5 members (klhansen, 2-Ton, Gray_Ghost, mason86, Charles in CA), 100 guests, and 1 robot.
Topics128,069
Posts1,055,886
Members48,428
#83688 10/02/2007 8:29 PM
This is probably a dumb question but....what is the purpose of the metal strips that bolt to the exaust manifold on the '283?? Is it to hold the bolts tight? There are little bent clips at the bolts.
Mine are total junk and rusted out. Do I need to replace?
sovagary
GS
#83689 10/02/2007 8:53 PM
Are you talking about the metal pieces that are curved at both ends and 4-5 inches long? If so they may be the heat shields that help protect the boots on your plug wires.
Bruce
Old Toy: Ol' Betsy stock 59 Apache SB Stepside (Gone but not Forgotten)
New Toy: 1962 Impala SS Coupe
The Driver: 1990 Toyota truck
#83690 10/02/2007 9:17 PM
They are locking devices for the mount bolts. The torque on the exhaust bolts are pretty low (I think 20ft lbs.)
FYI - You can get 2 1/2" manifolds for your 283 a Orieley's for around $70 each. They are made in China, but seem to be a good piece to use to open up the exhaust. They are modeled after the early 60's corvette manifold.
#83691 10/02/2007 10:32 PM
Thanks for this info Builer. Do these Chinese manifolds have the generator bolt/bracket bosses on the drivers side manifold?
Just wondering because I've seen a lot of Chineses castings that were of poor design and quality.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
#83692 10/02/2007 11:06 PM
Riding in the Passing Lane
Ive never replaced them. If you tighten the bolts down good they stay. If you want an original look then you would want to find some new ones. I also don,t use the gaskets that come with the sets. They will get you in trouble. That sounds like a good deal on those manifolds. The original ones are very rare. You wouldn,t need them on a 283 unless it is hopped up pretty good.
1972 Chevy c10 Cheyenne Super
#83693 10/03/2007 1:19 AM
If those are "bolt keepers", can I obtain some?
I've not seen any in my catalogs. Are they that necessary?
Note: I have the spark plug heat shields already.
thanks again.
sovagary
GS
#83694 10/03/2007 2:09 PM
You could take a small drill bit and drill through the bolt head. Then tie them together with wire.
Torque these bolts. Don't over tighten them.
#83695 10/03/2007 4:45 PM
Builder....again I ask:
"Thanks for this info Builer. Do these Chinese manifolds have the generator bolt/bracket bosses on the drivers side manifold?"
Thanks.
Dave
#83696 10/03/2007 7:09 PM
53moneypit,
Yes the manifolds have the generator brackets. Here is the link.
http://www.oreillyauto.com/EW3/GetStoreByZip.do
#83697 10/04/2007 1:33 AM
the safety wire trick is the best thing since sliced bread.
dj
dj durant
More pix on Flickr
