Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
0 members (), 37 guests, and 5 robots.
Topics128,009
Posts1,055,293
Members48,419
#827835 02/19/2012 7:10 PM
Hi all -
I've recently rebuilt a 235 distributor. I thought I would give is a simple test with my continuity testor. With the cap on, should I be able to put one lead where the coil plugs in (center) and another lead in any of the plugs and get a complete circuit at points when I turn the shaft?
I'm curious if the roter actually touches the contacts in the cap, or does it just arc because its so close?
Mark
I don't think it touches, because if it did, it would soon score the cap contacts, and then it wouldn't touch anyway.
Kurt
No touch.
My Blog
I was recently cleaning some old tachometers and needed a way to check them. I used a 250 inline 6 distributor and a battery. I chucked the distributor shaft in my drill press with the cap facing down. Using the slowest speed and a rubber stopper (to keep housing from turning) I was able to check the meters at a set rpm. I had four meters hooked up at once so it was easy to see which ones didn't read right!
Four a quick test, it worked really good with no problems.
Joe
Tachs generally sense the points opening & closing, which is the first part of distributor function...unless you have a clamp-on type, which senses secondary signal through a plug wire.
cm
If you can't fix it with a hammer and screwdriver, you need a bigger hammer.
1965 Chevy C10
