| | | Forums66 Topics128,010 Posts1,055,305 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2011 Posts: 52 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2011 Posts: 52 | Ive been tossing the idea around of getting some adapters made to fit the 22.5 (big rig) wheel on my 52 2 ton. Has anyone done this or would anyone be interested in some if i could get them done for a reasonable price?
52' Chevy 6400 2 ton
| | | | | Joined: Jan 2008 Posts: 4,960 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,960 | So are you going to take some 22.5 open center wheels and weld them to center of your old wheels. If so, I have done this on a brake drum lathe. I had a bunch of 8.25 open center wheels. If I were to do it again, I would probably use 7.50 wheels, but I sold all of them for salvage quite a few years ago. | | | | | Joined: Nov 2011 Posts: 52 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2011 Posts: 52 | I was talking about the aluminum adapters like the guys are using now days to put the 22.5 on thier one ton duallys. This would allow me the put aluminum 22.5 on my truck. i know some people want to stay with the stock look, but i figured a few may be interested in these.
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | I've looked at it before as well have others, there may be an old thread about them.
In my research (even made up an auto-cad drawing to see how it might work)there just wasn't enough room to make it all work without seriously offseting the wheel for the thickness of the spacer. It works on 8 lug pickups because the 8 lug pattern fits well inside the big 10 lug wheel center. Not so with our 10 lugs on 7.25" pattern.
No reason you can't look at it again, you may come up with a workable solution that suits you.
Grigg | | | | | Joined: Nov 2011 Posts: 52 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2011 Posts: 52 | Makes since. Will probably be more touble than its worth. Prob easier to do an axle swap and get better brakes in the process. Maybe in the future.
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Have you checked out the disc brake thread, sticky at the top of the big bolts section? In that I outline a way of keeping your original 2 ton I-beam and swapping newer spindles and disc brakes.
Grigg | | | | | Joined: Sep 2006 Posts: 1,276 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 1,276 | Grigg do the wheels in your head ever stop turning  | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | No. I wish I could follow through immediately with everything I think about.. it's confusing getting back into a project only when time allows here and there and remembering everything again.
Grigg | | | | | Joined: Sep 2006 Posts: 1,276 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 1,276 | Grigg today it is called A.D.D. or attention deficit disorder I too am afflicted one idea leads to ten others just one long string of thought. The difference between you and I is you seem to be able to focus long enough to take advantage of it.  | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | I don't know what your bolt pattern is, however, there are 22.5's out there for just about any bolt pattern, starting w/ late '50's trucks when tubeless tires first came out.
