| | | Forums66 Topics128,021 Posts1,055,355 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2005 Posts: 1,028 'Bolter | | 'Bolter Joined: Sep 2005 Posts: 1,028 | Every winter I drain the fuel from the truck so that I can put fresh in the following year
To do this I have to remove the fuel line form the bottom of the tank...a messy prospect especially if the tank has a lot of fuel in it.
There is a drain plug on the bottom of the tank but I am afraid that would be even worse as ther eis potential for gas leaking in the cab.
I am sure there is a simple solution. Any one have a drain port on ther fuel line or similar solution?
Thanks RB53
| | | | | Joined: Feb 2004 Posts: 29,746 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,746 | The next time the tank is empty, or nearly so, go ahead and pull that bottom plug. Then install a short pipe nipple that goes through the hole in the bottom of the cab, and add a petcock valve. Then the next time you need to drain, just turn the handle.
Of course, if you park it outside overnight, the guys with a Kentucky credit card will have an easy time draining the tank, too! Jerry
| | | | | Joined: Aug 2011 Posts: 835 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 835 | You could get yourself one of those siphon things and just siphon the gas out. Or a pump.
kurt
| | | | | Joined: Jan 2002 Posts: 2,839 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,839 | You could get yourself one of those siphon things and just siphon the gas out. Or a pump.
kurt No, do as what Hotrod Lincoln suggested. Much easier to work with.
Craig My '50 Chevy 3100 5 window, '62-235cu, 3:55 rear My truck ....... Respect The Rust If I'm not working on my truck, '65 m00stang or VW camper, I'm fishing with the wife or smoking Salmon.
| | | | | Joined: Oct 2010 Posts: 171 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2010 Posts: 171 | In my SCCA racecar I have a fuel testing port that might be of use for what you are in need of. Could be mounted just after the rubber tube under the tank where it meets the "hard" line. "T" block t block Fuel sampler port here I have used this for 4 year and have had no problems. Another idea is Stabil in the fall.
....David
| | | | | Joined: May 2001 Posts: 1,904 'Bolter | | 'Bolter Joined: May 2001 Posts: 1,904 | I'd just use Stabil if I wanted to do something.
I doubt letting the gas sit in there for 6-7 months would do any significant damage to a Stovebolt.
Does anyone know of credible studies on what Stabil does on a chemical basis? As a chemist, I'd want the analytical data.
I'd like to get 2 identical carbs and fill them with gas, stabilized and not stabilzed. I'd have to force it through the passages. After 9 months, disassembly should show whether it's worth it carb-wise. I'm guessing there would be difference.
Personally, I wouldn't worry about older, unstabilized gas in the combustion process itself, but that's just me. 1948 3/4-Ton 5-Window Flatbed Chevrolet 34 Years. Now with a '61 261, 848 head, Rochester Monojet carb, SM420 4-speed, 4.10 rear, dual reservoir MC, Bendix up front, 235/85R16 tires, 12-volt w/alternator, electric wipers and a modern radio in the glove box.
| | | | | Joined: Feb 2004 Posts: 29,746 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,746 | Good theory- - - - -lousy in practice. I've seen 3-month-old gasoline that wouldn't light off with a match, let alone a spark plug. Unstabilized gasoline also forms enough gum in valve guides to stick valves and bend pushrods- - - - -it happens to members here often enough to make all of us spooky about running even slightly stale gasoline. Compared to the cost of a valve job, a tank of gasoline, even at today's inflated prices, isn't worth the risk. Drain or siphon as much as possible before storing a vehicle, and dump a healthy dose of stabilizer into whatever's left in the tank. Better safe than sorry! Jerry
| | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | I doubt letting the gas sit in there for 6-7 months would do any significant damage to a Stovebolt. This past summer I had the gas go bad after 12 weeks It turned a honey color and caused me lots of problems ...pic... I drive it more often now and add stabalizer if its going to sit for a while. | | | | | Joined: Sep 2010 Posts: 252 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 252 | I am really confused now! Depending on who you listen to, you get two different answers about full or empty tanks for winter storage. Does anyone have a definitive answer? I add Stabilia to my tank and let it sit over the winter and, although it doesn't like it, it starts in the spring. Is Canadian gas different than American :-) I have also read that an empty tank leads to rust and you should leave the tank full during storage to reduce condensation. Questions, questions! | | | | | Joined: Aug 2011 Posts: 835 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 835 | It's the Ethanol. I never had a problem with old gas until gas started to be mixed with large quantities of Ethanol. Last year I had problems with my tiller, chainsaw and my stovebolt after they had sat awhile. The tiller and the Stovebolt I fixed by running them hard through a couple of tanks of gas. The chainsaw went in for service. Interestingly enough, the chainsaw place sold pure gas with no alcohol in quart cans because this problem is so common. A quart sold for about $4.50.
