2 members (klhansen, 59 fleet),
130
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,157 Posts1,056,874 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2012 Posts: 6 New Guy | | New Guy Joined: Feb 2012 Posts: 6 | [IMG] http://i29.photobucket.com/albums/c283/bondovian/Cabovers/Picture13-1.png[/IMG] Hey guys...love this place. Just receive my new 47COE that I purchased from MN. This truck is all original an in wonderful shape.It has a twin cylinder dump bed on it hat i cant wait to get fired up. My first concern is to get this thing running. To do that, i nee an ignition key for it. Does anyone sell new ignition switches with a key that i could install? Im sure this thing would fire up with some new gas, oil, battery. Hope to get to know most of you guys and learn all i can about these old beauties. Thanks, Jeff
| | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | Many ign. switches are so worn, any key will fit. Most locksmiths or keymakers will have blank GM keys. Look around, under the seat, etc., you might find one there. For now, just hotwire it.
Interesting truck. Gasser? What engine does it have? Ser. No. will start w/ displacement, i. e. 302xxxx, or 360zzzz, stamped on a machined pad behind the distr. on some.
Good luck
| | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | Nice COE. I've been seeing it on ebay, & Craigslist. i was hoping a streetrodder didn't get it. I think, I read that the tandem wasn't original to it. What series is it? What are your plans for it? | | | | | Joined: Dec 2003 Posts: 1,144 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 1,144 | You don't have to have an ignition key just to start tinkering. You can run a hot wire from starter or battery to battery side of coil. A cheap briggs and stratton lawnmower switch will work ignore the selanoid hot post if you have a floor stomp starter. Would suggest you do a search of this site for tips on waking a long dormant engine could save you from doing more harm than good. I bent a push rod on a 54 due to a stuck valve could have been avoided if I had checked a little closer. Cool Truck look forward to your adventure. Before you start determine whether the truck is positive or negative ground.
| | | | | Joined: Feb 2012 Posts: 6 New Guy | | New Guy Joined: Feb 2012 Posts: 6 | Thanks for the tips. How do I determine if its a positive or negative ground? I plan on going through it pretty good before trying to start it. The previous owner said it ran when it was parked so I'm hoping for the best.
Yes, it supposedly has a twin cylinder 71 dump frame underneath it. All i know is, this this is beefy. Cant wait to get it going. My plan is to keep it original but to convert it to single rear axle. Interior is in great shape and everything seems to work. Needs some glass replaced but everything is flat so shouldn't be very hard. I will keep you posted on progress. Thanks all for the tips. keep em' coming. | | | | | Joined: Mar 2011 Posts: 667 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 667 | Welcome to the Loony Bin! Great looking COE (how could anybody NOT love the face!?) If you search this site you will likely find the source for a manual with most of the specs & info you need. And don't rush the engine start, as kb3 noted, you can trash an otherwise good engine turning it over before checking it out. Good luck and do keep the pix coming, you've got a real sweetheart there. | | | | | Joined: Dec 2003 Posts: 1,144 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 1,144 | GMC's prior to 54 came standard positive ground, could have been changed at some point though. go to electrical bay forum there will be posts there already if you do a search. If old battery is still in there check how it is wired. Ask previous owner if he is the one who actually last ran truck.
| | | | | Joined: Nov 2006 Posts: 173 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 173 | Nice truck! I Looked at that one on C'list, even printed it out in case I hit the power ball. How big a big bolt is it? Good luck with it.
1947, 1950, & 1952 Chevrolet 1/2 ton 1952 GMC 450 series Cab Over Engine 1946 Chevrolet 2 Ton
| | | | | Joined: Jan 2010 Posts: 37 New Guy | | New Guy Joined: Jan 2010 Posts: 37 | Great truck, I was admiring it on ebay. Should be a really nice one to enjoy.
| | | | | Joined: Feb 2012 Posts: 6 New Guy | | New Guy Joined: Feb 2012 Posts: 6 | http://i29.photobucket.com/albums/c283/bondovian/photo-5.jpgGuys, here is a data plate I found on the side of the trans. Let me know what you see. Don't know much about these things so any info would help. Also, looks like it's a positive ground. No battery. Do these trucks have 2 starters? If so, mine is missing one. o i need both? Do i need a 6V battery? And where can I get a new starter for this thing? Thanks! Here is the album with more pictures. http://s29.photobucket.com/albums/c283/bondovian/Cabovers/
| | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | Only need one starter, 'Missing one' might be blank hole not blocked off. 6V starter will work fine on 12V, just don't lay on it. As was said before, remove valve cover and make sure no valves are stuck. Did you figure out what engine? Px?
| | | | | Joined: Feb 2012 Posts: 6 New Guy | | New Guy Joined: Feb 2012 Posts: 6 | Thanks for the info. I've posted new pictures of the interior including the power plant. Now I just need to get this thing titled.
JB | | | | | Joined: Feb 2006 Posts: 1,867 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 1,867 | The engine in question will be anywhere in displacement from 308-503. I have no clue what the original displacement would be. I've even heard tell of a 707, but I'm not sure if that even uses the same block casting? Do the big GMC 6's have the displacement on a pad by the distributor like the smaller 6's?
As mentioned above, I saw that on ebay as well. Nice find! Take more pictures!
Jeff | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | I've never seen one in real life(big block) but I'm sure they are stamped there.
| | | | | Joined: Mar 2004 Posts: 6,232 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,232 | Before the mid 1950's the engine serial number was used by many States as the vehicle ID number. You need to contact you MVA to find out what the next step is... Mike B  | | | | | Joined: Feb 2006 Posts: 1,867 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 1,867 | | | | | | Joined: Feb 2012 Posts: 6 New Guy | | New Guy Joined: Feb 2012 Posts: 6 | Why cant I find any info on this engine on the internet? Who made it, what parts are available....etc.? i figured it was the 361 power plant. i will be checking valves and giving it a tune-up this weekend to try and get her running. yes, i will check with the BMV to see about getting a title.
thanks!
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy 1938COE, the 361 engine was built by GMC, and as rustednuts has said it is one of a series of engines that range from a 278 cu. in. to a 503 cu. in.. These are an interesting group of engines, where most inline sixes can be broken down into two major pieces, (block and head), this series of engines can be broken down into three major pieces, crankcase, cylinder bank, and head, these engines also have a different firing order than their smaller cousins 142635 rather than the smaller engines 153624. According to my Motors manual your truck is probably a 600 series with that engine in it, hope that helps.
| | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | The "A" before the 361, probably indicates it was rebuilt at some point in its life.
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | That truck is a beauty! Are both those axles live? You should sign up on this site Old GMC Trucks.com as they have a lot of GMC owners on there. If you look down to the bottom of the page on that site you will see a link to their other site which is static but packed with all kinds of information including number decoders. | | | | | Joined: Jan 2008 Posts: 4,962 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,962 | The A or B in front of the displacement is a bore designation that GMC used and does not mean that the engine was rebuilt. GMC used the 361 from the late 40's until the mid 50's. However, it was offered in a size of trucks that never gained much popularity. Many people considered it cheaper to overload a two ton. Not many of the 361 engines were built. Few survived. The engines were too big to put into a pickup, so there was very little interest in saving them. About the only parts you will find will be NOS. | | | | | Joined: Apr 2010 Posts: 474 Shop Shark | | Shop Shark Joined: Apr 2010 Posts: 474 | One of my favorite trucks good luck with your build! Im still looking for a COE. | | | | | Joined: Dec 2011 Posts: 90 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2011 Posts: 90 | Wow that looks great! Good luck with the build | | |
