5 members (3B, DennisM, 52hornsby, Gdads51, dt235sd), 81 guests, and 0 robots.
Topics128,049
Posts1,055,693
#829198 02/24/2012 2:37 AM
Hi I replaced the muffler on my 68 k-20 292 engine with a Walker 21169 heavy duty muffler it has a whistling sound under acceleration any ideas of what the problem is?
Drive it around until a black stain shows up then you'll know where your leak is,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
Are you sure its not on backwards?
Riding in the Passing Lane
What size pipe is it? 292,s need a minimum restriction exhaust system. Some of these mufflers are restictive to make them quite. Or like Durwood says maybe its on backwards.
1972 Chevy c10 Cheyenne Super
the pipe size is 2 inch the muffler is marked inlet it is heavy duty replacement for the stock muffler walker 21331.
Are you sure you don't have a vacuum leak?
Harold Wilson
41 Chevy 3/4 Ton