Kurt | | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | 2 cycles are particulary prone to this | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Yeah, the boss had one of those little Mantis garden tiller and two or three times a year he'd bring it in to work cus it wouldn't start. All I ever did was pull carb abpart and wash it out and she would start right up every time and run like a champ. He'd take it home and let it sit for a coupleof months and dang thing wouldn't start. I was told by a mechanic at the garden supply that the jets are so small in them that they clog when the fuel dries up in them, even after a few months.
DG
Denny G Sandwich, IL
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | my experience with small motors has always been they need to have the fuel shut off and the carb run dry before sitting for extended periods, then add the right amount of Stabil to the tank .... last winter I used my 40 year old snowblower once and gave it that shutdown a few weeks later - and after nearly a year of sitting I turned on the fuel, gave it 2 light pulls to insure gas was flowing, and with one hard pull it was purring - haven't done any more than run it to it's standby location this year, and in a couple weeks I'll start it again to go back to storage and do a proper shutdown again, same gas that was put in nearly 2 years ago
it isn't ethanol that's the problem, it's operator error, the key is to always run it until it dies from starvation, clear the carb right out, then treat any fuel that'll sit in the tank, it doesn't matter what kind of gas it is, if you leave it in the carb to evaporate it'll gum things up
Bill | | | | | Joined: Apr 2005 Posts: 1,107 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,107 | i tee off the existing line going to the fuel pump, add a short nipple to the tee bottom and a 1/4" ball valve with a pipe plug in the valve. if i have to drain the gas it goes right into my gas can. should i need some gas for one of my other gas operated engines during the winter for the atv, snow blower, generator i take it out of the trucks. i fill the tanks in november and start running them in march. weather permitting ill run around on a nice day to cycle it through. i use no additives and havent had an issue yet not to say that i cant or wont. | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | Just don't let the trucks sit, Scott
| | | | | Joined: Jul 2010 Posts: 8 New Guy | | New Guy Joined: Jul 2010 Posts: 8 | I'll add my experience here. My Mustang sits in the garage from ~November to May. No additives added and no issues for the last 10 years(when it was carburated or now that it is fuel injected). Storage method is simply turn the key off.
My other "toy" a VW powered dune buggy it is only used 1 week in August and 1 or 2 days around Christmas. Stored outside, no additives, just turn the key off and walk away. I have cleaned the carb twice since 1989.
My parents have a '48 Willy's jeep. It sits in storage from September to June, gas tank topped off and battery disconnected (stored like this since 1948) and no problems. The first time the carb was taken apart and cleaned was the summer of 2010.
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Think your right on there Bill. I went thru a half dozen weed whackers over the past 30 years, or since they came out with them. They wouldn't start from one time till the next (only trimmed a couple times a year, I hate mowing the lawn). Got to be to much trouble pulling them apart to clean the carbs and they don't have a shut off. Same problem with them before the gas became alcoholic. My (big old wife) finally got tired of knee deep weeds around the edges and brought home a Black & Decker 18v with a couple of extra batteries so she could trim. Now a days that's me favorite lawn tool.
On a little larger scale, I've got a 10hp Ariens snow blower that I've had for 29 years. It sits two or three years sometimes without being fired up (like this year). I always run it dry after every use, never change the fuel (E-10) so it may have fuel in it that’s could be considered vintage. I do give it a good dose of Stabil when I top it off though. Never tuned it up but that engine is so reliable that three pumps on the primer bulb and she fires up on the first pull every time without fail.
That said, it sure can’t hurt to run any engine on a regular schedule Scott. Although some winters Bluebelle has to sit for a spell, I just taint gonna put her thru anymore Midwest winter driving. I’ve never had a problem with her starting in the spring and I’m not particular about how full the tank is when I shut her down. I don’t have to worry about running the carb dry, the Carter W-1 takes care of that on short order all by itself. If she sits more than a week or two I gotta pump her full of petrol before she fires off. I carry what I call, Bluebelle’s fill-up flask all year round which is a cocktail that consists of 3oz of Stabil and 6oz of MMOil. Don’t know for sure if it really makes a difference but one thing for sure, it don’t hurt nothing, cept my pocket book.
Soy, all I got to say is, you one lucky guy.
Denny Graham Sandwich, IL
| | | | | Joined: Mar 2003 Posts: 1,132 Shop Shark | | Shop Shark Joined: Mar 2003 Posts: 1,132 | Denny, I have my own definition of Marvel Mystery Oil (MMO); the mystery is no one knows if it works and the marvel is they got your money. I used it for years in a LeBlond radial engine on a Rearwin airplane. Never knew if it did any good or not but everyone else was using it so not wanting to look like a dummy I did too. Don't think it hurt the engine any.
Weeds | | | | | Joined: Nov 2011 Posts: 52 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2011 Posts: 52 | I was told ethinol attracts moisture then starts breaking the fuel down. Most cars now days have a evap fuel system and fuel injection and normally dont have problems sitting for long periods of time. But anything exposed to the atmosphere may cause problems, like carbs and unsealed gas cans.
52' Chevy 6400 2 ton
