0 members (),
113
Mod | | | Forums66 Topics128,101 Posts1,056,180 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#82994 09/15/2007 6:15 PM | Joined: Jan 2007 Posts: 81 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2007 Posts: 81 | I previously posted smoking problem with 1960 235 engine under heading of "stumped". I appreciated the several suggestions offered by fellow bolts. Relevant information is: engine rebuilt by local machine shop for PO but never started. Many pieces missing. Confirmed rebuild with machine shop owner. Scrounged/fabricated throttle linkage, installed distributor, wired engine. Installed rebuilt Rochester carb and rebuilt fuel pump.When started, got the expected smoke, etc. After being run some, it still puffed blue smoke after warm. When idling, exhaust was constantly brown and did not smell right. Plugs were initially oily, but after driving some, changed to dry black powder. still had blue smoke in puffs. Poured Sea Foam in all cylinders and let it set for two days. All plugs always identical appearance. Following previous bolt suggestion, performed ring seating procedure prescribed on Hastings web site. Perhaps not as much smoke but exhaust still not clean. Still brown at idle. Installed Felpro umbrella valve stem seals. Observed that both valve guides and valves were new and fit perfectly.. At the same time, retorked head,reset timing, adjusted valves to specs. Set carb float level. Truck runs great, pulls good. Has 145 psi compression all cylinders. Do not have brown smoke now at idle. Blue smoke now is intermittent..hot or cold. Sometimes puffs blue quite bad, other times not at all with exhaust appearing normal. Plugs still accumulate black carbon powder that wipes off dry. No burned oil residue. Engine now has about 300 miles on it and has had the oil changed one time. Engine is obviously running rich but can't tell it by driving it. Carburetor was correct part according to O'reilys. I can buy another carb from a different source but my burning (no pun intended)question is: where is the intermittent blue smoke coming from?. I have tried to anticipate all questions and have tried to answer them so as not to waste your time. meansam | | |
#82995 09/15/2007 10:03 PM | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | One posibility is ring alignment. If the rings weren't correctly indexed the gaps might be lining up on occasion, allowing some oil to blow by.
#82996 09/15/2007 10:40 PM | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | Are you losing oil? How much did you add between oil changes? If you're not losing much oil I would say you're running a little rich, Scott | | |
#82997 09/16/2007 3:01 PM | Joined: Jan 2007 Posts: 81 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2007 Posts: 81 | I have added one quart, but did lose some oil while adjusting valves. I also had an oil filter (ferrel connection) come loose. Luckily I was just moving it a few feet down the curb when it came loose. Had to refil from that. I gave up on the ferrel fittings and replaced completely with hydraulic lines. meansam | | |
#82998 09/16/2007 11:02 PM | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Blue smoke is going to be oil. You've only got about 300 miles on it, there's a good chance the rings aren't fully seated yet. I'd say most likely, you're getting oil past the rings, either from ring misalignment as mentioned earlier, or that they're not seated to the bores fully yet. Running rich will agrivate that problem due to the gas washing the oil from the cylinder walls.
Bill Burmeister | | |
#82999 09/16/2007 11:33 PM | Joined: Jul 2007 Posts: 6 Junior Member | | Junior Member Joined: Jul 2007 Posts: 6 | If you are running a detergent multi viscocity oil, changing to a non-detergent straight viscocity lubricant will often make a huge difference in smoke emissions. | | |
#83000 09/17/2007 10:25 PM | Joined: Feb 2007 Posts: 230 Shop Shark | | Shop Shark Joined: Feb 2007 Posts: 230 | Blue smoke is oil, has nothing to do with carburetion. Rebuilt engines in my experience do not puff large amounts of blue every now and then. dIn fact, a rebuilt may not burn oil at all (I have seen that lots of times), or if it does, burns a little blue steadily until the rings fully seat. I think you have some oil leak down from a valve guide. Or they cracked a ring or ring land when they installed the pistons (that's easy to do if you are not careful). For my 2 cents, I would not do anything else and run it for about 1000 miles. If it has the same problem, start tearing down begining with the heads. When you pull the heads off, take a look for a vertical scratch or discoloration on a cylinder wall. Or take it back to the machine shop if they warranty their work. | | |
#83001 09/17/2007 10:56 PM | Joined: Feb 2004 Posts: 29,799 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,799 | I'd suggest giving it a little more break-in time, and monitor the oil consumption carefully. You might need to re-jet the carburetor a bit leaner, or install a power piston spring of a little lighter tension, to prevent the mixture from going full rich with a slight amount of load on the engine.
