| | | Forums66 Topics128,050 Posts1,055,757 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#83902 10/08/2007 4:51 AM | Joined: Nov 2003 Posts: 236 Shop Shark | | Shop Shark Joined: Nov 2003 Posts: 236 | What are your opinions of the 3:55 rear end for a 52, 1/2 ton? Would a basic wrench be able to do it? I don't see anything in the archives.
Glenn, | | |
#83903 10/08/2007 1:35 PM | Joined: Aug 2001 Posts: 1,299 'Bolter | | 'Bolter Joined: Aug 2001 Posts: 1,299 | I have collected the parts but have not installed them yet. There is actually an installation article in the Tech Tips section I believe. Others that have done it say it was pretty straightforward. | | |
#83904 10/08/2007 1:56 PM | Joined: May 2000 Posts: 424 Shop Shark | | Shop Shark Joined: May 2000 Posts: 424 | It's easier than you think, Glenn. Patrick's has very good step-by-step directions included with the gears. I have an extra set of 3.55 gears here if you would like to look over the parts and instructions before ordering. Way back when I did mine, (early '90's when they first came out) I set the 3.55 gears up in another torque tube/carrier so that I could keep my stock 4.11's intact when I swapped the gears. That way, I figured if anything went wrong, or I didn't like the 3.55's, I could just swap back to the way it was. That old 4.11 has laid on the floor for almost 15 years now, I would never go back to it. | | |
#83905 10/08/2007 2:33 PM | Joined: Nov 2003 Posts: 236 Shop Shark | | Shop Shark Joined: Nov 2003 Posts: 236 | Thx Greg. I'll go to the tech tips. Barry I'll give you a call.
Glenn, | | |
#83906 10/08/2007 9:57 PM | Joined: Apr 2005 Posts: 507 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 507 | I have a set of 3.55 gears in my 41 1/2 ton with a early 60's 235 and would not trade them for anything. Stock torque tube and front disk brakes makes for a nice freeway cruiser. Gears are from Patrick's, great parts and great instruction's and phone help.
"If it ain't Steel it ain't Real" "Earth the insane aslyum for the rest of the Universe" 41 1/2-ton, a work in progress 68 Shortbed stepside 327/325hp/700R4
#83907 10/08/2007 10:17 PM | Joined: Feb 2006 Posts: 1,867 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 1,867 | I hated their instructions, actually just the pictures. Instructions were good but the pictures looked like theyd been photocopied about 100 times over. Still got it done, and runs wonderfully. Its pretty simple, the hardest part for me was reading the bluing on the ring gear teeth, didnt show up real well on the black of the tooth. Id suggest finding white lead or something similar rather then the bluing. Go for it, its just money! Jeff | | |
#83908 10/09/2007 3:24 AM | Joined: Aug 2004 Posts: 1,418 ODSS Lawman | | ODSS Lawman Joined: Aug 2004 Posts: 1,418 | As long as you have a good attention to detail, this swap is straight forward. I have done two to date, and both run VERY well. I too can be added to the "one of the best things to do" list.
SWEET Sergeant At Arms: Old Dominion Stovebolt Society BUNS?!?!?!Where we're going, we don't need no buns.....1950 GMC 450 1951 Chevy 1/2-TonThe GreenMachineIn the Stovebolt Gallery | | |
