2 members (BC59, Danielbolt),
210
Mod | | | Forums66 Topics128,149 Posts1,056,817 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2005 Posts: 946 'Bolter | | 'Bolter Joined: Jul 2005 Posts: 946 | I have a 190 degree thermostat in my 350. It stays there most of the time but will increase to 210 when 4 wheel drive and tooling around.
Just wondering the optimal operating temp? Is cooler better? What are the negatives of removing the thermostat? I live in Florida so it almost never gets cold.
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | removing the stat completely will result in overheating, although some folks take the center part out, leaving the surrounding "big washer" to maintain a flow restriction .... around 200 is good for a small block with a 14# cap on a rad that can take that pressure - slightly higher temps expected if you're working it harder
Bill | | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | Do you have a fan shroud? That may help cool it when your working it. You could try a 180 state. How close is the fan blade to the radiator? If its to far away the fan could be not moving enough air. | | | | | Joined: Feb 2004 Posts: 29,850 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,850 | With a 195 stat and a 14-17 lb. radiator cap the normal operating range will be from about 190 to 220 or so. That's what the engine was designed and clearanced to do. It won't even begin to boil any coolant until it reaches almost 250 if the radiator cap and hoses are in good condition. The only limiting factor will be your heater core, which was designed for a 7 lb. cap if you're talking about your 4X4 NAPCO. Jerry
| | | | | Joined: Oct 2007 Posts: 231 Shop Shark | | Shop Shark Joined: Oct 2007 Posts: 231 | I've always had an understanding that 350s run a little hot 210-220 range. | | | | | Joined: Jul 2005 Posts: 946 'Bolter | | 'Bolter Joined: Jul 2005 Posts: 946 | I have an electric fan, and the engine never gets above 215 even on the hottest days in Florida, so it looks like I'm in the good range. I guess what seems hot to a human isn't so hot to a Chevy 350.
Out of curiosity, why would the engine overheat with the thermostat completely removed? | | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | It won't unless there is another problem with the cooling system. Removing the thermostat will not fix any problem would be a better way to put it. Out of curiosity, why would the engine overheat with the thermostat completely removed? | | | | | Joined: Feb 2006 Posts: 1,867 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 1,867 | Out of curiosity, why would the engine overheat with the thermostat completely removed? It will if you end up sitting in traffic. The water flow through the engine and radiator doesn't have a chance to cool since it is being constantly flushed through. While driving, this isn't as big of an issue as all the airflow pushed through the radiator helps. Sitting in traffic, you only have what the fan can pull through the radiator while the water is constantly flushing. Not enough. I have never used anything above a 180 degree thermostat in a small block and have had no issues. Once I tried a 160 and the heater would not function due to the water temps. We do not have climactic extremes of heat or cold during the seasons here in the PNW, but I imagine you get fairly warm in summer. Running without a thermostat decreases gas mileage a bit and can create issues tryng to warm up an engine. Jeff | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | if the thermostat is completely removed, there is a problem with the system, the water flow is too fast to pick up enough heat from the engine and too fast to achieve the design cooling from the rad - things might work fine under some ambient temps and loading, but the Generals engineers had good reason to design the system as they did .... by removing just the thermostatic portion of the stat, the 'doughnut' left in place keeps a restriction to control the rate of flow to the original design, you just lose the precise control of temp range set by the stat rating .... and these engines do work best and last longest run at the design temps
Bill | | | | | Joined: Feb 2004 Posts: 29,850 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,850 | The main concern with running without a thermostat isn't overheating, although the dwell time of the coolant in the radiator could be an issue. All engines are designed so the parts establish a correct running clearance at a particular temperature, and the 350 is designed to run around 200 degrees or hotter. I can usually spot an engine that's been run without a thermostat when I tear it down for a rebuild by looking for a thin shiny area in the middle of the piston skirt. An engine that has been run at the right temp will have a much wider piston-to-cylinder contact patch because the piston heats up and gets round at the proper operating temp. Bearing clearances also get right when the crankshaft and rods run at the correct temperature, and the rings expand to minimize blowby. Jerry
| | | | | Joined: Jul 2005 Posts: 946 'Bolter | | 'Bolter Joined: Jul 2005 Posts: 946 | Thanks, I definitely learned something new today. It makes perfect sense that the radiator wouldn't have enough time to cool the water. | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | 175 thermostat and 14# cap. She runs at 190/205
~Jim
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Jerry, you are spot on. Thanks for the reminder!! | | |