Rings rotate around the piston all the time, so the idea of the gaps aligning and causing oil consumption is a myth. They do align occasionally, but they don't stay that way long. If you're using a rail and expander type of oil ring, it's almost impossible to get the rail gaps lined up, unless the scraper rails were deliberately installed that way. Even then, both the compression ring and middle ring gaps would have to line up, and the gap would be a matter of only a few thousandths on a warmed-up engine.
If the smoke is still there at the 2500-mile mark, or oil consumption increases noticeably, a teardown might be in order. Jerry
#83002 09/18/2007 6:43 AM | Joined: Jun 2006 Posts: 85 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2006 Posts: 85 | Meansam does this engine have a PCV system? I would check to see if the PCV valve is not sticking and drawing oil upinto the intake system. I also agree with HOTROD dirve it a little longer!! good luck DS | | |
#83003 09/18/2007 7:48 AM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | On the carb, make sure the gasket or spacer has the little notch cut out in it. There is a vacuum passage there that needs to be open for the power valve to work right.
Also, do you have power brakes or an automatic transmission with a vacuum modulator valve? One of those might be leaking into the engine.
#83004 09/18/2007 4:31 PM | Joined: Feb 2007 Posts: 230 Shop Shark | | Shop Shark Joined: Feb 2007 Posts: 230 | I would like to know from Hotrod Lincoln how he knows that rings rotate around the pistons all the time. I ask this question respectfully, because I have never heard it before and I want to learn. | | |
#83005 09/18/2007 6:28 PM | Joined: Apr 2006 Posts: 20 Shop Shark | | Shop Shark Joined: Apr 2006 Posts: 20 | me too I did not think the rings rotated but the little problem this motor sounds to have is the carb is out of wack and the motor may not be broken in all the way, does your motor have a oil air breather or a paper air filter. Mine blew some smoke when I ran it early on cause the air filter full of oil was suckin a lot of oil and lets say it smoked pretty heavy. Them oil air filters need to have instruction manuals | | |
#83006 09/19/2007 1:16 AM | Joined: Jan 2007 Posts: 81 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2007 Posts: 81 | Thanks for all the comments and suggestions. There is no pcv valve. no automatic transmission. No pwr brakes. I suspect any ring rotation is random, so any ring alignment would also be random. The comment by 4onthefloor interests me. I remember seeing the notch, but could see no reason for its being so it may be installed such as to block vacuum into the pwr valve, which, I suppose would make it want to open. As I mentioned in my opening list of things that the engine did not run such as to suggest it is running rich. Only the plugs indicate it is running rich. I will check the notch. It must need to align with a hole or notch on the carburetor base. meansam | | |
#83007 09/19/2007 4:42 PM | Joined: Feb 2004 Posts: 29,799 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,799 | At several of the schools I've attended, they have had engines with see-through cylinders, made of either tempered glass or quartz. I've used a delay-flash timing light, and watched the rings rotate. Perfect Circle Piston Ring Co. had a 216 stovebolt engine in their school several years ago (mid-50's) with a couple of glass cylinders installed. Really interesting to watch the flame travel, and color change while tinkering with mixture and timing! Jerry
#83008 09/19/2007 7:08 PM | Joined: Apr 2005 Posts: 1,971 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,971 | I always assumed that piston rings may move slightly from their original placement until they found their "groove", and that if they were turning it could be indicitive of a bent rod. | | |
#83009 09/19/2007 8:12 PM | Joined: Nov 2005 Posts: 1,554 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,554 | I recall on some 2 cycle engines I've worked on that there is a pin that the gap on the rings fit into to keep it from rotating. What gives with that? Dave 1941 Chevy"First rebuild - complete!"Follow the story in the DITY1941 GMC resting peacefully 1946/1947 Chevy Street rod on s10 frame complete 1945 GMC panel truck in line for restoration 1941 Plymouth stock complete 1941 GMC COE in restoration processRead his Project Journal1941 Chevy Coe uncertain future resting now
#83010 09/19/2007 8:23 PM | Joined: Mar 2007 Posts: 28 Apprentice | | Apprentice Joined: Mar 2007 Posts: 28 | Small two cycle engines have an intake and exhaust port cut into the cylinder wall instead of valves and the pin is to keep the ends of the rings from getting around to that area where they would catch on the edge of the ports. Richard
Life is simpler if you plow around the stump.
#83011 09/19/2007 9:22 PM | Joined: Nov 2005 Posts: 1,554 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,554 | I keep learning all the time on this site, it's like an on going education. Thanks folks. Dave 1941 Chevy"First rebuild - complete!"Follow the story in the DITY1941 GMC resting peacefully 1946/1947 Chevy Street rod on s10 frame complete 1945 GMC panel truck in line for restoration 1941 Plymouth stock complete 1941 GMC COE in restoration processRead his Project Journal1941 Chevy Coe uncertain future resting now
