 3100. Seems like many of the fastener part numbers were industry standard numbers. WBParts - Parts Procurement Service Enter part number in box - upper right corner May give discription of the part http://www.wbparts.com/BillyBob Parts Shop by Larry R. Kephart http://www.laroke.com/larryk4674/2005/bbpartshp2.htmStock Corvair Group http://stock.corvair.org/wpmu/blog/2011/11/gm-fasteners-table/Plymouth: The First Decade http://www.ply33.com/parts/group18GMPartsWiki is also a good source. It has been posted by Stovebolters before. http://www.gmpartswiki.com/queryThe MPC has standard hardware items, but only a few of the numbers match the numbers in the Assembly Manual. > Standard Parts Listing 1929 - 1954 8.899 p.473 - p.482 http://chevy.oldcarmanualproject.com/1929_54chevyparts/08/473.HTM> Standard Parts Listing 1929 - 1957 8.899 p.641 - p.652 http://chevy.oldcarmanualproject.com/1929_57chevyparts/57cmpc0641.htmAlso, illustration indexes in the Master parts Catalogs ... > Illustration Index 1929 - 1954 MPC http://chevy.oldcarmanualproject.com/1929_54chevyparts/info/039.HTM> Illustration Index 1929 - 1957 MPC Primarily '49 - '57 http://chevy.oldcarmanualproject.com/1929_57chevyparts/57cmpc0055.htmThe hardware item and dimentions are sometimes shown in the MPC section for the item that it attaches to, such as this listing for Group #0.002. http://chevy.oldcarmanualproject.com/1929_54chevyparts/00/093.HTM> Here are abbreviations used in the MPC that may help define the type of fastner http://chevy.oldcarmanualproject.com/1929_54chevyparts/info/005.HTMMy post discussing this information in a recent thread https://www.stovebolt.com/ubbthreads/ubbthreads.php?ubb=showflat&Number=897093#Post897093- Lonnie
- Lonnie My '54 3104Photos that I have shared on Stovebolt via PhotoBucket are no longer available. Please contact me if you want a photo from an old post. lonniecook [at] aol [dot] com. I sold my '54 3104 12/12/2017, but I still visit Stovebolt. OLD STUFF ... houses, furniture, cars, wine ... I love it all | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | | | | | | Joined: Jul 2006 Posts: 183 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 183 | I started reading this topic several hours ago and ended up spending the better part of my day reading the links! Thanks for all the great information Lonnie. By the way, if you ever run into a link like this: BillyBob Parts Shop by Larry R. Kephart http://www.laroke.com/larryk4674/2005/bbpartshp2.htmprepare yourself for a great reading experience. I could read Laroke posts for hours and hours.  | | | | | Joined: Oct 2010 Posts: 1,232 'Bolter | | 'Bolter Joined: Oct 2010 Posts: 1,232 | Thanks, fredoly -
The fastener section of the BillyBob blog was the second link in my list. You're right - it is a good read.
- Lonnie
