3 members (55shaker, Bill Hanlon, 1 invisible), 54 guests, and 3 robots.
Topics128,037
Posts1,055,463
Members48,422
#825891 02/13/2012 9:33 PM
I printed out the great tech tip on Advanced design hood alignment, unfortunately the instructions say to attach the support bracket to cab a fender and " measure from center of bolt head to edge of bracket", I have 2 bolts at the cab holding the support bracket , which do I measure from and to where on fender bracket (back or front)
just-a-hacker
'49 3100 before '99
Measure from the bolt closest to the fender. It shouldn't matter much whether you use the front, back, or middle of the fender bracket. Chances are you will have to re-adjust these rods to fine tune how the hood fits between the fenders.
Chuck
Hookalatch #825903 02/13/2012 10:09 PM
THANKS ,that makes sense
Now just a little hood work (it has a tweak from catching on lip)
the drivers side is a ways off from the 27 1/4 recommended (almost 28"),passenger side pretty close to 27"
just-a-hacker
'49 3100 before '99
I just looked at this tech tip as my hood is out by an inch Would this work on a 58
Rick
58 3600 4 on the floor
rickyt #829631 02/25/2012 4:31 PM
Can someone send mea link for this tip?
Freds55 #829649 02/25/2012 5:08 PM
Ok i just did a seach for Hood adjustment and went pape to page and can only find procedures for 1st series trucks. Mine is a 1955 GMC 2nd series and I havent been able to find any adjustment tips or procedures for this. Hope someone one can help.I would look in a manual if I had one but dont have that either.
Thanks Fred
Freds55 #829650 02/25/2012 5:11 PM
Look at the Menu at the top of this page:
click on Tech Tips
Under "General Help", click on Body Work
click on Hood Alignment on Advance Design (1947-1954) Trucks
(1947-1955st)
Another procedure is given in the Shop Manuals during Advance-Design years.
Unless i am missing something the tech tip listed is for 1st series only. Reading the article the hinge bolts are different than a 1955 GMC 2nd series.
thanks again
Freds55 #829663 02/25/2012 6:00 PM
yes Fred, the tip is for the AD's, the shop manual has some help .... for the TF [BlueChip] trucks, the thing to do is assemble things loosely so you can move various parts a bit as you go, and be aware of the adjustment possibilities using the lower rad core support mounts [shimming] .... there's minimal adjustment possible at both sides of the hinges, up/down and forward/back .... if you have a problem with the back of the hood wanting to push up away from the cowl you have worn hinge pins .... hope that helps, but if you have specific problems just ask
Flxible #829770 02/26/2012 12:59 AM
Thanks Bill
all give it go.
Freds55 #829851 02/26/2012 4:49 AM
...not sure about the TF but if you can do it without the hood springs I'd certainly advise adjusting the "gaps" at the cowing first before hooking up the springs.
