2 members (Peggy M, baldeagle),
49
Mod | | | Forums66 Topics128,005 Posts1,055,264 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2010 Posts: 575 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 575 | Hi all -
I've recently rebuilt a 235 distributor. I thought I would give is a simple test with my continuity testor. With the cap on, should I be able to put one lead where the coil plugs in (center) and another lead in any of the plugs and get a complete circuit at points when I turn the shaft?
I'm curious if the roter actually touches the contacts in the cap, or does it just arc because its so close?
Mark | | | | | Joined: Aug 2011 Posts: 835 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 835 | I don't think it touches, because if it did, it would soon score the cap contacts, and then it wouldn't touch anyway.
Kurt | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 |
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Feb 2000 Posts: 5,190 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,190 | I was recently cleaning some old tachometers and needed a way to check them. I used a 250 inline 6 distributor and a battery. I chucked the distributor shaft in my drill press with the cap facing down. Using the slowest speed and a rubber stopper (to keep housing from turning) I was able to check the meters at a set rpm. I had four meters hooked up at once so it was easy to see which ones didn't read right!
Four a quick test, it worked really good with no problems.
Joe | | | | | Joined: Dec 2008 Posts: 319 Shop Shark | | Shop Shark Joined: Dec 2008 Posts: 319 | Tachs generally sense the points opening & closing, which is the first part of distributor function...unless you have a clamp-on type, which senses secondary signal through a plug wire.
cm If you can't fix it with a hammer and screwdriver, you need a bigger hammer.1965 Chevy C10 | | |
